POV-Ray : Newsgroups : povray.general : Curved Triangle Problems Server Time
10 Sep 2025 23:58:29 EDT (-0400)
  Curved Triangle Problems (Message 1 to 10 of 10)
Subject: Curved Triangle Problems
Date: 19 Apr 2002 14:33:30
Message: <3cc062f9@news.povray.org>
Well, I've checked my include file (in p.binaries.scene-files), and I'm
not sure what the problem is.  I've verified that, when used only once,
the correct number of triangles is generated (LOD^2).  However, when
invoked multiple times, an excess number is generated, and I'm not sure
why.  If others could help me look at this, I'd appreciate it.
Thanks in advance,
...Chambers
PS If needed, I can supply a sample scene which demonstrates this
problem.
Subject: Re: Curved Triangle Problems
Date: 19 Apr 2002 14:50:24
Message: <3cc066f0@news.povray.org>
Okay after what you told, I checked your macro again.. Could it be as simple
as this?  ;o))
#declare LOD=LOD+1;
... this happens every time you invoke the macro because it's a global
variable! You don't undefine it after the macro is finished, so next time
your macro takes the variable, it's +1 ..  Don't worry, we all make
mistakes.. Assuming this was the bug cause I didn't test it yet.
Hugo
Date: 19 Apr 2002 17:30:39
Message: <3cc08c7f@news.povray.org>
Your macro seems to result in sharp edges between the triangles. For
example, try changing the smooth_triangles to regular triangles in
curvetri.inc, and rendering this scene:
#include "curvetri.inc"
camera { location <0, 3, -6> look_at <0, 0, 0> }
light_source { <-30, 30, -30> rgb 1 }
plane { y, -1 pigment { rgb 1 } }
mesh {
  curved_triangle (<-4, 0, 0>, <-1, 0, 0>, <0, 2, 2>, <0, 1, 0>, <0, 2, -2>,
<0, 1, 0>, 50)
  curved_triangle (<4, 0, 0>, <1, 0, 0>, <0, 2, 2>, <0, 1, 0>, <0, 2, -2>,
<0, 1, 0>, 50)
  pigment { red 1 }
Another problem is that if you scale the entire scene by a constant factor,
the shapes of the curved_triangles change. Also, if the lengths of the
normal vectors aren't 1, the vertices don't match up with the specified
points.
Anders
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Date: 22 Apr 2002 01:14:00
Message: <3cc39c18@news.povray.org>
> simple
> as this?  ;o))
> #declare LOD=LOD+1;
> time
> Regards,
> Hugo
Doh!  For some reason, that did it.  I thought it wouldn't matter,
since it is an argument to the macro... I guess it mattered :)
...Chambers
Date: 22 Apr 2002 13:15:30
Message: <3cc44532@news.povray.org>
> factor, the shapes of the curved_triangles change. Also, if the
> lengths of the normal vectors aren't 1, the vertices don't match up
> with the specified points.
> Anders
Hmm... the shapes shouldn't change, but I'll take a look.
By the way, I've fixed the normal thing in my C++ implementation...
now, the length of the normal affects the curvature of the triangle.
...Chambers
Date: 22 Apr 2002 16:23:52
Message: <3cc47158$1@news.povray.org>
Would it be a good idea to get the C version into the next MegaPOV?
Hugo
Date: 23 Apr 2002 10:48:43
Message: <3cc5744b$1@news.povray.org>
Looking at the algorithm you described, you're offsetting points based on
normal values, and as the size of the triangle increases, this offset
becomes less significant. Also, while adjacent edges between triangles will
be continuous when the normals are the same, there's no reason for them to
be smooth. I think you're going to need a completely different algorithm to
ensure this.
Anders
Date: 23 Apr 2002 11:31:35
Message: <3cc57e55@news.povray.org>
> on normal values, and as the size of the triangle increases, this
> offset becomes less significant.
Right - if you scale the triangle, you must also scale the normals
(odd, but true :)
> triangles will be continuous when the normals are the same, there's no
> reason for them to be smooth.
Hmm...  I hope that's not the case, but it may be.  Anyway, in the
tests I've done it's come out smooth, but I haven't tested many meshes
extensively (just large, odd shapes to make sure things look right).
> completely different algorithm to ensure this.
Could be.  I looked into using bezier splines for the three sides, but
the middle section always got me bogged down in how to compute it.
This method seems much more elegant, although it requires tracking a
large amount of data (points, normals, magnitudes and, if wanted,
texture coordinates etc).
...Chambers
Date: 24 Apr 2002 04:57:20
Message: <3cc6736f@news.povray.org>
<lol> First, let's get it working right :)  Then, we'll see.
...Chambers
Date: 24 Apr 2002 15:49:41
Message: <3cc70c55$1@news.povray.org>
Yeah, well maybe it could be improved.  :o)  I finally did some more tests,
now the LOD is working.. It seems that poor edges from a mesh doesn't really
"smooth out".. The normals are turned into -- curves? But I'm not sure if
this merely means a linear curve.
Hugo
