POV-Ray : Newsgroups : povray.general : Real Time Ray Tracing Server Time
30 Dec 2025 00:01:58 EST (-0500)
  Real Time Ray Tracing (Message 1 to 10 of 40)
Subject: Real Time Ray Tracing
Date: 8 Mar 2002 04:07:30
Message: <3c887f52@news.povray.org>
http://www.xl3d.com/bottom.htm
I haven't looked at it yet, but it looks interesting.
...Chambers
Version: 6.0.323 / Virus Database: 180 - Release Date: 2/8/2002
Subject: Re: Real Time Ray Tracing
Date: 8 Mar 2002 04:20:02
Message: <l20h8us9sqrsng4tdrn8kl9h6o2mvd2prq@4ax.com>
On Fri, 8 Mar 2002 01:04:46 -0800, "Ben Chambers" <bdc### [at] yahoocom>
AFAIK they mix terms. They write about OpenGL as raytracer but afaik OpenGL is
not a raytracer. Am I right ? I'm not an expert but this thing looks at first
sight like Moray with OpenGL preview.  Perhaps with speed improvements. I'm
sceptical :-)
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
Date: 8 Mar 2002 06:16:03
Message: <chrishuff-1FA5CC.06161508032002@netplex.aussie.org>
In article <l20h8us9sqrsng4tdrn8kl9h6o2mvd2prq@4ax.com>,
> sceptical :-)
OpenGL has no built-in support for raytracing, but there is a trick
which has to do with getting it to render a single pixel and getting the
depth of that pixel. The result is intersection information...very
roundabout and probably too inefficient to be useful, but I don't really
know.
You could also use scanline rendering instead of tracing the primary
rays, if you don't mind everything being converted to polygons. Same
technique: use the depth buffer to find the intersection points. Barely
something you could consider raytracing, but it accomplishes the same
thing.
Date: 8 Mar 2002 08:58:52
Message: <3c88c39b@news.povray.org>
  The source of the page which that links give me is the following:
<html>
<head>
<title>**</title>
</head>
<body marginheight=10 marginwidth=10 topmargin=10 leftmargin=10 background="imag
es/bot-bg.gif">
</body>
</html>
  Yes, looks quite interesting.
  Besides, real-time raytracing is nothing fancy. POV-Ray can do it.
Date: 8 Mar 2002 14:23:11
Message: <3c890f9f@news.povray.org>
In article <3c88c39b@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
And it can do so with double precision (the mentioned code uses single
precision all the way) and something better than a few triangles and spheres
using primitive light model, for example text objects and phong shading...
    Thorsten
e-mail: tho### [at] trfde
Date: 8 Mar 2002 15:24:37
Message: <3c891e05$1@news.povray.org>
And how can that be set up? Or is it something for version 4 (!!!) that
we're just getting a preview of in 3.5?
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c890f9f@news.povray.org...
spheres
>     Thorsten
Date: 8 Mar 2002 15:35:02
Message: <3c892076@news.povray.org>
In article <3c891e05$1@news.povray.org> , "Mahalis" <don### [at] fakeycom>
No, just a built-in scene to demonstrate that contrary to some claims POV-Ray
is not slow.  Some scenes are simply very complex and people making the claim
a scene renders slowly because POV-Ray would be slow don't really know what
they are talking about because they are comparing it to (commercial) programs
that don't use ray-tracing or simplified forms of (pseudo) ray-tracing :-)
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 8 Mar 2002 15:36:15
Message: <au7i8u8b54vg4mduo33eb20n5kcmhfv44u@4ax.com>
It is builded in Win and Mac version. Read carefuly latest longest discussion
in povray.programming (it was there iirc). With GUI-Extensions everybody can
build its own application to real-time cooperation with povray.
ABX
Date: 8 Mar 2002 15:54:08
Message: <3c8924f0@news.povray.org>
Just get a fast-enough computer, make a simple scene and render it
in an animation.
  For example this scene:
camera { location -z*15 look_at 0 angle 35 }
light_source { <100,250,-50>, 1 }
union
{ sphere { -x, 1 }
  sphere { x, 1 }
  sphere { y, 1 }
  box { <-2,0,-1.5><2,-1,1.5> }
  pigment { rgb <1,.5> }
  finish { specular .5 reflection .5 }
  rotate <clock*360, 2*clock*360, .75*clock*360>
renders in my computer (1.2GHz Athlon) at 320x240 with +kff500 -ga -f
at about 5 FPS.
Date: 8 Mar 2002 16:31:02
Message: <3c892d96@news.povray.org>
In article <3c8924f0@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> in an animation.
> union
> { sphere { -x, 1 }
>   sphere { x, 1 }
>   sphere { y, 1 }
> at about 5 FPS.
Indeed, even the render windows with their slower display deliver such
framerates on fast systems today.
Of course, the demo that is built-in has a few additional features like being
thread-safe and no dependency on dynamic memory allocation.  It also uses more
appropriate bouble-buffered drawing.  The hard-coded scene allows to skip
parsing as well, also the scene currently used isn't really very simple: In
the scene description language it is less than forty lines with no fancy
constructs, but expanded in C it is over 2000 lines of structure definitions
taking about 20 KB of memory...
Oh, and before people start wondering why the POV-Team spends time on this, it
should be noted that this allows for example to uncover bugs or inefficiencies
in the source code and in addition only "playing" with some parts of the code
allow us to understand again what those who programmed it a decade ago were up
to.  In short, playing with it today allows improvements for all users in the
future :-)
    Thorsten
Thorsten Froehlich
