POV-Ray : Newsgroups : povray.general : Graph Paper Texture Server Time
19 Jun 2026 08:23:04 EDT (-0400)
  Graph Paper Texture (Message 1 to 8 of 8)
Subject: Graph Paper Texture
Date: 22 Feb 2002 21:56:07
Message: <3c7704c7$1@news.povray.org>
I really like my graphpaper background object macro (see "Graphpaper" in
pbi), but it renders very slowly. I suspect it is the layered texture with
large amounts of transparency. It also cannot be placed on an object as well
as it does on the flat surfaces of my background. So I was looking for
another way to do it. I think quilt is the most likely pattern, but I don't
seem to be able to get a sharp enough curve. Is there a better way to do
what I want?
    First snow, then silence.
    This thousand dollar screen dies
    so beautifully.
Subject: Re: Graph Paper Texture
Date: 23 Feb 2002 00:20:46
Message: <3c7726ae$1@news.povray.org>
If you're using 3.5, try basing it on this...
#declare boxesfunc = function{max(x-int(x),y-int(y),z-int(z))}
function {select(boxesfunc(x,y,z)-.5,1-boxesfunc(x,y,z),boxesfunc(x,y,z))}
That code may or may not work, I didn't test it...
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 23 Feb 2002 10:22:51
Message: <3c77b3cb$1@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3c7726ae$1@news.povray.org...
    Doesn't seem to... I am still working on it though...Thanks.
Date: 23 Feb 2002 21:16:50
Message: <3C784D0A.50504@aol.com>
How about a gradient pattern inside a checker pattern.
Date: 24 Feb 2002 02:10:35
Message: <3C789288.734EEDD7@iquest.net>
In 3.1 I've used something like:
#declare GraphPaper =
            gradient x
            color_map {
                [0.1 color Red]
                [0.1 color transmit 1.0]
            gradient y
            color_map {
                [0.1 color Green]
            gradient z
            color_map {
                [0.1 color Blue]
Tweaking this gives me a decent "graph paper" look.  I've never noticed it being
significantly slower than, say, checkers, bricks, or similar.  Although, I must
admit, you are doing good things with your macro.  Nice work.
    Randy
> what I want?
>     so beautifully.
Date: 24 Feb 2002 08:22:37
Message: <3c78e91d$1@news.povray.org>
"Randy Hawley" <rha### [at] iquestnet> wrote in message
news:3C789288.734EEDD7@iquest.net...
    This is about the same way I'm doing it. Usually it is fine, but I was
just hoping for some speed increase. The untextured boxes render about 10
times as fast.
    I may be out of luck. I have made a couple of function pigments that
look worse and render slower... reverse progress of a sort, I know what not
to bother with anymore.
    Thanks though. Any input in appreciated. This may help me stop wasting
my time...
Date: 24 Feb 2002 13:05:55
Message: <3c792bc6.6655393@localhost>
On Fri, 22 Feb 2002 21:52:34 -0500, "Bill DeWitt"
>what I want?
I have recently been wrestling with this problem as well.
What seems to work the best for me is to declare a
function to get one direction of lines, then add
three copies of the function, each set to use
a different axes.  You might want to pop over to
the binaries scene files group and grab a posting
with the subject "ech_s12_drk_01.zip".  It
uses this technique to get 2d graph paper but I
see no reason why it can't be expanded to 3d graph
paper
Pete
Date: 24 Feb 2002 15:26:13
Message: <3c794c65@news.povray.org>
    I think I will end up with what I am using now. I forced my macro to
also generate a GraphObjectTexture that I can use on any object (see
p.b.i.). The paper only uses two dimensions and then I duplicate the
textured object to make three walls, so the GraphPaperTexture doesn't really
work on an object.
