POV-Ray : Newsgroups : povray.general : texture + diffuse Server Time
13 Jan 2026 19:08:37 EST (-0500)
  texture + diffuse (Message 1 to 10 of 13)
Subject: texture + diffuse
Date: 28 Jan 2002 06:26:03
Message: <3c55354b$1@news.povray.org>
When I use a stone texture and change the diffuse value, only one
element of the texture is changed:
#include "stones.inc"
camera{location z*-2}
light_source{z*-2 rgb 1}
plane
   z, 0
   texture
      T_Stone25
   finish
      diffuse 2
Why isn't the whole texture changed? What can I do to change the
diffuse value of the whole texture?
I use POV-Ray 3.5.
Felix Wiemann
Subject: Re: texture + diffuse
Date: 28 Jan 2002 06:51:49
Message: <bjea5u4jes3c0fr5ndhp88l3hon5f6hg53@4ax.com>
>I use POV-Ray 3.5.
plane {
  z, 0
    T_Stone25
    diffuse 2
Peter Popov ICQ : 15002700
Date: 28 Jan 2002 08:45:50
Message: <3c55560e$1@news.povray.org>
Huh?  That's not logic!
Hugo
> plane {
>   z, 0
>   texture {
>     T_Stone25
>     diffuse 2
Date: 28 Jan 2002 09:16:21
Message: <3c555d35@news.povray.org>
Felix Wiemann <Fel### [at] gmxnet> wrote:
:    texture
:       T_Stone25
:    finish
:       diffuse 2
  AFAIK this is actually a layered texture. You are not modifying the first
texture, but you are creating another texture on top of it.
  The effect you describe is strange, though.
Date: 28 Jan 2002 10:26:48
Message: <chrishuff-304553.10284928012002@netplex.aussie.org>
In article <3c55354b$1@news.povray.org>,
> I use POV-Ray 3.5.
What you are doing is creating another texture layer with the default
texture used for everything but the diffuse. You want:
plane {z, 0
        T_Stone25
        finish {
            diffuse 2
BTW, it also greatly helps readability if you neatly indent the code,
indenting inner blocks more than their containing blocks, and it helps
avoid this sort of problem later on. You don't necessarily have to do it
the way I did it, just be consistent and use *some* indentation.
Date: 28 Jan 2002 11:02:14
Message: <3c557606@news.povray.org>
> plane {z, 0
>     texture {
>         T_Stone25
>         finish {
>             diffuse 2
That doesn't work. It's still only one element with higher diffuse. I
wonder about that, too.
helps
it
I've tried so. Let me explain my indent "system":
1 (object or object modifier like union, pigment, plane, ...)
2       {
3       (some code)
4       }
(some code) can contain an object or object modifier.
It's better visible in an editor. I think it's a quite logical system.
But what do you suggest should I change?
Felix Wiemann
Date: 28 Jan 2002 11:16:44
Message: <3C557984.C577DFC4@atosorigin.com>
> > plane {z, 0
> >     texture {
> >         T_Stone25
> >         finish {
> >             diffuse 2
That's totally normal.
Check T_Stone25 definition....
It is a layered textured. so applying modifiers only works for one, not all of
them.
Solution for your problem : inline T_Stone25 and put the relevant finish
modifiers!
Non Sine Numine
http://grimbert.cjb.net/
Date: 28 Jan 2002 11:27:11
Message: <lfua5u8qrootuigbfvp0m38c9sf35kb5k7@4ax.com>
> modifiers!
There can be also some persons which don't want open, search, copy, close long
way (also becouse of respect to authors of code). For such persons there is
still workaround.
// START
#default{finish{diffuse 2}}
plane{
  z, 0
  texture{T_Stone25}
#default{finish{diffuse .6}} // default according to documentation
/* rest of scene */
// END
ABX
Date: 28 Jan 2002 12:05:19
Message: <3C5584E8.239F3950@atosorigin.com>
> still workaround.
Unless one also want an Unmodified T_Stone_27
Or already add loaded "stones.inc", may be due to another include...
So beware of that solution.
Non Sine Numine
Date: 28 Jan 2002 12:28:14
Message: <gd2b5ukf5epm7eop501a2207tnmmtngdrg@4ax.com>
> > still workaround.
Have you checked my solution ? It leaves T_Stone_27 unmodified
But of course there are some danger situations. Mainly when other default are
changed somewhere.
ABX
