POV-Ray : Newsgroups : povray.general : BMP to TGA utilities? Server Time
24 May 2026 23:53:27 EDT (-0400)
  BMP to TGA utilities? (Message 1 to 10 of 12)
Subject: BMP to TGA utilities?
Date: 4 Jan 2002 13:42:36
Message: <3c35f79c$1@news.povray.org>
So far for my animations, In order to produce animations that others can
view I've been using the pjBmp2Avi.exe and AVI2MPG.exe utilities. (for my
own personal viewing, I just stop at the AVI).
The results have been adequate and the file size reasonable.
However, with my current project, (IRTC entry, 10 days to go *crosses
fingers*) there's a few seconds in the middle of the animation where the
picture quality goes right out the window.
I did a quick search and found another utility called CMPEG.exe with
cmpg63m.exe as a windows front-end (I'm sure some of you know it).  The
challenge is that this utility doesn't seem to take BMP images as input, but
it rather wants TGA images.
Does anyone know of a utility that I can use to convert 700 bmp's into
tga's?
Thanks.
Tom Bates.
Subject: Re: BMP to TGA utilities?
Date: 4 Jan 2002 14:01:41
Message: <slrna3bv0n.44a.ron.parker@fwi.com>
> tga's?
http://netpbm.sourceforge.net/README
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 4 Jan 2002 14:41:28
Message: <3c360568@news.povray.org>
Thanks, Ron, I'll keep that in mind.
For now, I've found IrfanView which seems to be adequate for my needs.
Thanks for the tip, though.
One can never have too many utilities. :)
Tom Bates.
Ron Parker <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
> > tga's?
1u_steps
X=asc(substr(C,Y
Date: 4 Jan 2002 15:47:34
Message: <3c3614e6@news.povray.org>
I love infranview. Very nice for conversion and for flipping through the
irtc zips.
Tom Bates <tho### [at] shawca> wrote in message
news:3c360568@news.povray.org...
Date: 5 Jan 2002 04:41:58
Message: <3c36ca66@news.povray.org>
> tga's?
You can use POVRay:
putting an imagemap (with your bmp) on a cube/plane, use an adequate
orthographic camera turn off AA and render... (original size)
be sure to set tgaoutput: "Output_File_Type=T" in inifile
You may use povray 3.5 beta, because there's the solved problem of "camera a
half pixel off"...
and you will have to write a script in povray to get through the 700
filenames...
Ok, you can use IrfanView, just wanted to point out that you can use povray
for many, many imageprocessings
If you want to use cmpeg more, you may set tgaoutput as default; no
converting to tga anymore...
cukk
light_source{-9 1}#macro p(N,_,Y)sphere{<-_,Y-7,15>,.5pigment{color
<2,3,1>/(mod(N,2)?3:9)}}#if(-_<9)p(div(N,2),_-1,Y)#end#end p(463141
9,9)p(69973,9,8)p(201075,9,7)camera{}p(69973,9,6)p(489301,9,5)// KK
Date: 5 Jan 2002 16:52:23
Message: <3c377597@news.povray.org>
Well, I'm sold.
Of the three MPEG encoders that I've tried, CMPEG is my favorite.
It took a bit getting it to work (and I couldn't get the Windows Front-End
to work for me at all) but both the image quality and the mpeg file size are
better than the other two that I've tried.
It's not as easy to use as the others, but that's ok, I'm a programmer.
One more thing not to worry about as the IRTC deadline looms ever nearer.
Tom Bates
Date: 5 Jan 2002 17:52:04
Message: <chrishuff-5026C6.17533505012002@netplex.aussie.org>
> > tga's?
> You can use POVRay:
> half pixel off"...
> filenames...
You would have to make sure to set POV up to not do gamma
correction...also, use an ambient of 1 and no light sources. And there
is still the possibility that it will introduce errors...you should
really use an image conversion program. On the Mac, GraphicConverter
would be perfect. The ImageMagick package should be helpful no matter
what the platform:
http://www.imagemagick.org/
Date: 5 Jan 2002 18:45:49
Message: <slrna3f41g.3v5.ron.parker@fwi.com>
On Sat, 5 Jan 2002 14:50:33 -0700, Tom Bates wrote:
> Well, I'm sold.
I'm pretty sold on the mpeg2enc that comes with the Linux mjpeg tools.
I think there might be a cygwin version available, too.
Date: 5 Jan 2002 23:14:47
Message: <chrishuff-914AE8.23162005012002@netplex.aussie.org>
In article <slr### [at] fwicom>,
Maybe the tools here would be helpful:
http://www.mpeg.org/MPEG/MSSG/
Date: 6 Jan 2002 11:47:37
Message: <3c387fa9$1@news.povray.org>
YKYBRTTL when someone asks:
> > tga's?
And you respond:
> You can use POVRay:
a
> half pixel off"...
This bug was promised to be fixed in a future beta, but it isn't fixed yet.
Anders
