POV-Ray : Newsgroups : povray.general : new hardware configuration question ?? Server Time
12 Sep 2025 07:51:30 EDT (-0400)
  new hardware configuration question ?? (Message 1 to 10 of 23)
Subject: new hardware configuration question ??
Date: 4 Oct 2001 14:28:38
Message: <3bbcaa56$1@news.povray.org>
hello,
i've got an old 166MHz windows machine with 32MB of
memory.  don't use it much cuz i've got a laptop now that
i like a lot.
but i'm thinking about upgrading the desktop and i would
like to know if there is a maximum amount of memory
that windows ME or 98SE can use.  i can't believe how
cheap everything is now!  i can get a FIC athlon 1.2GHz
motherboard for $189.  i can get 500MB of memory for
less that $80!!
i want to spend $350 and run the athlon with 1 GB of
memory (i'm wanting to get prepared for megapov or
3.5, and i understand they are memory pigs), but i'd
feel like an idiot if the op system won't run it.
i've also heard that the bios on the motherboard can be
a limiting factor.
thanks, miker
Subject: Re: new hardware configuration question ??
Date: 4 Oct 2001 15:54:16
Message: <3bbcbe68@news.povray.org>
MR <a### [at] bnet> wrote:
: but i'm thinking about upgrading the desktop and i would
: like to know if there is a maximum amount of memory
: that windows ME or 98SE can use.
  In theory the memory limit in P-II and newer is (AFAIK) 64 GB (I don't
remember if the 4 GB limit was increased in P-II or in some previous processor,
but that's not so important here).
  In practice some OS's have a 4 GB or 2 GB limit (due to 32-bit architecture).
I don't remember what was the limit in Windows 9x, but it could be that 2 GB
(this is caused by the OS using signed integers, which halves the maximum
value). I don't think there's any worry about having 1 GB of memory (AFAIK).
  (Of course Windows may have some braindead limit on how much memory a single
process can allocate at a time which is much less than 2 GB; I faintly
remember something like that...)
: i've also heard that the bios on the motherboard can be
: a limiting factor.
  I think there was a limit in some motherboards on how much memory they
will cache (memory above that limit can be read but it's not cached). I don't
know if it's any issue nowadays.
Date: 4 Oct 2001 16:24:34
Message: <3BBCC64A.9D663A8F@gmx.de>
As i heard Windows 9x has serious problems with anything more than 256 Mb
(!!!). Windows NT/2000 should be able to use up to 2 Gb for Applications
(the upper 2 Gb are reserved for the system) Of course this is no first
hand information, only what i have heard.
From my own experience i have the impression Linux handles larger amounts
of memory much better than Windows.
Date: 4 Oct 2001 17:30:04
Message: <3bbcd4dc$1@news.povray.org>
Win ME can handle up to 768 MB of RAM.  I have a system that is configured
like that.  In my case I was limited by the motherboard.  Some
configurations will limit max memory to 512MB of RAM.  Win ME and 98SE are
quite similar so I would think it would allow the same memory as ME.  Check
with the motherboard maker to determine the limits for their boards and
BIOS.
NT 4.0 (SP5)  will handle up to 2 GB of RAM.
I refuse to participate in Micro$oft's annual rite of operating system
upgrade/ extraction of money from the user so I am unfamiliar with Windows
2000 and XP.
Good luck.
Jim
"MR" <a### [at] bnet> wrote in message news:3bbcaa56$1@news.povray.org...
> hello,
> i like a lot.
> less that $80!!
> a limiting factor.
> thanks, miker
Date: 4 Oct 2001 18:06:04
Message: <3bbcdd4c$1@news.povray.org>
thanks guys,
i'm pretty sure that ME will handle 512MB cuz dell sells laptops
configured that way, but i wasn't sure about double or even
triple that.
oh, by the way.  i found the 512MB PC133 for $29 apiece.  i
should now be able to get a new 1.2GHz athlon motherboard
with processor and 1GB of memory for $250.  incredible.
bring on the 3.5.    ;-)
miker
news:3bbcbe68@news.povray.org...
processor,
architecture).
GB
(AFAIK).
single
don't
Date: 4 Oct 2001 18:20:32
Message: <3bbce0b0@news.povray.org>
processor,
architecture).
GB
> value).
    9x uses full 32-bit addressing so the limit is a full 4Gb.
    Not much - one should take a look at the webpage that someone (Ken?)
posted in off-topic recently though - There are various performance issues
associated with more than 512Mb RAM under 9x, though 98 is slightly better
than 95.
single
    Again you can allocate a full 4Gb, you'll get some hideous disk
thrashing from doing it, but it'll work (most of the time).
    Usually only in how many slots of what sort and what max SIMM/DIMM size
they support.
don't
    I've not heard about anything along those lines before... I haven't
checked to see if he says anything on the subject, but Tom is usually my
first stop for hardware issues :
    www.tomshardware.com
    Of course, 2k has far superior memory handling - I'd look up the details
but I don't have the relevant documentation installed currently...
Scott Hill.
Software Engineer.
E-Mail        : sco### [at] innocentcom
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
Date: 4 Oct 2001 18:25:09
Message: <3bbce1c5@news.povray.org>
"MR" <a### [at] bnet> wrote in message news:3bbcdd4c$1@news.povray.org...
> i
    I was surprised at how little difference there was in rendering times
with 3.5 on my PIII933 and a friends Athalon1.4.
    Of course, compared to your 166 that baby's gonna fly...
Scott Hill.
Software Engineer.
Date: 4 Oct 2001 19:22:44
Message: <3bbcef43@news.povray.org>
MR wrote:
> hello,
> i like a lot.
> less that $80!!
> a limiting factor.
> thanks, miker
If you only want it to render your scenes try linux.
(However scene creating semmed to me a bit more comfortable with the
windows gui. But there is an other group for discussing this ;-) )
Sebastian H.
Date: 4 Oct 2001 20:58:53
Message: <3BBD04F9.FABBF4A5@geocities.com>
Yes. And it also could theoretically keep running for months, but bad
implementations cripled Win95 & Win98 to die at 49.7 days. That one bug has
finally been fixed, but there are many such.
Earlier Win98 systems had problems with more than 96 MB RAM.
My PIII is listed as being able to take a max of 384 MB.
> they support.
Yup. That's a key factor.
> don't
IIRC, that's where the Win9X problems with 96MB came in.
Of course, it really depends on what his needs are. For home use, Win2K is
usually not a good solution. Of course, it is a little more stable, and is good
for developers.
Especially if he just needs a good POV-Ray render box, then running Linux
instead is probably a good alternative. Probably since RedHat 5.2, and
definitely since 6.0 and 7.0, it's gotten easier to install than Win9x on a new
machine. And a custom compile on Linux of POV-Ray usually zipps along quite
nicely, and it has none of the major performance issues of the Win9X series of
OS's, and it's not nearly as much of a memory hog as 2K.
As long as the apps he needs for Linux, it'd be worth looking into.
Jon A. Cruz
http://www.geocities.com/joncruz/action.html
Date: 4 Oct 2001 21:02:42
Message: <3BBD05E0.6707ED5D@geocities.com>
I was just posting a little about that. Good stuff.
Ahh.
But I think that pointing out Emacs and the POV-mode could be
appropriate here. Especially since Emacs can easily be run on Windows
and on Mac OS X, in addition to the traditional Unix/Linux builds.
http://www.acc.umu.se/~woormie/povray/
Jon A. Cruz
