POV-Ray : Newsgroups : povray.general : switch question Server Time
24 Apr 2026 02:19:15 EDT (-0400)
  switch question (Message 1 to 7 of 7)
Subject: switch question
Date: 23 Sep 2001 14:52:13
Message: <3bae2f5d@news.povray.org>
As I can't keep up with the 3.5b versions ;) I'm still using 3.1 and Mega 7.0.
I'm sure that in Megapov7, one can include switches for the Width and Height
(+Wn & +Hn ?)  in the scene file but I cannot find an example of how it's done.
I have searched the docs, believe me ! but can't get the keywords Image_height
& width or +Wn to be recognized.  Will someone please give me the simple
code for use in the scene?
Also ... is it possible to specify AA depth and threshold in the scene?
I haven't been able to.
If not, what's the simplest method to use to change resolution and AA without
having to edit the Quickres INI every time?  Can i write my own INI and then
call it up to override the quickres.ini ?  I have zero experience with command
lines or useing sperate INI's.  Am reading up INI's right now.
One more Q ... am endeavoring to create some logos for a friend using 320x240
and 160x120.  At this res, what's the best AA threshold and depth to use ? They
don't take much time to render so I would like to shoot for the highest quality
Possible.
Tanks
Y
Subject: Re: switch question
Date: 23 Sep 2001 20:18:02
Message: <3bae7bba@news.povray.org>
"Y" <out### [at] huntelnet> wrote in message news:3bae2f5d@news.povray.org...
Height
done.
Image_height
global_settings {
ini_option "+w320 +h240"
Same way as above, only use +a0.3 for example, of course  :-)
without
then
command
Adding to the renderer\Quickres.ini file is as easy as going into the Tools
menu and selecting Edit secondary INI file.  I think that's better than
creating a new one, only my opinion of the moment though.
320x240
They
quality
> Possible.
+a0.1 +r4 might do okay and not take forever.  A jitter (+j1 is default) of
1.0 can sometimes foul up things by making grainy lines though so you might
want to lower it.
Everyone has their own preference.  I just like to also use +am2 instead of
+am1 because the description of how it works sounds good to me  :-)
Bob H.
Date: 23 Sep 2001 21:38:10
Message: <3bae8e82@news.povray.org>
: +a0.1 +r4 might do okay and not take forever.  A jitter (+j1 is default) of
: 1.0 can sometimes foul up things by making grainy lines though so you might
: want to lower it.
: Everyone has their own preference.  I just like to also use +am2 instead of
: +am1 because the description of how it works sounds good to me  :-)
: Bob H.
Thanks Bob ... messed with it a bit and didn't find a lot of difference at
320x240 between am1 and am2 ... am2 does slow it up quite a bit but as
you say ... it sounds cooler ;)
Can all the switches be used in the global ini-options ?
Thanks again
Y
Date: 24 Sep 2001 02:52:38
Message: <3baed835@news.povray.org>
Bob H. <omn### [at] msncom> wrote:
: global_settings {
: ini_option "+w320 +h240"
  Don't get used to that if you want to use pov3.5 some day.
  You can either write those on the command line (field in windows) or
make a scene-specific ini file (in windows it should be enough to open
that ini file and "render" it).
Date: 24 Sep 2001 09:36:29
Message: <3baf36dd@news.povray.org>
:   Don't get used to that if you want to use pov3.5 some day.
:   You can either write those on the command line (field in windows) or
: make a scene-specific ini file (in windows it should be enough to open
: that ini file and "render" it).
 - Warp -
Yup ... I saw that when I was taking it for a test run ...
Y
Date: 24 Sep 2001 10:45:37
Message: <3baf4711@news.povray.org>
"Y" <out### [at] huntelnet> wrote in message news:3bae8e82@news.povray.org...
Well hey, from the doc description it must be better  :-)
Nope.... and I have no idea what can and can't be either except as the docs
say clock settings cannot be.  Direct quote: "Not all INI options can be
used. Specifically, those related to animation, output file, and shell-out
commands are not allowed."
Bob H.
Date: 24 Sep 2001 12:14:39
Message: <3baf5bef@news.povray.org>
: Well hey, from the doc description it must be better  :-)
Interesting thread right here in this group ... "AA tweaking idea"
posted by Xplo Eristotle on 9/18.
Didn't see your nik in the thread so mayby you didn't see it.
: > Can all the switches be used in the global ini-options ?
: Nope.... and I have no idea what can and can't be either except as the docs
: say clock settings cannot be.  Direct quote: "Not all INI options can be
: used. Specifically, those related to animation, output file, and shell-out
: commands are not allowed."
: Bob H.
Yeah ... I saw that too. Just wondered about the output file ones.
Y
