POV-Ray : Newsgroups : povray.general : Glass Server Time
9 Oct 2024 12:17:46 EDT (-0400)
  Glass (Message 1 to 10 of 19)
Subject: Glass
Date: 9 Jan 2001 01:31:47
Message: <3a5ab053@news.povray.org>
I've been trying too figure out if PovRay renders glass correctly or not.
If you have a glass sphere that is slightly green (like normal window
glass). With most ray tracers and renderers they just map a colour too the
surface of the glass resulting in an even distribution of transparent green
when rendered(like a balloon), with of course refraction added. In real life
the centre of the sphere is actually darker because the light travels a
longer distance through the middle of the sphere than near the edge.
If PovRay doesn't do this, I think it should be easy too make something to
do this: the longer the distance that the light travels through the object,
the more light is absorbed. But I know nothing about programming or
scripting(yet). I don't want to use it only in spheres but in other shapes
as well.
Is there someone that can help me with this?
Thanks
Nekar Xenos
_____________
'E xapis meta sou.
Subject: Re: Glass
Date: 9 Jan 2001 02:16:28
Message: <c7el5tc1ci9jj2lg2mtj4gsn4qk3q81o6c@4ax.com>
On Tue, 9 Jan 2001 08:34:39 +0200, "J-Print News" <vir### [at] iconcoza>
To an extent :)
In real life glass is green because it absorbs some blue and red. To
achieve the same effect, make your sphere clear white and add a
magenta absorbing media. It behaves in the exact same way as you are
asking. The surface does not need to have a color as it is infinitely
thin (in POV's way of thinking); think of it as coating. You can give
it a finish with reflection and specular highlights, of course.
This is exactly what absorbing media does.
You can also use light attenuation which is faster. In official POV it
is not very accurate, I think, but MegaPOV offers an alternative
formula which is real-life based.
Note: I may be thining of light fading here but I don't have Mega
installed yet to check out (did a full reinstall just yesterday).
Peter Popov ICQ : 15002700
Subject: Re: Glass
Date: 9 Jan 2001 05:25:34
Message: <3a5ae71e@news.povray.org>
Thanks
Is MegaPov free? Where can I get it?
Nekar
Peter Popov <pet### [at] vipbg> wrote in message
news:c7el5tc1ci9jj2lg2mtj4gsn4qk3q81o6c@4ax.com...
> To an extent :)
the
green
life
to
object,
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Subject: Re: Glass
Date: 9 Jan 2001 05:41:13
Message: <3a5aeac9@news.povray.org>
Yes, and right here:
http://nathan.kopp.com/patched.htm
Lance.
http://come.to/the.zone
Subject: Re: Glass
Date: 9 Jan 2001 12:08:05
Message: <chrishuff-DA0AD9.12094409012001@news.povray.org>
In article <c7el5tc1ci9jj2lg2mtj4gsn4qk3q81o6c@4ax.com>, Peter Popov
It sounds like you mean the fade_color addition...it lets you specify
the color that light passing through the object attenuates to, and adds
an attenuation calculation that is supposed to be more realistic. And it
has nothing to do with light source fading, it is more of a solid-color
media-like effect.
Christopher James Huff
Subject: Re: Glass
Date: 9 Jan 2001 18:40:33
Message: <3A5BA04C.84746F2E@faricy.net>
Yes and no. That answer your question? ;)
(looks like Peter's explained it already)
Subject: Re: Glass
Date: 10 Jan 2001 05:52:11
Message: <3a5c3edb@news.povray.org>
interior
{ fade_distance ...
  fade_power ...
Subject: Re: Glass
Date: 10 Jan 2001 08:03:00
Message: <chrishuff-8059FF.08044010012001@news.povray.org>
In article <3a5c3edb@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
> interior
> { fade_distance ...
>   fade_power ...
And don't forget the fade_color available in MegaPOV.
Subject: Glass Reflections
Date: 10 Jan 2001 09:55:56
Message: <3a5c77fc@news.povray.org>
I just thought of something else. Glass reflects not only on the outside but
on the inside as well. If you look carefully at a window pane at night
you'll notice there is actually a double reflection.
Can this be done in Pov?
Thanks
Nekar
Subject: Re: Glass
Date: 10 Jan 2001 10:13:31
Message: <838o5t8ke8ok7tpc1vid8cj519dq2tg97c@4ax.com>
On Tue, 09 Jan 2001 12:09:44 -0500, Chris Huff <chr### [at] maccom>
>media-like effect.
I actually mean this:
>:: 7.2. Realistic attenuation
>:: If you set fade_power in the interior of an object at 1000 or above,
>:: MegaPov will use a realistic exponential attenuation function:
>:: Attenuation = exp(-depth/fade_dist)
>:: Colored attenuation does work with this exponential attenuation also.
Sorry abouit not being precise before but I just finished installing.
