POV-Ray : Newsgroups : povray.general : Real fire doesn't absorb, does it? Server Time
20 Jun 2026 18:42:03 EDT (-0400)
  Real fire doesn't absorb, does it? (Message 1 to 10 of 15)
Subject: Real fire doesn't absorb, does it?
Date: 15 Dec 2000 11:37:06
Message: <3a3a48b2@news.povray.org>
To create fire that looks realistic in POV-Ray the usual approach is to use
both emitting and absorbing media. Absorbing media is used to make the fire
visible on bright backgrounds.
But I think in reality fire doesn't absorb light (almost not anyway). The
reason it is still visible is that it is many times brighter than the
surrounding objects.
I think if POV-Ray showed light intensities based on for example an
logarithmic function rather than linearly it would be possible to make more
realistic scenes, and it would be easier too. I think it would affect more
things than you would think; perhaps completely change the way we think of
colors in POV-Ray.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 9)
/ Also visit http://www.povrayusers.org
Subject: Re: Real fire doesn't absorb, does it?
Date: 15 Dec 2000 13:42:03
Message: <chrishuff-EFC92C.13430415122000@news.povray.org>
In article <3a3a48b2@news.povray.org>, "Rune" <run### [at] inamecom>
Actually, it does absorb and scatter light, sometimes to a very
significant degree. Especially yellow flames, such as a candle flame or
wood fire, where there are many incandescent particles of carbon and
other smoke particles, and a lot of complex organic substances. It might
be an interesting experiment to shine laser beams through various types
of flames to measure the effects...
However, you are right that it usually just overwhelms the background
more than blocking it. Because of the limited, linear dynamic range, POV
will just make extremely bright flames look white.
> make more realistic scenes, and it would be easier too. I think it
> would affect more things than you would think; perhaps completely
> change the way we think of colors in POV-Ray.
This is possible to do as a post_process filter(*), in fact, the
"curves" filter could be used with a "raw_color" filter to do
this...then you could set up an include file with macros to imitate the
response curves of various film types or the human eye. Or maybe a
"limit_range" post_process that scales colors with components >1 down so
their brightest component is equal to one...not exactly realistic, but
maybe useful.
*the post_process patch is in MegaPOV, I have released the code for the
curves filter in these groups, and the raw_color and limit_range filters
aren't implemented yet, though they will be easy to do.
Christopher James Huff
Date: 15 Dec 2000 17:16:59
Message: <3A3A978C.C48AA29C@faricy.net>
Doesn't it also bend light away from the center of the flame? IIRC
Date: 15 Dec 2000 18:38:55
Message: <chrishuff-690D8A.18395515122000@news.povray.org>
In article <3A3A978C.C48AA29C@faricy.net>, David Fontaine
The different densities will cause the ior to be different, refracting
light...maybe not always away from the center. However, this is variable
ior, a pretty difficult and processor-intensive effect.
Also, I don't know how much of an effect it would have...it could easily
be barely noticeable. You can often see shadows from the "turbulence" of
a flame, but they aren't very distinct.
Back to the laser-beam experiment(I wish I had my laser pointer!), to be
thorough, you would need to use lasers of several different wavelengths
to get the actual color of scattering...actually, it might be better to
use a focused, high intensity white light instead of a monochromatic
laser...
Date: 16 Dec 2000 23:44:20
Message: <3A3C43D0.9E91475C@faricy.net>
give me a second to think about this...ok
Does a suspension refract? It's a suspension of smoke particles in air, and
the ior of the air is the same inside the flame.
Heat also refracts light, like the puddle-on-the-road mirage. So light would
bend away from the center of the flame, no?
Date: 17 Dec 2000 00:00:20
Message: <3a3c4864@news.povray.org>
would
Well, it's not really the heat that does it, just the density change caused
by the heat, but yes you're right, it will.  Because the air in the flame is
hotter, it will be less dense, so a ray of light going in to it should bend
away from the normal (if you were to draw the normal right through that is).
Lance.
http://come.to/the.zone
Date: 17 Dec 2000 00:10:34
Message: <3A3C4BC0.EF2E2F88@pacbell.net>
> would
Which will also vary depending on where you intersect the flame since
there are varying temperatures within the flame itself.
Date: 17 Dec 2000 00:14:04
Message: <3a3c4b9c@news.povray.org>
> > would
caused
flame is
bend
is).
That's right, which is why it's such a difficult thing to accurately model.
The other thing that makes it hard is that because it isn't a solid object,
the changes in density aren't as black and white (which means neither is the
normal)... I have no idea how someone would go about doing it perfectly.
Lance.
Date: 17 Dec 2000 00:25:56
Message: <3A3C4F57.B8668476@pacbell.net>
As it is with many things in the 3D graphic industry. If you can't model
it with real world physical attributes you fake it so that it at least
appears like it was. Unless you goal is academic it probably doesn't
matter anyway since the viewer is more concerned about the results than
the methods used to achieve it.
Date: 17 Dec 2000 00:29:04
Message: <3a3c4f20@news.povray.org>
Yes that's right.  I made an image today that is a bit along those lines...
Lance.
