POV-Ray : Newsgroups : povray.general : Flower power Server Time
4 Oct 2024 18:13:05 EDT (-0400)
  Flower power (Message 1 to 10 of 24)
Subject: Flower power
Date: 22 Oct 2003 02:41:24
Message: <3F962693.84387F65@Rapidnet.com>
Does anybody know how to design a flower using an IsoSurface? (Is this
even possible?)
I only need the flower itself, not the stem.
Anthony D. Baye.
Subject: Re: Flower power
Date: 22 Oct 2003 09:24:36
Message: <3f968514$1@news.povray.org>
"Anthony D. Baye" <ban### [at] Rapidnetcom> wrote in message
news:3F962693.84387F65@Rapidnet.com...
> even possible?)
How elaborate a flower? Unrealistic daisy is simple. Realistic rose much
more difficult. At least from what I'm thinking it would be.
The daisy could be a radial pattern, like so:
function {
 pattern {
  radial
  scallop_wave frequency 6 // shape and number of petals
  rotate 90*x
Then used as:
isosurface {
 function {
  (x*x+y*y+z*z) // sphere shape
  FlowerPattern(x,y,z)
 contained_by {
  box {<-1,-1,-0.1>,<1,1,0.1>} // middle slice
        spherical
            color_map {
                [0.75 color rgb <1,1,1>]
                [0.8 color rgb <1,1,0>]
Bob H.
http://www.3digitaleyes.com
Date: 22 Oct 2003 17:41:19
Message: <3F96F97F.FB04E35D@Rapidnet.com>
I was thinking, like a rose or something.
                                            Anthony D. Baye
> > even possible?)
> function {
>  pattern {
>   radial
>   rotate 90*x
> Then used as:
> isosurface {
>  function {
>  contained_by {
>     pigment {
>         spherical
>             color_map {
> Bob H.
Date: 22 Oct 2003 20:08:42
Message: <3f971c0a$1@news.povray.org>
news:3F96F97F.FB04E35D@Rapidnet.com...
Suspected so, and although maybe there's some way to cobble together some
patterns I would expect a mathematical formulation could ultimately be the
answer you're looking for.
I'm probably not going to be the one who might provide that, sorry. I did
get an ugly rose-like thing using the onion pattern, having frequency of 4
and scaled larger in one direction; also turbulated a little.  :-)
I had thought this might be something already done by someone before but I
sure can't locate anything concerning a isosurface flower. I suppose I'm
thinking of meshes.
Bob H.
Date: 22 Oct 2003 20:33:09
Message: <cjameshuff-EEBD5F.20310222102003@netplex.aussie.org>
In article <3f971c0a$1@news.povray.org>,
> thinking of meshes.
I did this a *long* time ago, when I was first playing around with
isosurfaces. It was basically an extremely distorted sphere function,
and looked a bit like a fat rose. A mesh certainly seems like a better
choice, however.
http://tag.povray.org/
Date: 22 Oct 2003 23:48:22
Message: <MPG.1a00fb8641b5c8e6989901@news.povray.org>
In article <cja### [at] netplexaussieorg>,
cja### [at] earthlinknet says...
> > thinking of meshes.
> choice, however.
In theory:
http://mathworld.wolfram.com/StarrRose.html
However, since they don't actually provide the equations for it, but
simply assume you know how to derive it from the 2D calcs in:
http://mathworld.wolfram.com/Rose.html
It isn't very helpful. Especially since I can't figure out what 'a' needs
to be or do to make Rose calcs work right either....
In my case I am trying to do something like:
N = 5 * rnd
vdelta = 2 * PI * rnd
vector = a * sin(N * vdelta)
X = cos(vector) * 30
Y = sin(vector) * 30
The problem is all I get is a dang circle... It is driving me batty. If
it was for something in POV, it would be driving me even more nuts. But
man would the StarrRose make a real nice Isosurface. Sigh...
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 23 Oct 2003 02:04:26
Message: <KwnOiDA022l$EwP5@econym.demon.co.uk>
>N = 5 * rnd
I think that N should be a constant (it's the number of petals or half
the number of petals depending on whether it's odd or even) and X and Y
should be cos(vdelta)*vector and sin(vdelta)*vector. "a" is a scaling
factor, the maximum radius of the whole shape
So:-
#version 3.5;
global_settings {assumed_gamma 1.0}
camera {location  <0,0,-10> look_at <0,0,0> angle 50}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#declare rnd=0;
#declare N = 5;
#declare a=3;
#while (rnd < 1)
  #declare vdelta = 2 * pi * rnd;
  #declare vector = a * sin(N * vdelta);
  #declare X = cos(vdelta) * vector;
  #declare Y = sin(vdelta) * vector;
    sphere {<X,Y,0>,0.2 pigment {rgb <1,1,0>}}
  #declare rnd = rnd + 0.001;
If we bung the significant bit "vector = a * sin(N * vdelta)" into an
isosurface it looks like this "a * sin(N * f_th(x,z,y))", which doesn't
do anything useful on it's own but suggests something like this:-
#version 3.5;
camera { location  <-1, 1, -6> look_at <0, 0, 0> angle 50}
background {rgb 1}
#include "functions.inc"
#declare n = 5;
#declare a = 2;
isosurface {
  function { a * sin(n*f_th(x,z,y)) * f_sphere(x,y,z,a) + 0.1}
  max_gradient 20
  contained_by{sphere{0,a}}
  pigment {rgb .9}
  finish {phong 0.5 phong_size 10}
Date: 23 Oct 2003 02:04:29
Message: <KwmOyHAw32l$EwvN@econym.demon.co.uk>
That could be made a little more realistic, like:-
#version 3.5;
camera {location  <-1,0,-2> look_at <0,0,0> angle 50}
background {rgb 1}
light_source {<-10, 10, -30> color rgb 1}
#declare FlowerPattern =
function {
 pattern {
  radial
  rotate 90*x
isosurface {
 function {
  (x*x+y*y+z*z*20) // sphere shape
  + f_noise3d(x*6,y*6,0)*0.5
 contained_by {
  box {<-1,-1,0>,<1,1,0.4>}
 open
 max_gradient 20
   cylindrical
   color_map {
     [0.2    color rgb <1,0.7,0.7>]
     [0.25  color rgb <1,1,1>]
   rotate x*90
Date: 23 Oct 2003 08:40:01
Message: <web.3f97cb44a022f3b88062416c0@news.povray.org>
Patrick Elliott wrote:
>In theory:
You can extend 2D polar functions to 3D in a variety of ways.  One is via
spherical products.
See:
http://news.povray.org/povray.binaries.images/32476/
for a few examples.  I use Ingo's "param.inc" and turn everything into
meshes, since it's faster, but you could also use the "parametric" object
from POVRay.
I don't know if this will give you what you want, but it does give some
rather interesting "3D mathematical flowers."
Dave Matthews
Date: 23 Oct 2003 12:41:45
Message: <3F9804C7.2CC33998@Rapidnet.com>
Does anyone know where I might find a dxf or obj model of, say, a
lotus?  I don't understand half of the math that was just thrown around
here, and I can't afford the one patch modeller I've been able to find
for the Mac.
A.D.B
> even possible?)
> Anthony D. Baye.
