POV-Ray : Newsgroups : povray.general : Straight-on wide camera Server Time
10 Sep 2025 17:22:25 EDT (-0400)
  Straight-on wide camera (Message 1 to 6 of 6)
Subject: Straight-on wide camera
Date: 15 Jun 2002 23:15:53
Message: <3D0C0233.7050902@spamthis.com>
I need a camera that will be able to render to a wide image (say
400x100) and not have any distortions, just be straight-on to the image.
Is there a setting to do this?  Appologies if my description isn't very
good.
I have been playing with the various projection types, and haven't been
able to find one that does what I'm looking for, or possibly I have just
blindly skipped over what I need.
Kevin
Subject: Re: Straight-on wide camera
Date: 15 Jun 2002 23:24:36
Message: <pan.2002.06.15.22.24.59.596412.1173@mac.com>
> good.
To render at that aspect ratio, try setting right to x*1 and up to y*0.25.
For the no distortion, including perspective distortion, you need an
orthographic camera. This means the camera rays will be parallel, not
spreading out as with the other types, but you will need to size the right
and up vectors to the desired camera view area, just keep them in a 4/1
ratio.
POV-Ray TAG e-mail: <chr### [at] tagpovrayorg>
WWW: http://homepage.mac.com/chrishuff/
Date: 16 Jun 2002 00:38:03
Message: <3d0c162b$1@news.povray.org>
Well, that depends on what kind of distortion, or what you're considering
"distortion" to be. You might find that a vertical cylindrical camera works
well, or maybe a panoramic one. Whatever kind you use, it's important to set
up the camera so that it matches the image's aspect ratio, to avoid
stretching.
 - Slime
[ http://www.slimeland.com/ ]
Date: 16 Jun 2002 11:39:32
Message: <3d0cb133@news.povray.org>
AFAIK ultra_wide_angle and panoramic are precisely designed for very wide
images. You should try them (try with different values for 'angle' until
it looks good).
Date: 16 Jun 2002 16:37:56
Message: <3D0CF648.3070702@spamthis.com>
> it looks good).
I have tried both ultra_wide_angle and panoramic, and personally I dont
like playing with the angle value trying to find what looks good, its a
waste of time. But the orthographic with the right and up values seems
to work good, I just have to narrow down the values so it fits how it
needs to. But otherwise, its what I was looking for with the parallel
rays instead of originating from a point, before I didn't know about
changing the up and right values like that (dont think its mentioned in
the manual, and I've never used orthographic before).
All in all, thanks everyone.
Kevin
Date: 17 Jun 2002 01:32:17
Message: <3D0D7386.2020905@spamthis.com>
> ratio.
Just on a final note to this thread, for anyone using it now or in the
future as reference, the aspect ratio is right:up, so since mine was
400x100, a 4:1 ratio, it was right x*4; up y*1, and then I have modified
those to get the proper "zoom" of the camera, but the ratio must be kept
4:1, so it can be modified to say, 100:25.
Kevin
