POV-Ray : Newsgroups : povray.general : Some help here please Server Time
15 Jun 2026 05:29:02 EDT (-0400)
  Some help here please (Message 1 to 3 of 3)
Subject: Some help here please
Date: 14 Mar 2002 18:51:01
Message: <3C913766.4050606@gates.com>
Hi all I need some help making some shapes,
I'm trying to kane an octahedron without taking a box and cutting off
edges, as I later want to make a regular dodecahedron and an icosahedron.
I finally found the prisim and it makes good stuff for other things but
i'm still new and cant find how to make the shapes above thanks for the
help!
this is what I have to do ?  but remember i'm new!
#declare cutter =
box {
<2.1,2.1,2.1>
<-2.1,-2.1,-2.1>
pigment {Green}
translate  <0,3.5,0>
difference {
box {
<2,2,2>
<-2,-2,-2>
pigment {Green}
object {cutter  rotate x*45}
object {cutter  rotate x*-45}
object {cutter  rotate x*45 scale -1}
object {cutter  rotate x*-45 scale -1}
object {cutter  rotate z*45}
object {cutter  rotate z*-45}
object {cutter  rotate z*45 scale -1}
object {cutter  rotate z*-45 scale -1}
Subject: Re: Some help here please
Date: 14 Mar 2002 19:22:25
Message: <3c913ec1$1@news.povray.org>
Here's the easiest way.
Find the corners of every polygon in your shape. You can do this with trig
or find the corners in a web reference. For each polygon, make triangles
from the center to each edge of the polygon. Put these triangles into a mesh
{} statement and you are done.
 -Shay
"Flaming Monarch" <fla### [at] gatescom> wrote in message
news:3C9### [at] gatescom...
Date: 14 Mar 2002 20:28:57
Message: <3C914E5A.4050303@gates.com>
hmmm I havent taken trig yet
so Ill look on the internet for that
>  -Shay
