POV-Ray : Newsgroups : povray.general : real world size Server Time
23 Apr 2026 18:21:22 EDT (-0400)
  real world size (Message 1 to 10 of 10)
Subject: real world size
Date: 2 Dec 2001 14:22:35
Message: <3C094B8B.7A0C066D@melbpc.org.au>
Hi all,
This has probably been asked before, but how large a real world
environment can can be simulated in POV.
I want to do a planetary system, showing, as near as possible, real
scale distances and body sizes.
eg. maybe 0.1 POV unit = 1 kilometer.
I know there can be work arounds using forced perspective, which I have
used before, but I want to try something different.
Thanks Alex.
  ,-._|\  Alex McMurray
 /  Oz  \ ale### [at] melbpcorgau               Melbourne PC User Group.
 \_,--.x/ Melton. Vic.  3337                     Australia
       v
Subject: Re: real world size
Date: 2 Dec 2001 14:38:41
Message: <3c0a8341$1@news.povray.org>
POV-Ray should be able to handle it. If distances start getting too big,
just decrease your scale.
You should know, though, that if you place things at the correct positions
and size, they'll be so small and far apart from each other that if you can
see one of them, you can't see any of the others, except for the sun. Just
think about how small jupiter and saturn and other planets look from earth.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 2 Dec 2001 15:31:27
Message: <3c0a8f9f$1@news.povray.org>
As Povray uses floatingpoint algorithms, it shouldn't your problem, to choose
the right scale ...
The problems will arise, if you have different sized objects, that hafe sizes
in different orders ...
That means:
It is perfectly OK, to compute everything with 10^5 units...
Say you have one planet, size 5000, distance 10000000, and another planet,
size 5500, distance= planet1+500 ...
should make no big problems ...
/BUT:/
If you choose to create structures on planet2, that have the size of 0.1
units, you will get accuracyproblems as in floatingpoint aritmethics they
will probably cancel out with the distance of which is a number, 10^8 times
higher. This alone maybe won't make the problem, but often there are
calculations, that involve solving of high-order equations(x^2 , x^4 or even
x^6 ...). Then the power wil raise to the double (10^16), or even more, and
then even a double-float-number is no longer able to hold these values ...
... of course, it can stre numbers like, maybe, 10^54 or 10^55... but in
these regions there is no longer any difference between 10^54+1 or 10^54+2
... they will be the same...
So your problem shouldn't be how many POV-Units is one kilometer, but
instead: What is the largest number you will use, and what is the highest
accuracy, you need...
hence, it should be perfectly possible, to scale a complete scene by a
factor, maybe 10^20, to make it bigger, or by 10^-20 to make it smaller ...
As long as the complete scene gets scaled (including cameras ligths and
everything) there shouln't any big difference ...
I hope this hole story makes sense to you...
Maybe someone else can explain better ...
Jan Walzer <jan### [at] lzernet>
Date: 2 Dec 2001 15:50:17
Message: <3C0A949F.A64D431B@hotmail.com>
<snip>
positions
> - Slime
If the planets are aligned, and the camera angle is small you should be
able to get a bunch of planets in one picture.
Dan Johnson
http://www.geocities.com/zapob
Date: 3 Dec 2001 14:18:06
Message: <3C0BCFD4.ED845969@aol.com>
It seems like this would work, but for some reason it doesn't. If you make
a sphere with a radius of 400,000 units with an ambient value as high as
you like, and place yourself 93 million units from it, you will not be able
to see it, as you would the sun from the earth. I don't know if it is an
internal math thing in POV-Ray or what, but I know that it is ture. Try it.
Date: 3 Dec 2001 15:07:44
Message: <3c0bdb90$1@news.povray.org>
able
it.
I've had problems with this before, it's just a matter of scaling, use a
larger base scale
Try this example which uses the sun, moon and earth at their proportional
sizes and scaled using 'scl'
with scl=1, the sun isn't visible, but with scl=1000 it is
-tgq
//start
global_settings{
  ambient_light 1
  assumed_gamma 1.0
  max_trace_level 100
#default{finish{ambient 0 diffuse 0.75}}
#declare Scl =1000
#declare ERad=6378.14/Scl
#declare SRad=695000/Scl
#declare SDis=149600000/Scl
#declare MRad=1737.4/Scl
#declare MDis=384400/Scl
//#declare lo = <-100,50,-200>;
//#declare la = <0,15,0>;
#declare lo = <0,ERad+1/1000/Scl,-SDis>;
#declare la = <0,0,0>;
  up y
  angle 25
  location lo
  look_at  la
// *******  L I G H T S  *******
#declare LB=sphere{0 SRad pigment{rgb <1,1,0>} finish{ambient 100}}
light_source {0
  rgb <1,1,1>
  looks_like{LB}
light_source {0
  rgb <1,1,1>
  translate <0,0,-SDis>
#declare E1=material{texture{pigment{rgb<0,0,1>}}}
#declare M1=material{texture{pigment{rgb<1,1,1>}}}
#declare CM=material{texture{pigment{rgb 0}}}
sphere{<0,0,-SDis> ERad material{E1} no_shadow}
sphere{<0,0,MDis> MRad material{M1} rotate -x*2 translate <0,0,-SDis>}
//end
Date: 3 Dec 2001 18:08:14
Message: <3c0c05de@news.povray.org>
bunch of dots you mean
PGP Public Key
Date: 4 Dec 2001 15:14:41
Message: <3c0d2eb1$1@news.povray.org>
You could get some planets larger than 1 pixel if the camera angle is
**VERY** small and the camera is **VERY** far away.  In other words, the
distances between the planets are negligible compared to the distance of
the camera.
Rick [Kitty5] <ric### [at] kitty5com> wrote in message
news:3c0c05de@news.povray.org...
be
> Rick
> Kitty5 WebDesign - http://Kitty5.com
> POV-Ray News & Resources - http://Povray.co.uk
> TEL : +44 (01270) 501101 - FAX : +44 (01270) 251105 - ICQ : 15776037
> PGP Public Key
Date: 4 Dec 2001 15:25:00
Message: <3c0d311c@news.povray.org>
make
as
able
an
Try it.
Yes, setting radius=4 and distance=930 works.  Multiply by 10 and
repeat, and it works, all the way up to 40,000 and 9.3 million.  Then it
just disappears.
Date: 4 Dec 2001 23:29:11
Message: <3C0DA319.44745904@iquest.net>
> make
> as
> able
> an
> Try it.
> just disappears.
Look at the relative size of the camera in your example scenarios.
In the first, the camera is huge in comparison to the objects (the camera is
planetary in size).
By the time you get to the last example, the scale of the camera in
relationship to the objects is now a very different matter.
