POV-Ray : Newsgroups : povray.general : How to get camera parameters from photohraph Server Time
31 Dec 2025 03:08:11 EST (-0500)
  How to get camera parameters from photohraph (Message 1 to 10 of 13)
Subject: How to get camera parameters from photohraph
Date: 2 Mar 2001 11:47:52
Message: <3A9FDEE5.4000802@hlavacek-partner.cz>
I have some photograph and I know coords of some its points in 3D space.
I need to calculate camera parameters, which will match the photograph,
so I can render some new object into it later.
Any ideas above it?
Thanks
Disnel
Subject: Re: How to get camera parameters from photohraph
Date: 2 Mar 2001 12:56:25
Message: <3a9fdec9@news.povray.org>
> in 3D space. I need to calculate camera parameters, which
> will match the photograph, so I can render some new object
> into it later.
> Any ideas above it?
More information needed...
What are you going to map the photograph onto?
Do you know the original co-ordinate of the camera?
How exactly have you planned to set up your scene?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 28)
/ Also visit http://www.povrayusers.org
Date: 2 Mar 2001 13:14:26
Message: <3A9FF32B.4070404@hlavacek-partner.cz>
I have two buildings with approx 20 levels
Not exactly, let we assume that no.
If I understand good the question, at the photo there are some other
buildings and I know their sizes and positions in my virtual world. Thus
I can create them and I need to setup camera to match their rendered
image with photo.
Disnel
Date: 2 Mar 2001 14:21:35
Message: <3a9ff2bf@news.povray.org>
> at the photo there are some other buildings and I know
> their sizes and positions in my virtual world. Thus I
> their rendered image with photo.
I tried something like that once. I don't know if there's a specific method
that can be used, all I can suggest is tweaking, tweaking and more
tweaking...
But anyway, in order to project a photo onto a scene you need a very special
mapping type. I suggest you have a look at my illusions include file. It can
project an image onto any surface in such a way that the image is not
distorted by perspective. If you need any help with it, don't hesitate to
ask me!
http://rsj.mobilixnet.dk/3d/illusion/illusion.html
Rune
Date: 2 Mar 2001 14:36:38
Message: <3AA0066F.5020803@hlavacek-partner.cz>
> tweaking...
What might help is some algorithm, which is able to compute cameras eye, target, angle
or right and left vectors
from pairs 3D vectors in model space and their apropriate 2D vector in images space.
> ask me!
Thanks, it looks good. But what I need now is to map photo as background
of whole image (this I've done, it was simple) and then match my
rendered image to photo (with this point I have serious problems...)
See p.b.i...
Disnel
Date: 2 Mar 2001 17:10:05
Message: <3aa01a3d$1@news.povray.org>
I have seen some software, that can extract a 3d image from a photo. I have
never used it and I would have to look for it again, but maybe it would
help?
C.J. POV User
PRSG (POV Ray Study Gallery)
http://hyperion.spaceports.com/~povstudy/
mailto:hou### [at] yaoocom
Disnel <dis### [at] hlavacek-partnercz> wrote in message
news:3AA### [at] hlavacek-partnercz...
method
> > tweaking...
target, angle or right and left vectors
images space.
special
can
to
> > ask me!
> See p.b.i...
> Disnel
Date: 2 Mar 2001 19:03:24
Message: <3aa034cc@news.povray.org>
"C.J." <hou### [at] yahoocom> wrote in message
news:3aa01a3d$1@news.povray.org...
have
> help?
Photomodeler Lite and Canoma are a couple:
http://www.programfiles.com/index.asp?ID=5681
http://www.programfiles.com/index.asp?ID=6490
Bob H.
Date: 3 Mar 2001 10:53:28
Message: <3aa11378@news.povray.org>
The few times I tried this I used a "try-and-see" method.
Select a regular object in the photo, make a pov wireframe cube and
rotate and scale until it matches the photo perspective. Repeat with a
second object to confirm camera position. A 10 frame animation of a
camera parameter helps.
Alf
"Disnel" <dis### [at] hlavacek-partnercz> wrote in message
news:3A9### [at] hlavacek-partnercz...
space.
photograph,
> Any ideas above it?
> Thanks
> Disnel
Date: 3 Mar 2001 14:53:56
Message: <3aa14bd4@news.povray.org>
Bob,
Have you used either? I always wondered what the output was like (a mesh
model?) and how well they work....
C.J. - POV User
Bob H. <omn### [at] msncom> wrote in message
news:3aa034cc@news.povray.org...
> have
> > help?
> Bob H.
Date: 3 Mar 2001 15:47:32
Message: <3aa15864@news.povray.org>
I tried both, yes.  Neither is something I can work with, I'm GUI impaired
Canoma isn't exactly what the original question would call for I suppose
because it maps images onto models you build.  Photomodeler actually uses a
camera perspective with the photos from it to build the models.  I managed
to make some Canoma things, although badly, but in Photomodeler I couldn't
get a antique telephone to become textured with the photos I made of it.
Got the points in enough I thought except it wouldn't apply a image to the
surfaces.  It's such a long process I called it quits pretty quickly instead
of dragging on and on with it.  Supposedly it does work right, main thing is
that it uses your camera lens properties as a guide to the end result.
Bob H.
"C.J. - POV User" <hou### [at] yahoocom> wrote in message
news:3aa14bd4@news.povray.org...
> Bob,
