POV-Ray : Newsgroups : povray.general : bounding box generation Server Time
17 Jul 2026 17:21:30 EDT (-0400)
  bounding box generation (Message 1 to 10 of 11)
Subject: bounding box generation
Date: 5 Jan 2001 13:17:31
Message: <3A561082.30E98818@Beccue.com>
Is there any way to have PovRay tell *me* what the bounding extents for
a particular CSG might be?  I have some object that someone designed for
me using Moray, and I want to know how big it is.
Thanks,
David
Subject: Re: bounding box generation
Date: 5 Jan 2001 13:19:37
Message: <slrn95c41s.crf.ron.parker@fwi.com>
MegaPOV's min_extent and max_extent might work, but you'll get some slop if
there are intersections or differences involved in the CSG.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 6 Jan 2001 10:48:45
Message: <3a573e5c@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: MegaPOV's min_extent and max_extent might work, but you'll get some slop if
: there are intersections or differences involved in the CSG.
  To be more precise, min_extent and max_extent return the coordinates of
the bounding box of the object, not the extents of the object.
  POV-Ray calculates automatically bounding boxes for most objects (with a
few exceptions). Mostly the bounding box corresponds to the extends of the
object itself, but sometimes it doesn't (mainly because it would be too
difficult to automatically calculate the exact extents of an object).
  So there's no way you can automatically get the optimal extents of an object.
The only solution is just to fine-tune by hand (eg. using a semi-transparent
box in the place of your bounding box to see what does it cover).
Date: 6 Jan 2001 11:16:27
Message: <3A5744A0.72A15988@skynet.be>
You could also 'scan' the object with the 'trace' function, in order
to get a closer result.
Fabien.
Date: 6 Jan 2001 11:28:11
Message: <3a57479b@news.povray.org>
Fabien Mosen <fab### [at] skynetbe> wrote:
: You could also 'scan' the object with the 'trace' function, in order
: to get a closer result.
  You get the risk of setting a bounding box that is a bit too small.
Date: 6 Jan 2001 17:39:01
Message: <3A579D69.CE37BC7B@faricy.net>
Simply use the last value that didn't intersect, rather than the first that
did. If you wanted to be really precise, you could make a bisection macro
too.
Date: 6 Jan 2001 18:21:07
Message: <chrishuff-ACEEEE.18224106012001@news.povray.org>
In article <3A579D69.CE37BC7B@faricy.net>, David Fontaine
> first that did. If you wanted to be really precise, you could make a
> bisection macro too.
There is still the risk of some small part protruding out into the space
between traces...but this method works for relatively "smooth" objects
without small scale points. For example, it wouldn't work well on a
piece of pine tree branch, or a sea urchin, but a computer monitor
should work fine.
Christopher James Huff
Date: 6 Jan 2001 23:58:31
Message: <3A57F65E.F7D7D242@faricy.net>
> should work fine.
There's just no satisfying you, is there? ;)
Date: 7 Jan 2001 15:39:20
Message: <3a58d3f8@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote:
: There's just no satisfying you, is there? ;)
  Perfectionism is the key to mastering POV-Ray.
Date: 7 Jan 2001 15:50:42
Message: <3A58D671.7F1283D0@skynet.be>
Being able to forget a little bit of perfectionnism is the key to
finishing IRTC entries before deadline ;-)
Fabien.
