POV-Ray : Newsgroups : povray.general : polygons or triangles Server Time
10 Oct 2024 18:27:16 EDT (-0400)
  polygons or triangles (Message 1 to 4 of 4)
Subject: polygons or triangles
Date: 13 Dec 2000 18:24:51
Message: <3A3804A6.36A052CC@gmx.de>
I think about a genaral problem: if I have a freeform-surface and I want
to devide it up into small faces, I often have the possibility to make
polygons (most faces then are quads) or triangles. Which way is the
better one ?
Subject: Re: polygons or triangles
Date: 13 Dec 2000 19:07:00
Message: <chrishuff-469B70.19075713122000@news.povray.org>
In article <3A3804A6.36A052CC@gmx.de>, chris <chr### [at] gmxde>
> better one ?
You can put triangles in a mesh, which can be much more efficient in
memory usage. Also, if you have more than one copy of the object, a copy
of a mesh will use the same data, saving even more memory, while a copy
of a union of polygons will copy *all* the data.
Christopher James Huff
Date: 14 Dec 2000 01:29:50
Message: <3A386840.67044BB7@gmx.de>
Thanks, but I thought of another problem.
If I devide my complex freeform-surface up into polygons (quads) or
trinangles and I want to render it (pov or another highquality
renderer), there is the problem of defining a "smooth" transition from
one element to the next, which is done with "spline"-patches, first (and
second?) derivative at the boundaries the same (I'm not a
math-expert..). I think, that both types (patches from quads or
triangles) give a little different aproximation of the
free-form-surface, but which one is the better one ?
Date: 14 Dec 2000 17:25:31
Message: <chrishuff-618F6A.17263014122000@news.povray.org>
In article <3A386840.67044BB7@gmx.de>, chris <chr### [at] gmxde>
I don't know what you are looking for...
Well, to start with, POV-Ray doesn't have a "quad" primitive, you will
have to approximate them with triangles or use polygons, so you can stop
talking in terms of quads.
You can use smooth_triangles, where you specify the normal of each
vertex of the triangle, and it is interpolated across the surface of the
triangle, but it doesn't actually do anything to the surface, it is
still perfectly flat.
Polygons don't allow you to specify vertex normals, and can not be used
in meshes.
You might be looking for bicubic patches (also called Bezier patches)...
In these, you specify a 4*4 grid of 16 points, and POV creates a curved
surface from this information. The surface really is curved, sort of
like a sheet of rubber, it doesn't just fake it with the normal(though
it is actually a triangle mesh internally). However, you can't use
bicubic_patch objects in meshes either, so your memory requirements will
go up, possibly *way* up, depending on what you are doing.
