POV-Ray : Newsgroups : povray.general : rotation question Server Time
18 Jul 2026 01:29:32 EDT (-0400)
  rotation question (Message 1 to 5 of 5)
Subject: rotation question
Date: 21 Sep 2000 16:35:48
Message: <39ca7124@news.povray.org>
Can anyone help?
If I have a sphere, and touching at any one point on that sphere I have
another object, is there any way I could control the rotation of that
object relative to the axis of the sphere's normal at that point?
For the image I'm working on, I have the radius of the sphere, the angle
of the object from the 'north-pole' of the sphere, and the angle around
the sphere measured from the positive x-axis.
Subject: Re: rotation question
Date: 21 Sep 2000 16:51:03
Message: <39ca74b7$1@news.povray.org>
In article <39ca7124@news.povray.org> , "sacrofts"
<sac### [at] tinyonlinecouk> wrote:
> Can anyone help? If I have a sphere, and touching at any one point on that
> sphere I have another >object, is there any way I could control the rotation
> of that object relative >to the axis of the sphere's normal at that point? For
> the image I'm working on, I have the radius of the sphere, the angle of the
> object from the 'north-pole' of the sphere, and the angle around the sphere
What you are looking for is the vaxis_rotate function.  You find it
explained in the documentation under:  Scene Description Language > Language
Basics > Vector Expressions > Vector Functions
The parameters in your case would be as follows (I think):
    vaxis_rotate(point, normal, degrees)
     Thorsten
Date: 23 Sep 2000 03:45:55
Message: <39cc5fb3@news.povray.org>
Many thanks, found it.  worked a treat
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:39ca74b7$1@news.povray.org...
on that
rotation
point? For
of the
sphere
Language
>      Thorsten
Date: 27 Sep 2000 21:22:30
Message: <39D29D62.7F31C366@ij.net>
sacrofts wrote:
> Can anyone help?
> If I have a sphere, and touching at any one point on that sphere I have another
object, is there any way I could control the rotation of that object relative to the
> For the image I'm working on, I have the radius of the sphere, the angle of the
object from the 'north-pole' of the sphere, and the angle around the sphere measured
	In line with KISS, presuming your main sphere is a 0,0,0 then put your
attached object there also and do its rotation there. Then rotate to the
desired orientation, then translate it to the attachment point. If the
main sphere is rotating, translate to the rotated position. (One of
those steps is likely out of order, it always is on my first cut.)
Date: 28 Sep 2000 18:24:42
Message: <39d3c52a@news.povray.org>
Many thanks!
That did just the trick,  I didn't realize how important it is to get
the rotations in the right order!!
the vaxis_rotate that was also suggested to me came in useful elsewhere.
Steve
the
