POV-Ray : Newsgroups : povray.general : Quickest way for cubes Server Time
15 Jan 2026 10:30:35 EST (-0500)
  Quickest way for cubes (Message 1 to 6 of 6)
Subject: Quickest way for cubes
Date: 21 Sep 2000 09:28:03
Message: <39CA0BA5.887B468D@my-dejanews.com>
Say I want to have a solid 3D object made up of thousands of cubes.
Is the best way to do this with 12 meshes, a cube, or what?
Just how worse are the superellipsoids, and how much better are the
improvements to them?
Subject: Re: Quickest way for cubes
Date: 21 Sep 2000 09:41:45
Message: <39ca1019@news.povray.org>
Greg M. Johnson <gre### [at] my-dejanewscom> wrote:
: Say I want to have a solid 3D object made up of thousands of cubes.
: Is the best way to do this with 12 meshes, a cube, or what?
  You mean 12 triangles?
  As far as I know the most efficient way is to create all the triangles
into one mesh (I mean that if you want 1000 cubes you don't make a mesh
made of 12 triangles and then copy it 1000 times, but instead you put
all the 12*1000 triangles into one mesh).
  You will be surprised how fast this mesh renders, no matter if it has
12*1000 triangles or 12*1000000 triangles (well, the parsing time gets
longer, of course, but that's not so important here; the parsing time
gets longer anyways, no matter what method you use).
  If the mesh must be solid (ie. useable in CSG) you'll have to use MegaPov
for that.
: Just how worse are the superellipsoids, and how much better are the
: improvements to them?
  Superellipsoids are very slow. I don't know if megapov has any
improvements in its speed, but it's always very slow (much slower than
a box and very much slower than a mesh if you have a lot of copies of it).
Date: 21 Sep 2000 09:57:32
Message: <39CA1289.419800F2@my-dejanews.com>
Thanks, my render is now up to 14 minutes per 320 x 240 frame and I probably
have less than 8000 cubes so far...
I vaguely remember posting about how people had improved the superellipsoid,
hoping they'd made it as fast as a cube! Perhaps with about 40-200  triangles I
could make a sort of rounded-cube approximation.
(BTW--did you see my old reply to you re: computing volume?)
> for that.
Date: 22 Sep 2000 02:52:36
Message: <39cb01b4@news.povray.org>
Greg M. Johnson wrote in message <39CA1289.419800F2@my-dejanews.com>...
superellipsoid,
triangles I
A superellipsoid will never render as fast as a cube.  The fastest primitive
to render is an axis-aligned box, with non-axis-aligned boxes, spheres, and
meshes also being very fast.
Mark
Date: 27 Sep 2000 21:07:41
Message: <39D299E8.FF75A250@ij.net>
	Try them and compare. Superels definitely take longer to render even if
you set the varibles to make them perfect cubes. BTW: Wouldn't a cube be
six meshes? Off hand, a cube is a simple, well-defined shape that traces
quickly so I'd guess that would be quickest.
If you quit smoking now you can live long enough
to get Altzheimer's.
           -- The Iron Webmaster, 24
Date: 27 Sep 2000 21:17:10
Message: <39D29C21.110CB83E@ij.net>
	As it is defined as a superel each point must be evaluated with the
squares of the point and solved for the normal and such. A cube is just
a plane not needing the extra steps.  There is your time difference. You
can't beat that except by pretesting for the unexpected condition that
the constants make it a cube and then treating it as a cube. So making
it a cube in the first place is expected of the user.
Modern superstition: If we forget the horrors of the Nazis
they will rise again.
	-- The Iron Webmaster, 135
