![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In POV 3.5 I would like to see the following implementations:
- True wavelength-dependent interference
- Diffraction
- Optical birefringence
- Polarization and polarizing filters, including ior-dependent polarized
reflection
- Non-uniform ior for object interiors
- Differentiation between absorption and interference filtration
<G> >;)
David Fontaine <dav### [at] faricy net> ICQ 55354965
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> - Diffraction
> reflection
...and a partridge in a pear tree.
Time for you to learn how to write your own patches, David.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 09 Aug 2000 14:37:37 -0500, David Fontaine <dav### [at] faricy net>
>reflection
The main difficulty with the above features is conversion from rgb to
spectrum space. Simply said, it's impossible. It can be faked in a lot
of ways like rgb -> hsb conversion but they will not come close to the
real thing as spectra are usually very complex with emission and
absorption lines and regions and so on.
Now, if all colors were represented in spectrum space, things would be
much easier. I don't think users will love tweaking such colors,
though :)
>- Diffraction
Diffraction is tricky. I don't think it's impossible but it would
probably require insane render times (unless someone comes up with a
algorithm of following a wave front which does not require extensive
Monte Carlo sampling).
This has been discussed more than enough so I'll just skip it.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
[snip]
I was of course only joking, I selectively listed the most
computation-intensive real-world properties and the ones that would require
massive restructuring of the entire POV code.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
David Fontaine <dav### [at] faricy net> wrote:
: In POV 3.5 I would like to see the following implementations:
: - True wavelength-dependent interference
: - Diffraction
: - Optical birefringence
: - Polarization and polarizing filters, including ior-dependent polarized
: reflection
: - Non-uniform ior for object interiors
: - Differentiation between absorption and interference filtration
It's easy to say, but how easy to implement? You are free to post your own
ideas about the algorithms that will implement those.
And by the way, about the non-uniform ior in objects interiors:
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#variableior
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3991B301.80EBA665@faricy.net>, David Fontaine
> - Diffraction
> reflection
You forgot these:
- True displacement mapping for all objects, using curved rays
- Relativistic effects, with adjustable light speed
- Differential ray tracing
- Custom BDRF functions
- 5x faster rendering and parsing
Christopher James Huff - Personal e-mail: chr### [at] mac com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 10 Aug 2000 08:17:43 -0500, Chris Huff <chr### [at] mac com>
This has already been implemented in another raytracer so it's not
that impossible.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <10n5ps4sjuvnbl6398bihmen322htdppue@4ax.com>, Peter Popov
> that impossible.
So have some of the other things, but they would all require large
changes in the architecture and source code. Adding it to POV would
probably be impossible...it would probably be easier to write a new
renderer that supports those things.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
there is a solution for this right? getting a computer that is 5X
faster :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <399311B7.AAB467A0@yahoo.com>, ryan constantine
> faster :)
But that costs more than a POV upgrade. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
