POV-Ray : Newsgroups : povray.general : Doing data-visualization...But HowTo do it ??? Server Time
26 Mar 2026 07:54:55 EDT (-0400)
  Doing data-visualization...But HowTo do it ??? (Message 1 to 10 of 10)
Subject: Doing data-visualization...But HowTo do it ???
Date: 16 Jul 2000 16:53:53
Message: <397220e1@news.povray.org>
I'm about to write some macros, for making some statistics with
povray ...
Creating diagrams with lines and bars semm quite easy, also for
2D-Diagrams showing surfaces ...
But how can I create a pie-chart ???
I don't want do do it with simple texturing on a cylinder, using
a radial gradient, but I want to have all segments of my pie as
own segments, to move them (later).
But how can I create all the pie-pieces ???
I thougt about an Isosurface, but that's quite slow and not
POV3.1 compatible...
Than I thought, using a CSG-operation of a cylinder and a
well-scaled/rotated cube, but this would be quite complicated to
compute, and will only work if the piece has a bit more than 0
degrees and a bit less than 180 degrees ...
Currently I think the isosurf would be the easier alternative,
but there must be another way of doing this ...
Can't I limit a cylinder to some degrees to use ???
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Subject: Re: Doing data-visualization...But HowTo do it ???
Date: 16 Jul 2000 17:32:52
Message: <39722a04@news.povray.org>
In article <397220e1@news.povray.org> , "Jan Walzer"
Use two planes instead of a cube and a CSG intersection.  If you place the
cylinder and planes at the origin, you can use a "rotate" attribute along
the cylinder axis to create pie pieces with the planes.  This will allow you
to create pieces in any size with the size measured in degrees.
      Thorsten
Example (not tested):
intersection
    cylinder
        x, -x, 10
    plane
        y, 0
    plane
        -y, 0
        rotate 60*x
    texture
        pigment
            color red 1
Date: 16 Jul 2000 17:36:37
Message: <39722AE6.148CF62@schunter.etc.tu-bs.de>
IMO CSG-difference would be the simplest
Example:
difference {
   cylinder { 0*z, 1*z, 10 }
   plane { x, 0 rotate end_angle*z }
   plane { x, 0 rotate start_angle*z inverse }
Date: 16 Jul 2000 17:48:07
Message: <chrishuff-4C2D1E.16483616072000@news.povray.org>
In article <397220e1@news.povray.org>, "Jan Walzer"
An isosurface seems a bit extreme for this...just use an intersection or
difference with a cylinder and 2 planes to create a wedge shape. You
could then translate the wedge away from the axis to separate the
"slice" from the others.
A macro like this should work: (untested!)
#macro PieWedge(minAngle, maxAngle, Radius, Thickness, Separation, Tex)
    difference {
        cylinder {< 0, 0, 0>, < 0, Thickness, 0>, Radius}
        plane {-x, 0 rotate y*(maxAngle - minAngle)/2}
        plane {x, 0 rotate -y*(maxAngle - minAngle)/2}
        texture {Tex}
        translate z*Separation
        rotate y*(minAngle + (maxAngle - minAngle)/2)
The parameters:
minAngle and maxAngle specify the angles where the wedge begins and
ends; Radius specifies the radius of the wedges, Thickness specifies the
height of the wedge, Separation controls the distance the wedge is moved
from the center, and Tex is the texture.
Date: 16 Jul 2000 18:04:03
Message: <chrishuff-82F3B1.17043216072000@news.povray.org>
In article <chrishuff-4C2D1E.16483616072000@news.povray.org>, Chris
That macro won't work with angles >180 degrees though...try a difference
of an intersection of 2 planes for those cases, something like
this:(also untested!)
    difference {
        #if(maxAngle - minAngle > 180)
            intersection {
        #else
        texture {Tex}
Basically, this chops off the sides if the wedge angle is <=180, but
removes a wedge shape if it is >180. You may want to account for angles
of exactly 180 degrees, they may cause cooincident surface problems, but
it would be easier to just move one of the planes by 0.0001 or so...and
there may not be any problem.
Date: 16 Jul 2000 18:05:54
Message: <3972317D.CFBC8723@yahoo.com>
another alternative is to use an SOR.  Surface Of Revolutions can be
spun for partial circles.  the surface to be revolved would just be a
straight line.  you'd have to make several, one for each pie chart
member, and then rotate and/or translate accordingly.
>     difference {
>         texture {Tex}
> #end
> The parameters:
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Date: 16 Jul 2000 18:24:28
Message: <chrishuff-D2E6FA.17245716072000@news.povray.org>
In article <3972317D.CFBC8723@yahoo.com>, ryan constantine
Where did you hear that?
Anyway, it isn't true. SOR's always revolve by a full 360 degrees, and
the same goes for lathes. I even double-checked in the manual and the
source code, to make sure. Maybe you are thinking of some other
program...
Date: 17 Jul 2000 02:38:18
Message: <3972A994.91541275@yahoo.com>
> program...
i may be.  oops.
Date: 17 Jul 2000 12:20:31
Message: <8F74BAB77seed7@204.213.191.228>
Would be a nice option though
Ingo
Date: 17 Jul 2000 13:12:21
Message: <chrishuff-D7D2BA.12125117072000@news.povray.org>
In article <8F74BAB77seed7@204.213.191.228>, ing### [at] homenl (ingo)
Wouldn't it be a bit redundant, when you can do the same using a simple
CSG like the one in my macro, just by replacing the cylinder with a
sor/lathe object?
You could even make the macro take an object as a parameter, so it would
work with any object centered on the origin.
