POV-Ray : Newsgroups : povray.general : Help on blobs: speediest way for opening? Server Time
16 Jan 2026 03:44:49 EST (-0500)
  Help on blobs: speediest way for opening? (Message 1 to 8 of 8)
Subject: Help on blobs: speediest way for opening?
Date: 5 Apr 2000 13:17:16
Message: <38EB7419.51B18DD8@my-dejanews.com>
I have developed a blob figure of a human.  I made a mouth by flattening
a sphere and giving it a big negative strength.
The problem is that this technique gives a ridiculously long render
time.  Most of the render time is spent on the mouth, where perhpaps a
dozen components (spheres) overlap.
What is the quickest-rendering ways to make a simple mouth on a blob
character?
a) negative blob components?
b) CSG?
c) Make a different-textured region show up (and is there a quick way to
do this)?
d) ?
Subject: Re: Help on blobs: speediest way for opening?
Date: 5 Apr 2000 16:04:01
Message: <38EB9BA6.FE8D6181@pacbell.net>
> character?
> b) CSG?
> do this)?
 d) H.E. Day uses manual bounding in all of his major Blob projects
    to help speed up rendering.
Date: 5 Apr 2000 16:38:29
Message: <38EBA340.DB6AE935@my-dejanews.com>
What the heck is that?
I've tried code like this before ages ago and gotten insulting messages from
pov that say things like:
  "I removed your unnecessary bounding box."
If you're familiar with the concept, what would I bound and with what:
    a) spheres just barely larger than every one of my 150+ components?
    b) a big cube larger than the arms will ever reach?
> > character?
> > b) CSG?
> > do this)?
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 5 Apr 2000 21:34:59
Message: <38EBE915.966CC9C2@pacbell.net>
You will have to use a switch -MB to turn automatic bounding off. If
you don't POV-Ray will ignore your attempts at manual bounding and
supply it's own which are not always optimized in complex operations.
I would be lying if I said I knew what the optimum scenario is or which
method Mr. Day uses. Since he is the recognized blob master around here
you might wish to ask him yourself - Pov### [at] aolcom
Date: 6 Apr 2000 17:23:11
Message: <38ECF290.3A82ED49@peak.edu.ee>
Actually, I'd use the -UR switch to disable unnecessary bounds removal (which is
what the 'insulting message' is referring to). If you use -MB you either have to
bound each and every object manually or suffer a severe speed penalty.
Margus Ramst
Date: 6 Apr 2000 17:37:56
Message: <38ED02A0.389A5673@my-dejanews.com>
And for us mortals using Win98, how are the equivalents of these switches being
done?
> Margus Ramst
> Personal e-mail: mar### [at] peakeduee
> TAG (Team Assistance Group) e-mail: mar### [at] tagpovrayorg
Date: 6 Apr 2000 17:46:21
Message: <38ECF7FD.BF320AF5@peak.edu.ee>
> done?
Well, you can give command-line switches in the Windows version, too - from the
'Ini' button menu.
The equivalent ini options are:
Bounding=on/off equals +/-MB
Remove_Bounds=on/off equals +/-UR
See also the documentation about automatic bounding control.
Margus Ramst
Date: 3 Jul 2000 08:55:19
Message: <39608d37$1@news.povray.org>
Margus Ramst <mar### [at] peakeduee> schreef in berichtnieuws
38ECF7FD.BF320AF5@peak.edu.ee...
switches being
> > done?
from the
> 'Ini' button menu.
<snip>
Or, you could press Alt-C and put them in the text box labeled command line
options. This way you don't have to switch to the INI to start a render.
     Frits van Bommel
"In the beginning the Universe was created. This has
made a lot of people very angry and been widely
regarded as a bad move."
