POV-Ray : Newsgroups : povray.general : Error message:points in polygon are not co-planar Server Time
14 Mar 2026 18:54:22 EDT (-0400)
  Error message:points in polygon are not co-planar (Message 1 to 9 of 9)
Subject: Error message:points in polygon are not co-planar
Date: 27 Jan 2000 08:13:30
Message: <38904479.13D97AE8@stud.uni-sb.de>
Hello!
I have the error message points in polygon are not co-planar, what means
co-planar ? (example), what can I do to make them co-planar?
Alex
Subject: Re: Error message:points in polygon are not co-planar
Date: 27 Jan 2000 08:51:57
Message: <38904d7d@news.povray.org>
robcad-user <alg### [at] studuni-sbde> wrote:
: Hello!
: I have the error message points in polygon are not co-planar, what means
: co-planar ? (example), what can I do to make them co-planar?
  It means that they are not located in the same plane.
  You could define your polygon with one of the components of all vectors
set to 0 and then rotate and translate it to its place.
Date: 27 Jan 2000 09:06:14
Message: <a1CQOMw9toTn7rInMKWRhzGuKbf6@4ax.com>
On Thu, 27 Jan 2000 14:13:30 +0100, robcad-user <alg### [at] studuni-sbde>
wrote:
>Hello!
>Alex
It means they are not in the same plane. A polygon is a flat shape and
all its points must lie in the same plane. I don't know what polygon
you're trying to render, if you post the snippet of code that POV
chokes at it would be easier to locate the problem.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 27 Jan 2000 18:18:20
Message: <3890D431.4F90F2F8@erols.com>
robcad-user wrote:
> Hello!
> means co-planar ? (example), what can I do to make them co-planar?
The message means that there is no plane that can contain all of the
points you gave for the object.  This happens for one of two reasons:
1) You actually tried to place all of the points such that they cannot
all lie in one plane.  For instance,
  polygon { 5,
    <-1,0,-1>,<1,0,-1>,<1,.1,1>,<-1,0,1>,<-1,0,-1>
will cause this error; three of the points lie in the y=0 plane, but the
third point is off-plane.
2) The other cause is that you tried to place them in a plane that is
at an angle to the coordinate axes, and rounding error has caused one
of the points to go out of the plane.
One work-around is to define the polygon so that it lies in one of the
coordinate planes; specifically, set one of the coordinate components
to zero in all of the points, and then move it into position with the
appropriate transforms.
The other work-around is to turn the polygon into a bunch of triangles,
which are not subject to this problem; needless to say, you can only use
this work-around if you are making a linear spline polygon.
Hope this helps,
John
Date: 27 Jan 2000 19:03:56
Message: <slrn891n0l.v8.ron.parker@parkerr.fwi.com>
On Thu, 27 Jan 2000 18:26:41 -0500, The Yodeling Veterinarian of the Alps wrote:
Are the Alps in that much need of veterinary care?  I wasn't
even aware that they qualified as an animal; I would have guessed
mineral.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 27 Jan 2000 19:09:18
Message: <3890E025.2015B11E@erols.com>
> mineral.
Actually I got it from a VeggieTales tape.  It sounded ludicrous
enough to be a good Usenet handle for one of my Netscape user
profiles.
ICQ: 46085459
Date: 27 Jan 2000 22:09:11
Message: <38910812.42909E40@fci.net>
Neato, those VeggieTales tapes, huh?  I think I'll try and get a Job with
BigIdea. :)
> > mineral.
> profiles.
> ICQ: 46085459
H.E. Day
Date: 27 Jan 2000 23:27:48
Message: <38911BD1.BD84B222@geocities.com>
Well...
You might have a shot there. Just remember that they focus on character,
emotion and movement. But I think your existing work would fit in nicely
with their Larry-Boy stuff.
> BigIdea. :)
> > > mineral.
> > profiles.
> > ICQ: 46085459
> H.E. Day
Subject: VeggieTales
Date: 28 Jan 2000 17:26:41
Message: <3892199A.A156448B@erols.com>
> with BigIdea. :)
If they're hiring when I retire from the Air Force I'll bee looking into
it as well.  I e-mailed them a while back, asking them which renderer
they used.  The reply said that at the time they were migrating from one
package to another.  I forget which apps were named, but neither of them
were POV-Ray :-(
Their web site has a job listing, and it looks like they want pretty
much the whole spectrum of workers (ie, CG artists, regular artists,
render wranglers, programmers, admin staffers, etc.).  They are *not*
looking for voice talent.
If you're wantin' a job, you have to submit a cover letter, resume, and
a demo-reel in VHS format, and be prepared to move to Lombard, Illinois
(Chicago area) once you are hired.
The stuff is at http://www.bigidea.com/company/careers/
[Follow-ups gone to p.o-t]
John
