POV-Ray : Newsgroups : povray.general : tanslucent textures Server Time
16 Jan 2026 15:55:31 EST (-0500)
  tanslucent textures (Message 1 to 3 of 3)
Subject: tanslucent textures
Date: 1 Dec 1999 05:05:36
Message: <3844F2ED.47E56907@gmx.net>
Is it possible to create translucent textures with povray, so I can see
that there is a lightsource behind an object without seeing the object?
Has someone  an idea how to do that, I couldn't figure it out yet. The
only way I see at the moment is the possibility of assigning a
lightsource to an object, but that feature you can't use working with
the moray 3.1 editor (as far as I know).
Thanks
Rainer
Subject: Re: tanslucent textures
Date: 1 Dec 1999 06:27:25
Message: <chrishuff_99-B3BA44.06273401121999@news.povray.org>
In article <3844F2ED.47E56907@gmx.net>, Rainer Ludwig
You can use a transparent texture and media. I would suggest an
unofficial version incorporating media method 2 or 3 for this, the
standard method can be very slow.
Or if the object is a patch object or infinitely thin, like a clipped
plane, you can use a patch which includes the double_illuminate patch,
like the Superpatch or UVPov.
But if you are using Moray, you will have to do some hand-editing to use
the patched versions.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 5 Dec 1999 07:34:47
Message: <384A5BE5.8FADCFD8@gmx.net>
Thank's for the tip, I've downloaded UVPOV and will try that one.
Rainer Ludwig
> Chris Huff
> Web page: http://chrishuff.dhs.org/
II*
