POV-Ray : Newsgroups : povray.general : CMKY Output Server Time
27 Mar 2026 09:02:55 EDT (-0400)
  CMKY Output (Message 1 to 10 of 13)
Subject: CMKY Output
Date: 21 Nov 1999 13:51:48
Message: <38383f44@news.povray.org>
Is there any possibility to set PovRay to output directly to an 32-bit CMKY
file rather than the usual 24-bit RGB format.
Thanks
Sergio
Subject: Re: CMKY Output
Date: 21 Nov 1999 14:09:20
Message: <3838430D.EC60AE1B@pacbell.net>
> Thanks
> Sergio
No.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 21 Nov 1999 15:03:12
Message: <38385000@news.povray.org>
Can someone add this? I know I could use it (for my yearbook).
Date: 21 Nov 1999 15:35:16
Message: <38385828.82819396@peak.edu.ee>
I don't think this would be practical, since AFAIK internally POV is built
around the RGB model. You could of course do RGB -> CMYK conversion in video
post, but there are other programs better suited for this. Good RGB -> CMYK
conversion is not a trivial matter, for one because the two models have quite
different gamut space.
Margus
Date: 21 Nov 1999 15:56:37
Message: <8Vs4OFyF8MYx7dpOF2K6izanTRkc@4ax.com>
On Sun, 21 Nov 1999 16:22:37 -0000, "Sergio" <ine### [at] esotericapt>
>Thanks
>Sergio
RGB to CMYK conversion is lossy and it requires a profile, and these
are platform-specific. So the answer is no, and it probably remain so
in the next version.
Peter Popov
ICQ: 15002700
Date: 21 Nov 1999 16:25:15
Message: <383862E8.6221EDD3@pacbell.net>
> Margus
  I see a lot of people asking the question in comp.graphics.misc about
convering RGB -> CMYK. Even the people experienced with the process and
can afford the software that does this type of conversion are not always
happy with the results.
  I would think it would be highly problematic to do this in POV-Ray and
get predictable results.
Date: 21 Nov 1999 18:21:39
Message: <38387F27.A7839479@peak.edu.ee>
Is there an echo in here? :)
Or did my post sound like I was claiming the opposite?
Margus
Date: 21 Nov 1999 18:32:26
Message: <383880B3.7C44846A@pacbell.net>
> Margus
No sir. I was merely supporting your statement. You see it's like if
one person say's to you that there is a red mark on your face you
might ignore that person. If every person you see for the rest of the
day tells you that there is a red mark on your face it's time that
you start believing them. For that reason I thought that I would
attempt to lend some weight to what you already said so that the
topic would not continue in a pointless manner.
Satisfied ?
Date: 21 Nov 1999 18:35:55
Message: <38388281.E713349A@peak.edu.ee>
Ken wrote:
> Satisfied ?
Of course.
I was simply afraid my argument had fallen victim to poor wording.
Margus
Date: 21 Nov 1999 19:17:37
Message: <38388ba1@news.povray.org>
Sergio <ine### [at] esotericapt> wrote ...
CMKY
> Thanks
> Sergio
No, but you could output to a PNG and use up to 16 bits per color (48 bits
total).  This could give better output for subsequent CMYK conversion
-Nathan
