POV-Ray : Newsgroups : povray.general : Stupid POV tricks Server Time
1 Dec 2025 02:38:12 EST (-0500)
  Stupid POV tricks (Message 1 to 9 of 9)
Subject: Stupid POV tricks
Date: 27 Oct 1999 09:48:37
Message: <3817006E.EB0BB4AB@aol.com>
I think something was mentioned about doing specular and phong colors
recently and 'out of the blue' I remembered a trick I came up with for
doing this for a program I wrote.  Take a gander at this,
light_source {<50, 50, -100> color White}
camera {location <0, 10, -40> look_at 0}
sphere {<0, 0, 0>, 10
      pigment {color rgb <1, 1, 1>}
      finish {phong 0}
      pigment{color rgbt <1, 0, 0, 1>}
      finish {phong 1 phong_size 20 metallic}
plane {y, -10
pigment {color White}
Subject: Re: Stupid POV tricks
Date: 27 Oct 1999 20:56:42
Message: <38179f4a@news.povray.org>
Clever... but, is that phong 0 really necessary?
Date: 28 Oct 1999 01:45:05
Message: <3817E09D.FF472963@aol.com>
Phong defaults to 0 so it isn't.  I didn't want to bother with much
testing at the time so I just added that in there just in case the
default was something else.  Try this to increase the effect.
material
      pigment{color rgbt <2, -1, -1, 1>}
      finish {ambient 0 diffuse .1 phong .5 phong_size 20 metallic}
hollow
Subject: Re: Stupid POV tricks - similar trick
Date: 28 Oct 1999 22:09:05
Message: <38190327.8CEF8E6B@aol.com>
I found out not too long ago that you can specicy both a phong & a
specular in the same finish statement. Many of you probably already knew
that, but it was interesting to discover it.
Samuel Benge
STB### [at] aolcom
"And you can fly
 High as a kite if you want to
 Faster than light if you want to
 Speeding through the universe
 Thinking is the best way to travel"
          -The Best Way to Travel, The Moody Blues
Date: 29 Oct 1999 10:08:08
Message: <d1IZOMst6JUFnl9p0wP89bAWVbSO@4ax.com>
On Thu, 28 Oct 1999 19:15:03 -0700, "SamuelT." <STB### [at] aolcom>
My metallic textures usually have a phong value equal to half the
specular value, and low phong_size and roughness (a large, soft phong
highlight and tight specular highlight). This gives the illusion of a
visible light source (a bulb, the sun). Also I use metallic of
0.75-0.95 to see the light color a bit.
Peter Popov
ICQ: 15002700
Date: 29 Oct 1999 23:35:34
Message: <381A68F1.9A12940F@aol.com>
I thought metallic showed the object's color in the highlight....
> Peter Popov
> ICQ: 15002700
Samuel Benge
STB### [at] aolcom
"And you can fly
Date: 30 Oct 1999 00:57:04
Message: <381A7A70.5125D727@isd.net>
T_Glass from the include uses both...
> Samuel Benge
> STB### [at] aolcom
> "And you can fly
Date: 30 Oct 1999 03:17:34
Message: <381a9b8e@news.povray.org>
'specular' or 'phong' hilights use the 'light_source' color, 'metallic'
causes use of the object surface color.  So, correct.
SamuelT. <STB### [at] aolcom> wrote in message
news:381A68F1.9A12940F@aol.com...
Date: 30 Oct 1999 06:45:35
Message: <UcsaOBqSu8dXzDcmfrMoGZQkptsv@4ax.com>
On Fri, 29 Oct 1999 20:41:37 -0700, "SamuelT." <STB### [at] aolcom>
Metallic controls the color of the highlight. At 0, it corresponds to
the light's color (plastic) and at 1 it corresponds to the color of
the object (metal). I use 0.9 or something similar to show 10% of the
light's color in the highlight.
Peter Popov
ICQ: 15002700
