POV-Ray : Newsgroups : povray.general : Infinity in a box Server Time
27 Mar 2026 16:11:06 EDT (-0400)
  Infinity in a box (Message 1 to 10 of 10)
Subject: Infinity in a box
Date: 15 Sep 1999 08:51:15
Message: <37df9643@news.povray.org>
Sometime in the last week someone brought up the "infinity in a box" thing
again, they did it with a clear box with a reflection of 1.
The first person to try this claimed they had a problem with it disapearing to
black, but my problem has gone the other way, I get about 1 1/2 reflections
(all of which are faded) and then it fades to white.
I tried removing all of the light sources and setting the ambients higher,
etc. I even moved the camera into the box, I get a better image, but it still
seems to be a bit bright.
Changing the base color (of the transmit 1 pigment) of the box, but that
doesn't seem to effect it....
This is a diversion I really don't need, but now that I'm on it I'd like to
see it through <GRIN>
Any help would be great....
Thanks....
PHIL
Subject: Re: Infinity in a box
Date: 15 Sep 1999 11:23:10
Message: <37dfb9de@news.povray.org>
'transmit 1' you say? Watch out when using it instead of 'filter'
since for reasons not entirley known to me it tends to increase
brightnesses.
Philip Bartol <phi### [at] concentricnet> wrote in message
news:37df9643@news.povray.org...
thing
disapearing to
reflections
higher,
it still
that
like to
> Thanks....
> PHIL
Date: 15 Sep 1999 22:03:48
Message: <37E05045.336C673C@tapestry.tucson.az.us>
> Thanks....
> PHIL
Did you put the box in an entirely black (or very close to it) setting?  Because
the reflection values are added each time a ray hits the cube, anything else will
fade to a color (white in most cases) very fast.
Date: 15 Sep 1999 23:48:09
Message: <37e06879@news.povray.org>
Hmm, I figured it couldn't be 'finish' related at all without any
light sources present (as Philip had said he tried) so 'diffuse'
shouldn't have been happening then.  Will reflection alone add up? I
have forgotten if it does or not.  Just tried a face to face 2 plane
check of it and didn't see any reflection color addition.
Well it's a mystery to me, as most things are.
Kevin Wampler <kev### [at] tapestrytucsonazus> wrote in message
news:37E05045.336C673C@tapestry.tucson.az.us...
setting?  Because
anything else will
Date: 16 Sep 1999 13:48:08
Message: <37e12d58@news.povray.org>
In article <37E05045.336C673C@tapestry.tucson.az.us>, Kevin Wampler
> Because
> will
This is what I found to be the case... I had a plane right below the box, set
to color Gray50 (rgb .5).... when I removed the plane I got the infinate
images fading to a black... when I put the plane back in with a almost black
color (Gray05 or rgb .05) Then I got the image I was hoping to see...
The bummer behind this is that you can't put a checkered plane or anything
under it.... this technique can't be used to put a small "cube of infinity" on
someone's desk or something....
Oh well...
PHIL
Date: 16 Sep 1999 14:10:42
Message: <37e132a2@news.povray.org>
Sure you could (I think...) if you use the "vampire" method on the
infinity mirror box.  Couldn't you?
news:37e12d58@news.povray.org...
anything
infinity" on
Date: 16 Sep 1999 14:33:11
Message: <37E137EE.6CA0AC5A@enst.fr>
> Oh well...
> PHIL
	Who said so? (see picture in p.b.i)
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 16 Sep 1999 14:40:16
Message: <37E13997.11E8947D@enst.fr>
> Bob
	Exactly :)
		Jerome
* Then do it.                 *
Date: 20 Sep 1999 22:56:54
Message: <37e6f3f6@news.povray.org>
In article <37e132a2@news.povray.org>, "Bob Hughes" <inv### [at] aolcom> wrote:
>Bob
>anything
>infinity" on
"Vampire" method? I'm missing something here aren't I?
PHIL
Date: 21 Sep 1999 00:00:36
Message: <37E702E3.ADA09978@enst.fr>
> >Bob
> >anything
> >infinity" on
> PHIL
	It's a method that was used in a series of posts a month or two ago to
make objects that didn't appear in mirors or cast weird shadow. It
basically uses bounding boxes to make the objects visible only from the
camera or the light source or the mirror. You can see an example I just
posted in p.t.s-f
		Jerome
* Then do it.                 *
