POV-Ray : Newsgroups : povray.general : normal calculation Server Time
16 Oct 2026 02:43:15 EDT (-0400)
  normal calculation (Message 1 to 8 of 8)
Subject: normal calculation
Date: 27 Jun 1999 09:53:03
Message: <37762cbf@news.povray.org>
Hi
when calculating the normals of a smooth_triangle, POV Help tells me that
"Generally the smoothed normal should be the average of all the actual
normals of the triangles which share that point".
Does that mean, that I simply have to add these normals and divide them by
their number? Is the average of some vectors such a simple thing, and why
then do MY smooth_triangles look so sadly wrong?
Are their special things to care about while calculating normals, width of
angles or such?
Short question, does anyone know about some simple-case-tutorial/faq
concerning  triangle or mesh calculation? Some source-code would do, too, I
am for now working on a rounded "Icosaede" (didn't find the english
translation, the platonic shape made of 20 equal triangles).
Thanks for your hints
Andreas
ger### [at] netcologneNOSPAMde
Subject: Re: normal calculation
Date: 27 Jun 1999 10:05:51
Message: <37762fbf@news.povray.org>
In article <37762cbf@news.povray.org> , "Andreas Gerdes"
Well, do your vectors all have the same length?
    Thorsten
e-mail: Tho### [at] csicom
Date: 27 Jun 1999 10:29:30
Message: <wbd7yhsomu.fsf@tycho.oslo.infostream.no>
[Andreas Gerdes <ger### [at] netcolognede>]
| their number?
Yes, but make sure your normals are of the same length and that they
are pointing in the same direction relative to the surface. (Clockwise
vs. counterclockwise triangles)
A penny for your thoughts.
Mine are more expensive.
Date: 27 Jun 1999 10:59:55
Message: <37763c6b@news.povray.org>
Thorsten Froehlich schrieb in Nachricht <37762fbf@news.povray.org>...
Since it is an Ikosaede made of equal sided triangles, sure.
The normals of each edge, too.
I am quite sure that I have got some problems in my surrounding programming,
especially in the data structure (several pointer lists),
so I would really like to see some simple examples to know if at least my
vector calculations are right.
I've posted two images in binaries.images, the icosaede unsmoothed and
smoothed with some (unnormalized) normal vectors, which seem to be well
calculated - but their average must be completely wrong :-(
bye
Andreas
gerdes@netcologne.*NOSPAM*.de
Date: 27 Jun 1999 11:33:33
Message: <3776444d@news.povray.org>
   1-----5
2---3----6
   4
Do you mean that, when calculating for example the normals of vertice 1,
taking the directed edge 1/3, I have to take 1/3 too instead of 3/1, when I
calculate the normals of vertice 1 ?!
And that I have to fix the directions of any edge once and for all before
proceeding further calculations?
I almost suspected that it would become a little more complicated ...
Thanks for your patience
Andreas
Date: 27 Jun 1999 11:39:56
Message: <377645cc@news.povray.org>
There was a fault in my former message:
I
>>>>1 ?!
I mean 3, of course.
Date: 27 Jun 1999 11:41:22
Message: <37764655.5A0BAA98@pacbell.net>
Andreas Gerdes wrote:
> Hi
> angles or such?
> Andreas
  Besides the advice you have already recieved see the tread in
povray.advanced-users posted 06-08-99 "smooth triangle normals"
for more info on calculating the cross product at each vertice.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 27 Jun 1999 12:09:30
Message: <37764cba@news.povray.org>
Hi again
and thanks
I know now that I comletely misunderstood the whole matter, always
calculating
vnormalize(vcross(a,b))
vnormalize(vcross(a,c))
vnormalize(vcross(a,d))
instead of
vnormalize(vcross(b-a,c-a))
vnormalize(vcross(c-a,d-a))
didn't care about sense of rotation, neither ...
Andreas
