POV-Ray : Newsgroups : povray.general : External data for animations? Server Time
14 Nov 2024 19:17:34 EST (-0500)
  External data for animations? (Message 1 to 7 of 7)
Subject: External data for animations?
Date: 21 May 1999 18:04:51
Message: <3745CA8F.5B17EF49@istar.ca>
At work I use a nice little program called Interactive Physics...
simulates motion. It can also output measurements (position, rotation,
etc) to a text file.
Obviously, if I could combine POV and this file, amazing animations
could be made. Is there any easy way to do this? It is a text file for a
falling (and bouncing) square with columns for frame number, xpos, ypos,
and rotation.
Simon
http://home.istar.ca/~sdevet
Subject: Re: External data for animations?
Date: 21 May 1999 18:20:08
Message: <3745ce08.0@news.povray.org>
>and rotation.
First, massage the data file into something the file read stuff in
POV can understand.  You might need to write some code for this part.
While you're rendering your animation, you can find the frame number
using clock and clock_delta (actually, only if the clock is zero on
the first frame, but you can always add a constant if it's not.)
Now, just read through the file until you find the right frame number
and use the data in that row.  Parse time might suffer, but you can't
have everything. :)
Alternatively, of course, you could write a Perl script (or some other
language, I'm just partial to Perl) to convert the data file into a big
#switch and some supporting code and just #include it, letting the
compiled C code in the POV parser do what you would have had to do in
interpreted POV-Script.
Date: 24 May 1999 18:19:54
Message: <3749C267.4D107CC7@netvision.net.il>
what's clock_delta?
Date: 24 May 1999 18:35:10
Message: <3749c60e.0@news.povray.org>
>what's clock_delta?
From the section "Built-in Float Identifiers" in the 3.1 manual:
  The built-in float identifier clock_delta returns the amount
  of time between clock values in animations in POV-Ray. While
  most animations only need the clock value itself, some animation
  calculations are easier if you know how long since the last
  frame. Caution must be used when designing such scenes. If
  you render a scene with too few frames, the results may be
  different than if you render with more frames in a given time
  period. On non-animated scenes, clock_delta defaults to 1.0.
  See section "Animation Options" for more details.
This is new in 3.1, as I recall.
Date: 24 May 1999 18:37:16
Message: <3749C679.D5D18035@netvision.net.il>
ahhhh. Well, another fault of the help system. The search does not show
it.
Date: 24 May 1999 18:48:36
Message: <3749c934.0@news.povray.org>
>it.
The search doesn't show a large fraction of the identifiers.  For
example, try finding vaxis_rotate (or any other function.)  This
is a serious limitation, because the nice new context help feature
depends on being able to find the keyword you had selected.
Unfortunately, I would imagine that adding such keywords to what
is currently the result of an automatic process would be a lot of
work for our beloved and already-overworked webmaster and Windows
POV-Team guy.
Date: 24 May 1999 22:34:33
Message: <3749fe29.0@news.povray.org>
show
>>it.
>POV-Team guy.
        Em, guys,
        I had no problem finding either of those words using the
"search" function of the help system. Frankly, I rarely use the index
: I find that even the summary is more helpful now that I know POV
somewhat better.
        Jean
