POV-Ray : Newsgroups : povray.general : orthographic projection of game tiles.... Server Time
12 Aug 2024 11:17:43 EDT (-0400)
  orthographic projection of game tiles.... (Message 1 to 8 of 8)
Subject: orthographic projection of game tiles....
Date: 27 Feb 1999 22:40:09
Message: <36d8ba99.0@news.povray.org>
I'm working on a shareware video game similar to diablo  and I want to use
POV-RAY to render the tiles.  the tiles need to be 64x64 with two diamonds
rendered from a checkered floor, one right above the other.  so far I've got
the orthographic part right, but I cant get the camera into the right
position to render it perfectly.  I need the perfect rendering position so
the individual tiles will match up correctly inside the game.  so right now
I've got a checkered floor and I'm looking at 0,0,0 from 10,10,10 with the
floor scaled up by 10.  this doesnt give me the effect I'm looking for.  I
need the corners to line up to the edges and to the center of the tile....
so can anybody lend some advice?
Subject: Re: orthographic projection of game tiles....
Date: 1 Mar 1999 01:45:28
Message: <36da3788.0@news.povray.org>
Forget the "look at" and just use the height/width in your right/up vectors.
If memory serves (I did some ortho reciently), the camer's position is the
lower-left corner, not the center!   Don't rotate the camera and you'll have
nice straight lines.
--John
Stephen Guentert wrote in message <36d8ba99.0@news.povray.org>...
got
Date: 1 Mar 1999 04:34:56
Message: <MPG.11447dce346addd698969c@news.povray.org>
'T was on Mon, 1 Mar 1999 00:45:26 -0600,
Er... Not exactly true.
With orthographic camera's, the up and right vectors determine the view
size with the look_at point as the *middle*.
For instance,
    location <0, 10, 0>
    up <0, 2, 0>
    right <2, 0, 0>
    look_at <0, 0, 0>
would give you a view of 2 units wide and 2 units high (yes, a square
image :) with the origin as the center point.
With this camera you could use a plane on the y axis as the background
and put whatever you want to tile on the origin.
Don't forget to specify the image width and height itself!
Phoenix
eag### [at] telekabelnl                       http://users.telekabel.nl/eagle
The POV-Ray VFAQ: http://iki.fi/warp/povVFAQ.html
Date: 1 Mar 1999 08:23:49
Message: <MPG.1144a8a467e6c9d898969d@news.povray.org>
'T was on Mon, 1 Mar 1999 10:35:28 +0100,
that Phoenix wrote:
> camera {
      orthographic
>     location <0, 10, 0>
>     up <0, 2, 0>
>     right <2, 0, 0>
>     look_at <0, 0, 0>
Stupid me! Give a lecture on the orthographic camera and then forget to
make it one...
Phoenix
Date: 1 Mar 1999 19:47:18
Message: <36db3516.0@news.povray.org>
yes, I looked at the actual script and it's in the middle.
#local Height= 71;
#local Width= 47;
#local Base= 18;
#declare ortho=
   orthographic
   location <0,Base+(1+Height)/2,-8*ft>
   direction <0,0,1>
   up <0,Height+1,0>
   right <Width+1,0,0>
   look_at <0,Base+(1+Height)/2,0>
As long as the camera was pointed perpendicularly to the scene's horizontal
and vertical components, those components rendered straight.
--John
Phoenix wrote in message ...
vectors.
the
have
>For instance,
>camera {
>    location <0, 10, 0>
>    up <0, 2, 0>
>    right <2, 0, 0>
>    look_at <0, 0, 0>
>Phoenix
Date: 1 Mar 1999 22:15:32
Message: <36db57d4.0@news.povray.org>
I messed with the up and right vectors and got it to work perfectly.
I didn't use all those #declares and #locals though.  notice that everything
is scaled up by 10.  notice also that my right vector is the square root of
2 (scaled by 10).  my up vector is 1.63 (scaled again).
this gives me exactly what I want - but I'd like to understand the
mathematical significance of these numbers.
and also, is anyone interested in doing some images for a shareware game?
heres my tile.ini:
Width = 512
Height = 512
Bounding_Threshold = 3
Display=On
Verbose=On
Library_Path=C:\Program Files\POV-Ray for Windows\INCLUDE
Input_File_Name=tile2.pov
Output_File_Name=C:\WINDOWS\Desktop\images\
heres my tile.pov:
global_settings {
  ambient_light <1.0,1.0,1.0>
  assumed_gamma 1.9
background { color <0.000,0.000,0.000> }
camera {  //  Camera StdCam
orthographic
  location  <10 , 10, 10 >
  right     <0  , 1.4142135623730950488016887242097 * 10 , 0.0 >
  up        <1.63 * 10, 0.0 , 0.0 >
  direction <0  , 0 , 1 >
  look_at   <0.000, 0.000, 0.000>
// *******  L I G H T S *******
light_source {   // Light1
  <10.000, 20.000, 20.000>
  color rgb <1.000, 1.000, 1.000>
//  Moray V3.01 For Windows (c) 1991-1998 Lutz + Kretzschmar
// ********  TEXTURES  *******
#include "tile2.inc"
// ********  REFERENCED OBJECTS  *******
// ********  OBJECTS  *******
sphere { //left foot
  <0, 0, 0>, .5
    Tiles
  scale <2,1,1>
  translate <5, 0, 3>
sphere { //right foot
  <0, 0, 0>, .5
    Tiles
  scale <2,1,1>
  translate <5, 0, 7>
sphere { // head
  <0, 0, 0>, .75
    Tiles
  translate <5, 8, 5>
sphere { // torso
  <0, 0, 0>, 1
    Tiles
  scale <.5,1,1>
  translate <5, 6, 5>
sphere { // hips
  <0, 0, 0>, 1
    Tiles
  scale <.5,.75,1>
  translate<5, 4, 5>
sphere { // left shin
  <0, 0, 0>, 1
    Tiles
  scale <.5,1,.5>
  rotate <10,0,0>
  translate<5, 1.5, 3.25>
sphere { // left thigh
  <0, 0, 0>, 1
    Tiles
  scale <.5,1,.5>
  rotate <10,0,0>
  translate<5, 3, 3.75>
sphere { // right shin
  <0, 0, 0>, 1
    Tiles
  scale <.5,1,.5>
  rotate <-10,0,0>
  translate<5, 1.5, 6.75>
sphere { // right thigh
  <0, 0, 0>, 1
    Tiles
  scale <.5,1,.5>
  rotate <-10,0,0>
  translate<5, 3, 6.25>
plane { // Plane001
  y,0
    Tiles
  scale 10.0
Date: 1 Mar 1999 23:22:09
Message: <36db6771.0@news.povray.org>
Stephen Guentert wrote in message <36db57d4.0@news.povray.org>...
Why not?  makes it easier to change, and you don't have magic numbers in the
final code but see the reasons for them.
Well root-two is the diagonal of a square, and 1.618123 (close to what you
have) is the inverse of the "golden ratio", a way to divide a line so that
the ratio the small piece to the large is the same as the ratio of the large
to the whole.
>orthographic
>  scale 10.0
In a ortho camera, the "right" is the number of POV units wide the scene
will render, and the "up" is the number of POV units tall.  So you're saying
you want 14.1 x 16.3 POV units to form your image, outputting in 512x512
pixels.  Strange that your pixels are not square...
You are located at 10,10,10, but looking down over your left sholder.  The
angle of this view to the ground probably is the cause of these numbers.
Normally, in an ortho projection, the "look at" should be directly down the
line of sight, so it has two numbers the same as the location, and the one
that's different is the one that's not used in the up and right.
Date: 2 Mar 1999 00:27:03
Message: <36db76a7.0@news.povray.org>
John M. Dlugosz wrote in message <36db6771.0@news.povray.org>...
the
I plan to eventually use variables.  this was just to get me up and running.
large
>to the whole.
aha! that's what I was looking for.........
>>orthographic
>>  scale 10.0
saying
512 x 512 was a "test" size.  the tiles will be 64x64 in the end.
I just had to maintain powers of 2 in both directions of the image,
and the corners of the diamonds had to fall in a perfectly tilable fashion.
declare a checkered texture (where I failed to include mine) and you will
see the
perfect math that comes out of it.
 I know this doesn't look like everyday POV, but
I've already plugged a couple tiles into the engine and it's working like a
dream.
thank you much for the mathematical clarification! It had me stumped.
