POV-Ray : Newsgroups : povray.general : Matrix commands Server Time
12 Jan 2026 01:21:21 EST (-0500)
  Matrix commands (Message 1 to 5 of 5)
Subject: Matrix commands
Date: 9 Mar 1999 20:23:02
Message: <36E5C8D2.9C179299@spiritone.com>
I was reading a web site that explained the way the Matrix command
works, but it intentionally disregarded the math behind it. I was
wondering if POV-Ray used normal matrix mulitplication or if it used
another algorithm for translating things. If I were to pick up my old
high school textbooks and brushed up on matrixes there, would I get the
same results as POV-Ray?
Thanks,
Josh
Subject: Re: Matrix commands
Date: 10 Mar 1999 06:46:14
Message: <36e65b86.0@news.povray.org>
As far as I can figure, it does. Have a look at the scene language help
under Matrix. It explains exactly what the maths is. You should look up
homogeneous coordinates in your texts.
Good Luck
Gordon
<gbe### [at] birdcameroncomau>
Josh English wrote in message <36E5C8D2.9C179299@spiritone.com>...
>Thanks,
>Josh
Date: 10 Mar 1999 11:16:38
Message: <36E69B4A.8CDEE8CB@spiritone.com>
Yeah, that helps, but the webiste I was looking at (and didn't have the URL
fer earlier) is at www.erols.com/vansickl/ and it mentions that matrices are
multiplied together during parsing so multiple transformations are handled
at roughly the same speed. It is mostly academic at this point, but I would
like to see how they are combined... I suppose I could do a lot of
experimentation. Thanks,
Josh
> Good Luck
> Gordon
> >Thanks,
> >Josh
Josh English
eng### [at] spiritonecom
www.spiritone.com/~english
Date: 10 Mar 1999 20:32:22
Message: <36e71d26.0@news.povray.org>
I think you'll find that they do work that way, but ultimately you should do
a few experiments to be sure. One thing to keep in mind is that the order of
multiplication IS important, but the web site and your texts probably
mentions this.
Gordon
Josh English wrote in message <36E69B4A.8CDEE8CB@spiritone.com>...
are
>Josh
>> Good Luck
>> Gordon
>> >Thanks,
>> >Josh
>Josh English
Date: 10 Mar 1999 22:21:11
Message: <36E737E4.B0515DDB@erols.com>
> mentions this.
Internally, a POV-Ray matrix looks like this:
 A B C 0
 D E F 0
 G H I 0
 J K L 1
the fourth column is zero, zero, zero, one.
If you have another matrix,
 M N P 0
 Q R S 0
 T U V 0
 W X Y 1
then the first is multiplied by the second, they yield
 A*M+B*Q+C*T   A*N+B*R+C*U   A*P+B*S+C*V   0
 D*M+E*Q+F*T   D*N+E*R+F*U   D*P+E*S+F*V   0
 G*M+H*Q+I*T   G*N+H*R+I*U   G*P+H*S+I*V   0
 J*M+K*Q+L*T+W J*N+K*R+L*U+X J*P+K*S+L*V+Y 1
If you reverse the order of multiplication, the results will be different
except in a few special cases.  Verification of this is left as an
exercise for the interested student with nothing better to do.
John
