POV-Ray : Newsgroups : povray.general : Math r dumb-Ken r toopid Server Time
28 Apr 2026 07:27:47 EDT (-0400)
  Math r dumb-Ken r toopid (Message 1 to 10 of 11)
Subject: Math r dumb-Ken r toopid
Date: 19 Feb 1999 13:28:37
Message: <36CDACF0.398D5F39@pacbell.net>
Howdy Ya'll !
 Is it possible to trap a specific number generated by the rand
function to be used in another portion of a loop ?
  An example of why I ask would be to create non umiform scaled wood
shingles for a roof. They are usually the same in thichkess and length
but the width varies. I could use the rand function within a loop to
vary the scale of each oject generated but it would greatly complicate
the position of the shingles as they are translated into postion through
the loop count. My idea of a solution would be know what variation of
scaling is given by the rand function for each object and using that
value to adjust the translated position of the objects accordingly.
 Is it possible to do something like this and if so how, what, when,
where, and why ?
I appreciate your thoughtful consideration in this matter.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Math r dumb-Ken r toopid
Date: 19 Feb 1999 14:50:15
Message: <36cdbe96.16933852@news.povray.org>
>where, and why ?
Just generate the random number separately, save it in a variable, and
use it in both places.  For your shingling project, in order to
account for the variable positions of other shingles, you could either
save the random numbers in an array as you create them and sum the
correct row or column for the needed offset, or (bad idea) reset the
random number stream with the original seed and run the random number
through the needed number of iterations at placement time.  If you are
crazy enough to do that, you will also have to reseed and iterate each
time in the placement loop.  An array would be much better.
Jerry Anning
clem "at" dhol "dot" com
Date: 19 Feb 1999 15:00:04
Message: <36CDC2C0.649C@merlin.net.au>
Hi Ken,
Not sure I understand your problem.
Do you mean something like
#declare NextX = 0;
#while( NextX < 20 )
  #delare Scale = 1+rand(Seed);
  box{0,1 scale Scale}
  translate <NextX,0,0>
  #declare NextX = NextX + Scale
PoD.
Date: 19 Feb 1999 18:02:16
Message: <36CDED14.95606CD8@pacbell.net>
> Jerry Anning
I understand how to use arrays but am unsure hot to pass a value to one
for storage and later retrieval. A brief example would be appreciated.
Ken Tyler
Date: 19 Feb 1999 18:05:25
Message: <36CDEDD1.399182D7@pacbell.net>
PoD wrote:
> Hi Ken,
> #declare NextX = 0;
> #end
> PoD.
I thought it might be accomplished in a way similar to this but never
would have thought to increment the counter with the scale value.
I will check it out and see what happens.
 Thank you !
Ken Tyler
Date: 19 Feb 1999 18:37:56
Message: <36CDF5EF.41A3FA1B@virginia.edu>
While I would be in favor of a solution like PoD's, storing and
retrieving from an array is easy.
#declare num = 20;
#declare MyArray = array[Num];
#declare i = 0;
#while (i < num)
   #declare MyArray[i] = i;
   #declare i = i + 1;
this stores the current value of i into the array at each position (so
MyArray[5] = 5) to get them out, simply do something like the following
#declare i = 0;
#declare Sum = 0;
#while (i < num)
   #declare Sum = Sum + MyArray[i];
   #declare i = i + 1;
it is that simple.
Steve
> > Jerry Anning
> Ken Tyler
Date: 20 Feb 1999 06:33:20
Message: <36ce9d80.0@news.povray.org>
Ken wrote in message <36CDEDD1.399182D7@pacbell.net>...
>PoD wrote:
>> Hi Ken,
>> #declare NextX = 0;
>> #end
>> PoD.
> Thank you !
>Ken Tyler
It might help if you don't think of NextX as a counter, but as a position. We get used
to using #while because there is no #for, but it is a more general loop than that.
Gordon
<gbe### [at] birdcameroncomau>
Date: 22 Feb 1999 11:58:53
Message: <36d18ccd.0@news.povray.org>
On Sat, 20 Feb 1999 19:33:24 +0800, Gordon <gbe### [at] birdcameroncomau> wrote:
>DQpLZW4gd3JvdGUgaW4gbWVzc2FnZSA8MzZDREVERDEuMzk5MTgyRDdAcGFjYmVsbC5uZXQ+Li4u
>DQo+UG9EIHdyb3RlOg0KPj4gDQo+PiBIaSBLZW4sDQo+PiBOb3Qgc3VyZSBJIHVuZGVyc3RhbmQg
>eW91ciBwcm9ibGVtLg0KPj4gRG8geW91IG1lYW4gc29tZXRoaW5nIGxpa2UNCj4+IA0KPj4gI2Rl
>Y2xhcmUgTmV4dFggPSAwOw0KPj4gI3doaWxlKCBOZXh0WCA8IDIwICkNCj4+ICAgI2RlbGFyZSBT
>Y2FsZSA9IDErcmFuZChTZWVkKTsNCj4+ICAgYm94ezAsMSBzY2FsZSBTY2FsZX0NCj4+ICAgdHJh
>bnNsYXRlIDxOZXh0WCwwLDA+DQo+PiAgICNkZWNsYXJlIE5leHRYID0gTmV4dFggKyBTY2FsZQ0K
>Pj4gI2VuZA0KPj4gDQo+PiBQb0QuDQo+DQo+SSB0aG91Z2h0IGl0IG1pZ2h0IGJlIGFjY29tcGxp
>c2hlZCBpbiBhIHdheSBzaW1pbGFyIHRvIHRoaXMgYnV0IG5ldmVyDQo+d291bGQgaGF2ZSB0aG91
>Z2h0IHRvIGluY3JlbWVudCB0aGUgY291bnRlciB3aXRoIHRoZSBzY2FsZSB2YWx1ZS4NCj5JIHdp
>bGwgY2hlY2sgaXQgb3V0IGFuZCBzZWUgd2hhdCBoYXBwZW5zLg0KPg0KPiBUaGFuayB5b3UgIQ0K
>Pg0KPi0tIA0KPktlbiBUeWxlcg0KPg0KPm1haWx0bzovL3R5bGVyZW5nQHBhY2JlbGwubmV0DQoN
>Ckl0IG1pZ2h0IGhlbHAgaWYgeW91IGRvbid0IHRoaW5rIG9mIE5leHRYIGFzIGEgY291bnRlciwg
>YnV0IGFzIGEgcG9zaXRpb24uIFdlIGdldCB1c2VkIHRvIHVzaW5nICN3aGlsZSBiZWNhdXNlIHRo
>ZXJlIGlzIG5vICNmb3IsIGJ1dCBpdCBpcyBhIG1vcmUgZ2VuZXJhbCBsb29wIHRoYW4gdGhhdC4N
>Cg0KR29yZG9uDQo8Z2JlbnRsZXlAYmlyZGNhbWVyb24uY29tLmF1Pg0KDQo=
Now I've officially seen everything:
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: base64
What kind of stupid newsreader would even think about letting someone do
this? Oh, I see.  It's another fine Microsoft product.
Date: 22 Feb 1999 15:09:00
Message: <36d1b95c.0@news.povray.org>
Ron Parker schrieb in Nachricht <36d18ccd.0@news.povray.org>...
4u
[snip]
Whoops, I didn't see what you meant (for the POV stuff, I normally use M$OE,
because of the pretty picture shows), but when I saved Gordon's post and
loaded it with a text editor, I could see. Really looks a bit illegible,
doesn't it?
The original said:
------------------------------->8----cut
here---------------------------------------
<QUOTE>
>PoD wrote:
>> Hi Ken,
>> #declare NextX = 0;
>> #end
>> PoD.
> Thank you !
>Ken Tyler
We get used to using #while because there is no #for, but it is a more
Gordon
</QUOTE>
-----------------------------------------------cut
here------------------8<---------------
Rudy Velthuis
Date: 22 Feb 1999 15:41:57
Message: <36D1C115.3B59@merlin.net.au>
Rudy Velthuis wrote:
[ snip snip ]
> Gordon
> </QUOTE>
> Rudy Velthuis
Yeah, that's why I called it NextX. In my mind at least that's kind of a
hint that it's the x offset of the next object rather than just a
counter.
Cheers, PoD.
