POV-Ray : Newsgroups : povray.general : Bug in pseudo random? (gif 716b+) Server Time
12 Sep 2025 00:09:48 EDT (-0400)
  Bug in pseudo random? (gif 716b+) (Message 1 to 10 of 14)
Subject: Bug in pseudo random? (gif 716b+)
Date: 2 Feb 1999 11:18:38
Message: <36B7240F.665C19A0@bahnhof.se>
Well, I was playing around in pov, using rand() and seed() functions
when I found this little effect after using it a bit.
The original idea was to ues the Superpatch in a few aspects(place a lot
of sphres and use bouded_by from a text object, and thus get text made
out of bubbles, generally.) when this effetc appeared, I made some
changes, and switched to normal pov to see if it was still there. Sure
it was.
Well, this is the code for the scene :
camera { location<0,0,-10> look_at<0,0,0> }
light_source { <-50,150,-50> color rgb 1 }
light_source { <+50,150,-50> color rgb 1 }
union {
  #local Min = <0,-0.0286, 0>+0.1;
  #local Max = <10,1.6721,4.6715>-0.1;
  #local S = <seed(1), seed(2), seed(3)>;
  #local R = seed(4);
  #local N = 0;
  #while(N<10000)
    sphere {
      Min+(<rand(S.x),rand(S.y),rand(S.z)>*Max)
      (rand(R)*0.07)+0.03
    #local N=N+1;
  translate -5*x
  pigment {colour rgb 1 }
  finish {ambient .8}
At first I thought it was the #local S = <seed(1), seed(2), seed(3)>;
line that was in error, but no. This worked with other numbers, so the
error is in seed(1) seed(2) seed(3) generation.
I just wonder if there is a limitation in the seed() function causing it
not to work with theese small numbers ???
If i used a a larger set of numbers, 666, 1999, 2010 3010 and so, it
worked nicely, but not here.
Attached is a .gif of the image, 2 colours.
I'm sorry about the image, but I thought it was small enough to be
attached here. *smile*
//Spider
Download 'bug_2.gif' (1 KB)
Preview of image 'bug_2.gif'
Subject: Re: Bug in pseudo random? (gif 716b+)
Date: 2 Feb 1999 11:43:15
Message: <36B72941.78392E6D@xs4all.nl>
It happens with every series of seeds with regular intervals.
I tried it for instance with 1000,2000,3000 which gave a similar result. Then I
tried it with 1000,2001,3000 and lo and behold!
I gues this has something to do with the way seed() works but I wouldn't know
anything about that.
What I don't understand is why you should declare more then one seeds.
Isn't one enough? Anyway, look what happens when you use only one seed. I did
I guess this isn't really a bug, just a way to uncover that randomness in a
computer is often pseudo (as you mentioned).
Remco
> it was.
> union {
>   #local R = seed(4);
>   #local N = 0;
>   #while(N<10000)
>     sphere {
>       (rand(R)*0.07)+0.03
>     #local N=N+1;
>   #end
>   translate -5*x
>   finish {ambient .8}
> //Spider
Date: 2 Feb 1999 15:58:53
Message: <36B72F70.7F8C5B85@bahnhof.se>
ok, is that it. I guess i should have known :-) (After all, I'm
currently reading a thing on how to make pseudo random values, abd how
to prove that a random series isn't working with statistics...)
oki.
probably not the seed() but the rand().
Actually, I usually have one for each axis, because then there is less
difference If i add a random rotation around an axis or so. And, I think
it's better to use three random values instead of one, gives me a bit
better feeling about it, it's "more random" (I know I'm wrong, but,
whata heck :-)
yup. I was just baffeld at the experience... (notice the ? in the header
//Spider
Subject: Re: Bug in pseudo random? (gif 716b+) (UDP)
Date: 2 Feb 1999 15:59:00
Message: <36B7322B.B845A942@bahnhof.se>
More thoughts.
If this won't change(I doubt it will) then a note in the documentation
should note about this, and make the user aware of it. A thing for the
UDP ?
//Spider
Date: 2 Feb 1999 18:31:12
Message: <36B787C1.365DA2D2@xs4all.nl>
Spider wrote:
> More thoughts.
> UDP ?
> //Spider
Huh, or just stick to using one seed.
Remco
Date: 2 Feb 1999 19:24:49
Message: <36B79630.23AEB71@bahnhof.se>
> Spider wrote:
> > More thoughts.
> > UDP ?
> > //Spider
Nooo, that would defy the reason for having seeds, wouldn't it ??
//Spider
Date: 2 Feb 1999 20:52:37
Message: <36b8ab2c.102296086@news.povray.org>
On Tue, 02 Feb 1999 18:13:15 +0100, Spider <spi### [at] bahnhofse> wrote:
>More thoughts.
>UDP ?
Aaaahhh!
A peek inside parkrrrr's mind while he tries to decode the characters
"UDP"...
"Usenet Death Penalty"  nope, that's not it.
"User Datagram Packet"  nope, not it either.
what could it be?  Oh, yeah, "User Documentation Project."
Can we come up with a different TLA?  That one's already been
overused.  :)
Date: 2 Feb 1999 20:59:53
Message: <36B7AC78.1460C0C8@bahnhof.se>
Not my idea, dont' blame me!!! (Scared scream as he jumps for cover)
sure thing, change it, do it, do it !!!!
//Spider
> >More thoughts.
> >UDP ?
> Aaaahhh!
> "UDP"...
> overused.  :)
Date: 2 Feb 1999 23:28:06
Message: <36B7CF8D.B4A4C823@aol.com>
How about calling it the YKYBRTLWYCAPFMAUDTIMTTTOTCWTP?
-Mike
> >More thoughts.
> >UDP ?
> Aaaahhh!
> "UDP"...
> overused.  :)
Date: 2 Feb 1999 23:32:28
Message: <36B7D13D.F425DFA5@pacbell.net>
Fine with me as long as I don't have to reference it by name.
I'll call it Y for short.
> -Mike
> > >More thoughts.
> > >UDP ?
> > Aaaahhh!
> > "UDP"...
> > overused.  :)
Ken Tyler
tyl### [at] pacbellnet
