POV-Ray : Newsgroups : povray.general : spline.inc Server Time
12 Jan 2026 12:45:41 EST (-0500)
  spline.inc (Message 1 to 5 of 5)
Subject: spline.inc
Date: 15 Jan 1999 07:32:45
Message: <369f356d.0@news.povray.org>
im using spline.inc (from chris colefax's website) to create smooth motion
paths....however, i cant seem to create more than one spline per scene.
is it meant to work this way?
i can rotate and move the one spline, but i need several different
splines...even using two spline files and including spline.inc after each
one creates only one spline.
any help would be greatly appreciated.
Subject: Re: spline.inc
Date: 15 Jan 1999 18:25:37
Message: <369FCDF2.47D607EE@pacbell.net>
 Can you provide a general example of how you are using it.
If we can see the code it is easier to trouble shoot the problem
for you. Don't include the whole scene you are working on just
the relevant parts.
Ken Tyler
tyl### [at] pacbellnet
Date: 16 Jan 1999 05:59:06
Message: <36a070fa.0@news.povray.org>
now i know i can get the same effect as using these two splines by using one
and rotating it, but this gives an idea of what i'm talking about.
i certainly hope i've made no stupid mistakes...
heres the code -
--------spline-test.pov---------
camera {location <0, 70, -30> look_at <0, 0, -30> }
#declare spline_smoothness = 300
#declare spline_file = "left.spl" #include "ShowSpl.inc"
#declare spline_file = "right.spl" #include "ShowSpl.inc"
-------left.spl----------
#declare spline_segments = 1
#declare spline_loop = false
#declare point0 = <-100,   0,  -60>
#declare point1 = <-40,   0,  -60>
#declare point2 = <0,   0, 2>
#declare point3 = <0,   0, 10>
#include "Spline.inc"
------right.spl---------
#declare point0 = <100,   0,  -60>
#declare point1 = <40,   0,  -60>
Date: 16 Jan 1999 18:06:36
Message: <36A11AF6.D2EEE1A6@pacbell.net>
> heres the code -
Hmm ! Sorry  I can't see the problem and would hate to start
guessing. Maybe an email to Mr. Colefax can clear this up for
you. I have found him very helpful in the past and he will answer
private emails when he finds the time. It might take a few days
but he will respond.
Ken Tyler
Date: 20 Jan 1999 08:06:16
Message: <qqmzp7e5c1l.fsf@goldach.fmi.uni-konstanz.de>
"Chris Field" <fun### [at] hotmailcom> writes:
> heres the code -
[ splines snipped ]
It it possible to use several splines at a time. We used up to 65 splines
in a project last year. We did however not use "ShowSpl.inc". The way we
used the splines was:
  #declare spline_clock = value1
  #include "node00.spl"
  #declare node00 = spline_pos
  #declare spline_clock = value2
  #include "node01.spl"
  #declare node01 = spline_pos
I hope this helps.
http://www.fmi.uni-konstanz.de/~willhalm
