![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
At:
http://www.iro.umontreal.ca/~pigeon/pub/PovPage/PovPage.html
Include:
-- Optimized for Pentium 2 processor and Windows NT (works on 95/98,
though)
-- ETA on status bar
-- float pps, i.e., you can see 0.03 pps instead of 0 PPS. (someone
asked for it... but... ?)
-- pixel in row progress status
-- minor bug fixes (palette and refresh of rendering window, default ini
file loading,
etc.)
Best,
S.
Steven Pigeon Ph. D. Student.
University of Montreal.
pig### [at] iro umontreal ca Topics: data compression,
pig### [at] jsp umontreal ca signal processing,
ste### [at] research att com non stationnary signals
and wavelets.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Cool!
A friend of mine compiled POV for Pentium Pro using MSVC5.0 max speed
optimisations. On a K6 ('cause I use one) it yields ~14% speed-up under NT
and ~5-6% under 95. What about your version? Anyway, I am downloading it
even now (5:50 a.m. local time!), but I was just curious if you can tell me
something beyond skyvase.
---Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Peter Popov wrote:
> Cool!
> Regards,
> ---Peter
What I found:
Parser is twice as fast.
Meshes are about 30% faster.
Average speed up is about 15% as reported by many
users... However, they all had Pentium 2's, and not K6's.
and:
-- Some minor bugs were corrected.
-- Some (minor) features were added, namely:
(in the currently available version on my web page)
ETA counter, PPS with 2 digit precision (ex: 0.15 pps),
pixel-in-line progress gadget,
(in the soon-to-be-on-my-web-page version)
Wheel mouse support about everywhere, except in
the editor window (because I can't compile it, my version
of Delphi is too old), Render window refresh bug repaired
(this bug was that sometimes the render window did not
refresh correctly when another application changed the
palette), ETA counter bug fix (eh... these things happens!),
and... and... what else have I added or changed....?
Eventually, I'm going to profile the whole thing to see where CPU
time goes. Maybe I'll rewrite some small parts.
Best,
S.
and wavelets.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I rendered using the PII compile on a K6 200 it was more that 100%
slower on a 640x480 image of a bridge.
(Times were 3:23 for the optimized, 1:38 for the regular)
Steve
Peter Popov wrote:
> Cool!
> Regards,
> ---Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
ohhh... that's bad. Are you sure that nothing else was running at
the same time? That's pretty weird... anyway, you're the first to
tell me that it slowed down, because everybody that tried it reported
speedups, not slowdowns.
What Peter Popov wrote:
> >> Cool!
> > Regards,
> > ---Peter
...is basically what I get from people who tries my version. Would you
do the experiments in the different order? Also, what is the scene? How
much memory do you have? Maybe one paid the penalty of getting stuff
into virtual memory...?
Or the K6 200 behaves really differently than the real Pentium 2 ?
Tell me more, I think this might be an important problem.
and wavelets.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm not sure.... I honestly don't remember, but the conditions were the
same for each render... I know that there were no ACTIVE windows as the
time... However, I must make on addition, the processor I'm using was
supposed to be a 233, but wouldn't run stably at 233 and I had to clock
it down. I'll try it on my K6-300 at home this evening...
Steve
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And I will be the second one. A julia fractal rendered 103% slower with the
*Pentium II* optimised version on my K6/200. I guess the conslusions are:
1. In the optimised version, all math is float (faster than int on P2,
slower on K6)
2. FPU operations are optimised for 2 floating point conveyors (K6 only has
one)
3. I'll stick to my K6 until I can afford a P2 (in a year maybe) and will
silently weep in a corner until then
BTW, in defense of AMD, a mandelbrot program a friend wrote in assembler and
manually optimised for the K6 was ~17% faster on AMD than Intel... Guess it
says it all about K6's RISC core and integer operations speed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Peter Popov <pet### [at] usa net> wrote in article
<35db94ca.0@news.povray.org>...
the
<sniped rather obvious conclusions>
and
it
Bollox does it ! Compare like against like (ie. K6 optimized on a K6 again
PII optimized on a PII) and then come back saying which is better. A K6
optimized app is always going to be better on a K6 then on an Intel chip,
just as a PII optimized app is always going to perform better on a PII than
any other chip. That's the point of optimization, it optimizes the code to
run the best on a given platform, you can't and shouldn't expect software
optimized for one specific platform to run equally efficiently on another,
different, platform.
Scott Hill
Sco### [at] DDLinks co uk
Software Engineer (and all round nice guy)
Company homepage : http://www.ddlinks.demon.co.uk
"The best trick the devil ever pulled was convincing people he didn't
exist..."
- Verbal Kint.
"the Internet is here so we can waste time talking about nothing in
particular when we should be working" - Marcus Hill.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
