POV-Ray : Newsgroups : povray.general : Light Sources Server Time
13 Jan 2026 16:51:59 EST (-0500)
  Light Sources (Message 1 to 4 of 4)
Subject: Light Sources
Date: 15 Apr 1998 18:05:07
Message: <35352F13.30B84FAD@programmer.net>
I've searched the documentation and I cannot find the answer to this
question.... How many light sources can a scene have and can that number
be expanded (assuming of course that the answer is not as many as you
like). I tried to draw a scene with lots of light sources and it seems
to use all of the light sources, but I haven't managed to count how many
are actually being used....
    just me,
        jeff
`._`.*.'_._ ____.____   Jeffry J. Brickley
* .o   o.* `.`. +.    . jbr### [at] geocitiescom
`  |\^/|  `. * .  * ` Magic is REAL, unless declared INTEGER.
`.. \U/ . + http://www.geocities.com/CapeCanaveral/Hangar/9078/
`.  /_\  .`. http://www.geocities.com/SiliconValley/Pines/3210
Subject: Re: Light Sources
Date: 16 Apr 1998 10:49:05
Message: <6h55ra$3bb$1@oz.aussie.org>
Jeffry Brickley wrote in message <35352F13.30B84FAD@programmer.net>...
>like).
I am not aware of any regulating factor for the number of lights, except for
rendering speed and other hardware related reasons.
Anybody else?
Johannes.
Date: 16 Apr 1998 11:48:32
Message: <6h598g$3em$1@oz.aussie.org>
Johannes Hubert (jhu### [at] algonetse) wrote:
: Jeffry Brickley wrote in message <35352F13.30B84FAD@programmer.net>...
: >I've searched the documentation and I cannot find the answer to this
: >question.... How many light sources can a scene have and can that number
: >be expanded (assuming of course that the answer is not as many as you
: >like).
: I am not aware of any regulating factor for the number of lights, except for
: rendering speed and other hardware related reasons.
: Anybody else?
  AFAIK there's no limit. Parsing and rendering of course slow down a lot
with thousands of light sources, but I think there's no limit. Why there
should be?
  I think the only limit is the memory and disk space (for the swap) of
the computer (I think light buffers consume memory).
                                                              - Warp. -
Date: 28 Apr 1998 14:10:43
Message: <35461BA3.E8A08207@programmer.net>
Well, I'm rendering a lightning bolt and trying to render the atmospheric glow.
By adding a light at every curve it looks REAL good, but it stops almost half way
down (rendering light sources) the bolt is 100 units long, given the distance it
stops at I think there's a limit at about 33-48, it's more than 33 as I am now
placing a light at every 3rd bend, but it's less than 50 as placing a light at
every 2nd still stopped half way there.... But I've never found a reference to
this limit....  I'll double check the code, but everything else seems to be good,
just the lights causing the problem....
    jeff
> : >like).
> : Anybody else?
> should be?
>                                                               - Warp. -
