POV-Ray : Newsgroups : povray.general : Realistic Sunsets Server Time
1 Mar 2026 18:51:35 EST (-0500)
  Realistic Sunsets (Message 1 to 6 of 6)
Subject: Realistic Sunsets
Date: 12 Jan 1999 12:23:25
Message: <369b850d.0@news.povray.org>
Is there any way to simulate the earths atmosphere in order to produce
realistic sunsets and how is the sun itself done?
for example:     if the sun is near the horizon the sky turns red if it is
up higher
                           the sky is blue.
-Dave
Subject: Re: Realistic Sunsets
Date: 12 Jan 1999 13:49:14
Message: <369B98B1.61364819@pacbell.net>
> up higher
>                            the sky is blue.
> -Dave
  I'm no expert in this department but I can direct you to a great
tutorial on the subject:
http://members.xoom.com/POVRAY3/
Ken Tyler
Date: 12 Jan 1999 18:19:52
Message: <369BD83D.7F886A1C@Kopp.com>
Yes, you can do this.  Go to povray.binaries.images and check out my message
titled "Media cloudscape revisited" (10/5/98).  The original image was by Mike
Andrews.  His message was "A media cloudscape ..." (9/28/98), and his code can
be found in povray.text.scene-files in the message "Media clouds." (9/29/98). I
posted two sunset images that both look pretty good.
A word of caution:  These scenes take a long time to generate.
If you want my modified version of Mike's scene, let me know (I hope he doesn't
care).
-Nathan
> up higher
>                            the sky is blue.
> -Dave
Date: 12 Jan 1999 21:08:46
Message: <01be3e99$a5e32dc0$7b0e8dc3@default>
Since I've seen this scene, I did found it really beautiful.
But, is it possible to generate such clouds over a normal landscape, with
HF? I think I did try to do it but nothing happened with the landscape, I
could only see the clouds. The rest was completely dark. In fact, I didn't
spend a lot of time with that, I supposed it was to strong for me.
<369BD83D.7F886A1C@Kopp.com>...
message
doesn't
> care).
> -Nathan
DEPerere
per### [at] infomaniakch
Date: 13 Jan 1999 13:02:23
Message: <369CDF33.1F7DDCD1@remove-this.reading.ac.uk>
> care).
No, I don't care :-)
I hope some more people get interested in using media for atmospheric effects,
especially they find a faster way to do it!
    Bye,
        Mike Andrews.
> -Nathan
> > up higher
> >                            the sky is blue.
> > -Dave
Date: 13 Jan 1999 15:00:43
Message: <369cfb6b.0@news.povray.org>
effects,
Have a look at strange media in the images newsgroup it was based on Mike
Andrews work. Then it went off in wierd directions of it's own when I
discovered the effect of ramp_wave and frequency... That took 5 hours to
render on a 300 mhz P2
Look out for my next IRTC entry it pushes media into even stranger realms.
Mick Hazelgrove
