POV-Ray : Newsgroups : povray.general : Transparency bug in POV 3.1? Server Time
11 Jul 2026 03:40:46 EDT (-0400)
  Transparency bug in POV 3.1? (Message 1 to 3 of 3)
Subject: Transparency bug in POV 3.1?
Date: 14 Aug 1998 15:41:46
Message: <01bdc7b3$4f05de60$89c3f5cf@workstn2.uact.net>
I've just downloaded pov 3.1 and got possibly a little too excited about
the new media feature.  I thought that it would be possible (using a scaled
sphere and interior) to produce wispy bozo clouds in 3d.  The problem is
that when I enter a transparency value in the density color_map the
renderer completely ignores it and uses only the red green and blue values.
 Am I doing something wrong or is there a way around this problem?
Andrew Clinton
The POV Place - http://www3.sympatico.ca/dclinton/pov/povplace.htm
Subject: Re: Transparency bug in POV 3.1?
Date: 14 Aug 1998 20:59:15
Message: <35D4CF3E.7ABB32F0@flash.net>
It's in the documentation.   It's the way it's supposed to
behave -- it isn't of the same form as halos.
Dan
> Andrew Clinton
http://www.flash.net/~djconnel/
Date: 18 Aug 1998 14:03:16
Message: <35D9B3FB.A2DFC29F@remove-this.reading.ac.uk>
Hi Andrew,
    Sounds like you're trying to do the same thing as me. I have had limited
success so far in building clouds using the media of v3.1 - have a look at my
'Hazy Days ...' posts on p.b.i and the source on p.t.s-f if you want to see how
I'm going about it.
    One thing you need to remember with density maps - you are actually
defining the optical density in each of the red, green and blue with 1 being
brightly emmiting/highly absorbing/hugely scattering media and 0 being
transparent; filter and transparency have _NO_ effect.
    Hope this helps,
        Mike Andrews.
> Andrew Clinton
