POV-Ray : Newsgroups : povray.documentation.inbuilt : Document -CC/+CC command line and Create_Continue_Trace_Log ini opt. Server Time
28 Aug 2025 23:01:48 EDT (-0400)
  Document -CC/+CC command line and Create_Continue_Trace_Log ini opt. (Message 1 to 10 of 10)
Subject: Document -CC/+CC command line and Create_Continue_Trace_Log ini opt.
Date: 6 Dec 2016 06:43:26
Message: <5846a45e$1@news.povray.org>
Per recent discussions and issue work I think we should document the -CC
option.
Reference :
http://news.povray.org/povray.windows/message/%3C584605a0%241%40news.povray.org%3E/#%3C584605a0%241%40news.povray.org%3E
and
https://github.com/POV-Ray/povray/issues/167
I think it comes to adding something like :
Create_Continue_Trace_Log=bool  Save state information in file on/off
+CC Save state information in file on
-CC Save state information in file off
The state or continue trave information file must exist for the
Continue_Trace=true / +C option to work.
to the section:
http://wiki.povray.org/content/Reference:General_Output_Options#Resuming_Options
Also in that section we today have this bit:
"This option reads in the previously generated output file, displays the
partial image rendered so far, then proceeds with the ray-tracing. This
option cannot be used if file output is disabled with Output_to_file=off
or -F."
However, I think "Output_to_file=off or -F" suppresses the creation of
the final output image file not the state/log file needed to continue a
trace. Thinking we might re-work the above paragraph to refer to the
state/log file instead and drop reference to the output to file option
here.
Aside: There are other documentation updates sitting in the two
references above, but thinking we should go after those later in
dedicated threads for sake of clarity.
Bill P.
Subject: Re: Document -CC/+CC command line and Create_Continue_Trace_Log ini opt.
Date: 7 Dec 2016 07:39:00
Message: <584802e4$1@news.povray.org>
> option.
agreed ... i recall this feature being added but don't remember when. at
first i thought back in 3.7 when Max_Image_Buffer_Memory was added but
after looking i don't think so ... 3.7.1??
yep ... thanks
> to the section:
> or -F."
> here.
good catch ... think you're correct about -F
like what? might as well see if i can address those while i'm over there
anyways
Subject: Re: Document -CC/+CC command line and Create_Continue_Trace_Log iniopt.
Date: 7 Dec 2016 11:21:52
Message: <58483720$1@news.povray.org>
Hi folks,
Am 07.12.2016 um 13:38 schrieb Jim Holsenback:
>> option.
Just did a quick code compare: 3.7.1 it is.
Date: 8 Dec 2016 08:41:12
Message: <584962f8$1@news.povray.org>
> anyways
OK. Might be some thinking aloud on my part. Take a look at my comment to :
and specifically within that comment the block with the leader:
"Documentation indicates:"
The list starts off with a set of 4 features our documentation has as
available which are not in 3.7. I think the documentation should
probably indicate these as Deprecated for the time being.
The two undocumented features near the bottom of the block should
probably be restored to the documentation and also listed as Deprecated.
Our code allows them to exist - and they no doubt do - in old ini files.
I don't know what to do with Antialias_Gamma_type as it didn't look to
me like end users have ever seen it documented in any fashion, but
others might know differently. I'd say leave it completely out of the
documentation pending any other information.
Just below the block, in parens, I wonder about the text we have in the
documentation about the very old and long gone Buffer_output and
Buffer_Size options. Thinking it should just be deleted - yep, I missed
documenting where I saw that text...
I've used the term "Deprecated" to be consistent with other
documentation, but I believe all options marked this way are "Deprecated
and Non-functional." Perhaps we should better indicate this.
There are further questions about how our code is handling many of these
non-functioning option - you'll see I rolled a flyspray issue I think
you opened into this github issue - but I don't think this is the
newsgroup / issue in which to work those out.
I think a good first step with github #167 is to do some documentation
updates to reflect the status today.
Bill P.
Subject: Re: Document -CC/+CC command line and Create_Continue_Trace_Loginiopt.
Date: 8 Dec 2016 10:28:36
Message: <58497c24$1@news.povray.org>
Am 08.12.2016 um 14:41 schrieb William F Pokorny:
kPOVAttrib_AntialiasGammaType is just a (placeholder) companion to
kPOVAttrib_AntialiasGamma, just as kPOVAttrib_FileGammaType is a
(genuine) companion to kPOVAttrib_FileGamma. The latter two combine to
convey the information provided via the "File_Gamma" setting (with
kPOVAttrib_FileGammaType being used to convey special values such as
"sRGB"). Since "Antialias_Gamma" currently only supports float values,
the type portion is unused.
Date: 8 Dec 2016 11:35:11
Message: <58498bbf$1@news.povray.org>
http://wiki.povray.org/content/Reference:Animation_Options#Field_Rendering
http://wiki.povray.org/content/Reference:General_Output_Options#Interrupting_Options
i see from wiki history that i removed these back in sep 2013. besides
the feature listing there was also some narrative as well. rather than
restore all that and document as deprecated ... how about a well placed
"Note" instead
http://wiki.povray.org/content/Reference:File_Output_Options#Output_File_Buffer
besides the content there's only a couple of other places that need to
be touched to just get rid of it altogether ... nuke it?
i'm ok with this term mainly because it /is/ consistent with what's been
done so far ... only possible drawback is confusion with /deprecated/
keyword. as long as <code> is used when taking about keyword and <em> is
used otherwise i think we should be fine
Subject: Re: Document -CC/+CC command line andCreate_Continue_Trace_Loginiopt.
Date: 8 Dec 2016 11:37:27
Message: <58498c47$1@news.povray.org>
> "Note" instead
http://wiki.povray.org/content?title=Reference:Display_Output_Options&diff=8385&oldid=8161
Date: 8 Dec 2016 13:43:05
Message: <5849a9b9$1@news.povray.org>
Am 08.12.2016 um 17:37 schrieb Jim Holsenback:
>> "Note" instead
Still accepted on the command line and in INI files, so might bring a
short description back in. Something to the effect that
platform-specific versions /may/ use these parameters for blah-blah.
(For instance - but please don't put this in the docs - the `+Dn`
setting might be revived by some future version to choose between a
windowed (sized to image), maximized (sized to screen) and fullscren (no
taskbar and such) mode for the preview.)
Date: 9 Dec 2016 13:14:43
Message: <584af493$1@news.povray.org>
>>> "Note" instead
I couldn't pick up any note with these old eyes. I agree with Christoph
that bringing back a short description instead of the whole mess is
probably in order.
Bill P.
Date: 10 Dec 2016 09:46:31
Message: <584c1547$1@news.povray.org>
>>>> "Note" instead
> probably in order.
> Bill P.
i just went ahead and restored the whole thing and clarified the status:
http://wiki.povray.org/content/Reference:Display_Output_Options#Display_Hardware_Settings
