POV-Ray : Newsgroups : povray.bugreports : 3.8 macro parsing errors Server Time
21 Apr 2025 17:51:04 EDT (-0400)
  3.8 macro parsing errors (Message 1 to 10 of 26)
Subject: 3.8 macro parsing errors
Date: 20 Jun 2024 19:50:00
Message: <web.6674bff08a6ffbab1f9dae3025979125@news.povray.org>
I'm trying to port some c++ over to SDL so that I can use the Gamma function to
implement the version of the Beta function based on that.
original code:
https://www.johndcook.com/Gamma.cpp
Using v 3.8, I get "end of file found, but #end expected" even though I went
through the code 7+ times and every opening statement was matched with a
corresponding #end.
So I added a token #end, and got an error that it didn't recognize TestGamma,
which is a macro name.
So I set the scene to v 3.5 and got a bunch of weird ; errors
and now it's not recognizing #local declared variables.
This parser has some major problems if I can't write some simple macros.
Can anyone confirm?
debug?
provide a sane and function workaround?
- BW
PS
Also struggling a bit with
result *= y++;
I interpreted that as:
#local Result = Result * (Y+1);
(line 102)
Download 'gamma.pov.txt' (8 KB)
Subject: Re: 3.8 macro parsing errors
Date: 20 Jun 2024 23:14:32
Message: <6674f018$1@news.povray.org>
On 6/20/24 19:49, Bald Eagle wrote:
> Can anyone confirm?
> debug?
I see a few things.
The yuqk fork complains about the line with the comment "// end macro
Gamma" and there being a missing semicolon somewhere prior, but in this
case the error is somewhat miss-leading.
The parser is unhappy because that line isn't the end of the macro, but
of an #if directive. The '#end' line following is the end of the macro.
1)
		Result
         #end // end macro Gamma
Those lines should be:
	Result
2) Also in macro Gamma it looks possible by logic to go all the way
through that macro and not ever set Result. So my strong recommendation
would be to immediately set a default local 'Result' value at the top of
Gamma(), but I don't know what it should be.
3) Also in macro Gamma you have:
      #if (X <= 0.0)
         #warning concat ("Invalid input argument ", str (X, 0, 4),
		". Argument must be positive. \n")
         #break
But, seems like that needs to be an #error as your not handling Result
on the #break. You could not do that check at all then below cheat
around some potential divisions by zero by adding fudge factors but I
have no immediate idea what this means for the validity of any result.
     #if (X < 0.001)
         #local Result = 1.0/((X*(1.0 + _gamma*X))+1e-6);
and
     #local Result = Result / ((Y-1.0) + 1e-6);
4) The following line needs a semicolon:
#local Test = Gamma (0.5)
5) In TestGamma() you have the line:
#local computed = Gamma (test[T][0])
which needs a semicolon.
I hope of some help.
Bill P.
Date: 21 Jun 2024 00:20:00
Message: <web.6674fef618d864b5b1d667ae6cde94f1@news.povray.org>
hi,
> > Can anyone confirm?
> > debug?
> I see a few things.
and _then_ there's the first line:
> #version 3.1;
</grin>
regards, jr.
Date: 21 Jun 2024 05:45:00
Message: <web.66754a7118d864b51f9dae3025979125@news.povray.org>
> 1)
>   Result
> #end
>          #end
>  Result
That's because I left that extra #end in there to just try to get it to run
without complaining about the initial "missing" #end statement.
The initial configuration was just:
  Result
Then I just commented it out when I started version changing.
Yes, I had that sort of idea in the back of my head after I converted to SDL,
but without being able to run it and test it, that hardly matters.  I'd get an
obvious Lvalue Rvalue error of some sort anyway.
>       #if (X <= 0.0)
>          #break
>      #end
It was an #error, but I needed to force further parsing.
I removed that after I set v to 3.1 because the parser complained about it being
there
Same as above.
Thanks for looking - I prob won't be able to start tearing my hair out again
until late tonight or tomorrow.
- BW
Message: <web.66754b4518d864b51f9dae3025979125@news.povray.org>
> > #version 3.1;
I started with 3.8
edited
got pissed, and figured it was the lurking #local bug in macros,
set it to 3.7
then 3.5
then 3.1
which is when it started parsing differently / more thoroughly.
So that's how _that_ happened.
Hope you're doing well and staying cool,
BW
Date: 21 Jun 2024 11:35:00
Message: <web.66759c8918d864b5587c26bf123015f7@news.povray.org>
> result *= y++;
> (line 102)
The whole statement, when decomposed, can be interpreted in C/C++ as
      old_y = y ;
      y = y + 1 ;
      result = result * old_y ;
'y++' is interpreted as get the value of y, increment y by one then return the
value of y prior to incrementing it.
      #local Old_Y = Y ;
      #local Y = Y + 1 ;
      #local Result = Result * Old_Y ;
In your interpretation, Y will never be incremented ...
Date: 21 Jun 2024 11:55:00
Message: <web.6675a13a18d864b55a6710c25979125@news.povray.org>
Yes, I knew there was reason that I wasn't fully confident with what I wrote.
Thanks for the clarification - I was trying to crank out a language translation
at the end of a hot day, and getting frustrated by parser woes.
Thanks!
Hopefully I can get the rest of it sorted out to do some testing and then start
daisy-chaining everything together soon.
Date: 21 Jun 2024 13:05:00
Message: <web.6675b20218d864b5b1d667ae6cde94f1@news.povray.org>
hi,
> then 3.1
noted.  (for when it's my turn again "cursing the parser" :-))
the "heat dome" your side is making the news here too, hope you too (and WFP,
others? in the region) keep cool + hydrated.  cheers.
regards, jr.
Date: 21 Jun 2024 15:21:46
Message: <6675d2ca$1@news.povray.org>
On 6/21/24 05:40, Bald Eagle wrote:
>> 1)
>>    Result
>> #end
>>           #end
>>   Result
To my eyes and a quick check the parser was correct to complain. Without
that 'extra' #end you have a missing #end statement in the code you
posted. That 'extra' one fixed that, but Result ended up in the wrong
spot - about which the compiler is also right to complain.
I agree though, the error message is confusing. In my yuqk fork, I can
add another line of explanation making the entire error message:
Parse Error:
#declare of float, vector, and color identifiers require semi-colon ';'
at end. As do equivalent #local identifier definitions and the #version
setting. This error is sometimes issued where an #end statement
incorrectly follows a floating, defined identifier. The problem may
involve lines of prior code.
Is that error message more helpful?
I see Kelumden answered your C++ question (Thank you). Apologies. I
spaced that you'd asked it.
I'll offer up two tricks I use. One when translating from c/C++ to SDL
or playing with potential changes to the POV-Ray(yuqk) code base. The
other when trying to match all of SDL's opening directive blocks with
their #end(s).
1) For smallish questions about c/C++ code, compile and run a small
example. The whole of the recently announced f_catenary() function was
written this way prior to inserting it into the yuqk source code.
Install a C++ compiler if you've not.
For the question you asked, I'd create a file my.cpp containing:
#include <iostream>
#include <string>
int main()
     double Result = 1.0;
     int    Y      = 1;
     Result *= Y++;
     std::cout << std::endl << Result << std::endl;
     Result *= Y++;
     std::cout << std::endl << Result << std::endl << std::endl;
Compile with:
	g++ my.cpp
or equivalent. Without setting more options, the executable on unix like
systems will be 'a.out'. In a terminal window type:
	a.out
And you'll see:
1
2
Trying ++Y is an interesting experiment too.
2) When really stumped on #end matching, employ an editor which matches
braces, parens, brackets or the like. It doesn't need to be the editor
you use day to day. I'm using 'vim via gvim' on my Ubuntu machine.
Edit a temporary file called my.pov. I started by boiling the code you
posted for Gamma() down to what needs #end matching. I then added open
'{' and close '}' characters in a more or less outside -> inward order.
#macro Gamma (X) {
     #if (X <= 0.0) {
     #end }
     #if (X < 0.001) {
     #end }
     #if (X < 12.0) {
         #if (arg_was_less_than_one) {
         } #else {
         #end }
         #for (i, 0, 7) {
         #end }
         } #else {
             #for (i, 0, n) {
             #end }
         #end }
         #if (X > 171.624) {
         #end }
     #end }
#end }
When lucky, mistakes will immediately be highlighted in red. When not -
say, for example, #end(s) are in some way matching incorrectly - I place
the cursor at each opening '{' or closing '}' brace in turn. Its
matching brace will be highlighted(*) in a like color to the one at my
cursor - and I check that matching is correct for each matching pair in
turn.
Yes, I'm managing to stay cool, but one sure feels the heat & humidity
on stepping outside! :-)
Bill P.
(*) - In larger bits of code there are ways to find and move to the
currently matching brace.
Date: 21 Jun 2024 15:50:00
Message: <web.6675d90e18d864b5475732ab25979125@news.povray.org>
Ugh.  I really must have been reading straight through something.
I'll go over it again ASAP and try to see what I was missing.
> Parse Error:
Better.  I'll have to read that again when I'm encountering it during my
testing/editing.
Totally fine.   I constantly have things drop off the stack when I'm trying to
compose a long list of ideas and/or responses.
I will try some version of that - thanks!
 - BW
