POV-Ray : Newsgroups : povray.bugreports : alpha.10064268 freezes Server Time
3 Jun 2025 01:41:05 EDT (-0400)
  alpha.10064268 freezes (Message 1 to 10 of 18)
Subject: alpha.10064268 freezes
Date: 2 Dec 2019 12:20:00
Message: <web.5de5468fe9831fc7feeb22ff0@news.povray.org>
hi,
using alpha.10064268, dies with:
  Fatal error in renderer: Frontend halted render.
I'm trying to add a logo/decal to an Android model (version 4, POVCollection
#590224).
the code is taken from 'androidrobot_posed.pov', with minor modification, and
the error occurs when the pigment is uncommented.
when I reverse the order of the pigments, POV-Ray runs ok, but, of course, that
is no help.
regards, jr.
-----<snip>-----
#declare droid_ = union {
  object {
AndroidRobot_Posed(no,HeadRotate,LArmRotate,RArmRotate,LLegRotate,RLegRotate)
    pigment {ANDROIDROBOT_C_COLOR}
//    pigment {image_map {png "plate.png" once} scale .2}
    finish {
      reflection {.5 metallic}
      diffuse DIFFUSE * .5
      ambient C_AMBIENCE * .5
      specular 1.788 metallic
      roughness .05
      brilliance 1.857
  union {
    object {UserDefinedEye}
    object {UserDefinedEye scale <1,1,-1>}
    AndroidRobot_Head_x (HeadRotate)
  rotate 90 * y
  translate -ANDROIDROBOT_V_BASE
object {droid_}
Subject: Re: alpha.10064268 freezes
Date: 3 Dec 2019 04:55:00
Message: <web.5de630ae48df159ffeeb22ff0@news.povray.org>
> #590224).
> is no help.
> -----<snip>-----
>   object {
>     finish {
>       roughness .05
>       brilliance 1.857
>   union {
>   rotate 90 * y
> object {droid_}
some more information (fwiw).  same error in alpha.9945627.  without the 'once'
keyword the scene renders (but not useful since the decal repeats).
regards, jr.
Date: 3 Dec 2019 07:30:19
Message: <5de6555b$1@news.povray.org>
I've not much hobby time at the moment and what I have is going toward
other stuff. As always, having a small-ish complete scene which shows
the problem would be a help to whomever debugs.
- What happens if you leave 'once' but scale up enough to be sure the
robot is covered by the image_map-once? Don't worry about how it would
look.
- What happens with v3.7? The image_map alpha channel / transparency
handling was re-worked in v3.8 IIRC.
- Have a vague recollection of another image_map alpha channel /
transparency related issue in v3.8 too for which I don't think there was
a resolution. I don't remember details at the moment. If so, we should
find that thread and add a link here to it and visa versa.
Bill P.
Date: 3 Dec 2019 08:40:00
Message: <web.5de6653248df159ffeeb22ff0@news.povray.org>
hi,
using the scene from the collection zip verbatim, except for adding an
equivalent pigment, does illustrate the issue.
> look.
no difference in the 3.8 versions.  3.7.1-alpha.8656843 - v interesting.  using
the pigment as shown, I get the single decal but the other texture has turned
transparent and the droid looks like a weird mix of glass and (white) emissive
media.  :-)
the image is 8-bit rgb, no alpha, in case it matters.
regards, jr.
Date: 3 Dec 2019 10:17:55
Message: <5de67ca3$1@news.povray.org>
On 12/3/19 8:37 AM, jr wrote:
> hi,
Alright... So, all you did to get the crash/freeze was add a second
pigment { image_map {...}} after the first pigment {} leaving both
un-commented when you run the object collection's most current android
robot scene?
If true, this, I think, amounts to overlapped textures and it's why I
assumed your image_map would have transparency everywhere except the
'decal.' Maybe the lack of any transparency/alpha channel is tangled in
the reason for the crash? That you are sometimes getting stuff to sort
of work puzzles me too.
And apologies I wasn't clear I was interested in v3.70 (stable) over
anything after, though whatever you see with the v3.71 release is
interesting and perhaps useful to know too.
And my brain cells being earlier stirred have since remembered the other
image_map issue had something to do - I think - with adding transparency
via the 'transmit' keyword. Head also popped the question of whether the
fix for Warren's macro issue of this past April made it into the master
branch. I still have my local branch fix, so maybe not? I usually delete
my local fixes once things fixed in master.
Anyway, very likely more than a month before I'd have the time to look
at this in any depth.
Bill P.
Date: 3 Dec 2019 12:10:00
Message: <web.5de6964548df159ffeeb22ff0@news.povray.org>
hi,
> robot scene?
correct.
no problem, version 3.7.0.8 too hangs (pigment as shown).
also no problem (for me).  out of interest, what advantages does your fork have
wrt media artefacts, media in general?
regards, jr.
Date: 4 Dec 2019 06:10:01
Message: <web.5de792ee48df159ffeeb22ff0@news.povray.org>
hi,
re-rendered the name plate ("decal") with '+ua', appears to make no difference.
regards, jr.
Date: 4 Dec 2019 08:47:57
Message: <5de7b90d$1@news.povray.org>
:-) Simple question with a non-simple answer...
I've never published a merged branch of all the branches I run as 'povr'
- partly because what I run contains more branches / differences to
master than those I've published to github. Also 'povr' is meant to be a
temporal thing based on the current master branch into which continually
re-based to master branches are merged.
That said, my published solver branch addresses many artifacts media and
otherwise - and extends the range over which containers work for media.
This work though is limited to shapes using the common solvers.
There is a published branch addressing the photon media deposit banding.
I assume that was some debugging left in as I see no reason to introduce
banding except to get some visual feedback of the sampling periodicity
while developing code.
There is a published branch for one version of a change published for
jitter and adaptive media 3 which helps scene-performance up to 5%, if
your scene is media dominated and you're not using media jitter - and
one shouldn't with media method 3 unless they want noise.
Non-published branches...
I have another version of the media 3 jitter changes which is faster
still, but it's also more intrusive code wise and so more difficult to
re-base. I didn't use/re-base this branch in my last create a 'povr'
pass.
Suppose some of the recent pattern and wave modifier work touches media
too and issues fixed more likely to show up with media given the
containing shapes like isosurfaces, but also the sampling periodicity is
more likely to numerically land badly. With that last though, the
sampling, if set deep enough, probably mostly hides any wave modifier
issues.
Aside: At one time I naively thought there was an issue or two with
media, but a year plus back mentally carrying 8-10 media media artifact
causes. It's a bunch of stuff - and media turns out to be a great way to
test for underlying problems! Though, if you asked me in this moment to
list them all, I'd be hard pressed to do it. Not worked specifically on
media in a while. For me, newer work tends to push the old out of my
head - given the lack of space, the near continual wind storm and
general clutter up there... :-)
Oh, I never got to testing code, but I started a local branch supporting
a second emission specific media absorption specification/control. In a
scene Norbert posted a year or more back based on Gilles Tran's cloud
technique using scattering, emission and absorption together with media
there was color clipping due how the emission was cleverly used and this
demonstrated that media emission needs it's own media,
emission-absorption control(1).
Lastly, something not fixed in any code of which I'm aware - I tried and
failed for a fix. One needs to be sure light sources are outside any
media container, if you want all the media related controls/attenuation
to best work(2). True even if you have to cut a small void in the media
container around your lights to get this set up. See:
http://news.povray.org/povray.binaries.images/thread/%3C5a842989%241%40news.povray.org%3E/
Bill P.
(1) Or - maybe - should always internally absorb at a color matching the
emission color. This, I think, would align OK with physical behavior for
florescent media, but it would be more limiting and it would change the
look of current scenes with emissive media.
(2) I've since stumbled across a post from back in the 2000s where
someone else (Bruno Cabasson?) had discovered this issue too suggesting
the same work-around. IIRC even with the workaround we are left not
being able to turn media attenuation off in containers.
Date: 4 Dec 2019 12:15:01
Message: <web.5de7e87a48df159ffeeb22ff0@news.povray.org>
hi,
sounds like a good starting point.  artefacts seem to appear when I use
interpolation, so interested in the difference that code will make.  what is the
build/install procedure?  (sorry to use up yr time, mostly familiar with the
usual '.tar's, not "pulling" (+ merging?))
thank you for this link.  bookmarked.  much to take in.
regards, jr.
Date: 5 Dec 2019 06:40:23
Message: <5de8eca7$1@news.povray.org>
Interpolation with respect to media... Not completely sure what you
mean, but, there are directions on my wiki page at:
http://wiki.povray.org/content/User:Wfpokorny
Though the branches available are out of date on it(1). You can get a
current list of published branches on github. A graph/network view be
seen by going to:
https://github.com/wfpokorny/povray/network
and you can also see a list using the branch switching list-pick button
on the page:
You have to be in a position to build your own *nix versions of POV-Ray
If you're not, well, what I have out there today isn't going to be
useful to you.
You need to have git installed and to have a local clone of povray to
follow the pick and chose branches to merge into your personal version
of POV-Ray method on the wiki. If you are compiling via download and
just want to try a single branch, you can switch to it, download the
branch to your machine & compile normally.
Bill P.
(1) - The inability to add new links to discussion and documentation
made the wiki much less useful - and I've more or less just been letting
my pages sit as is for long time.
