POV-Ray : Newsgroups : povray.bugreports : Installation I/O error Server Time
30 Jun 2024 11:08:49 EDT (-0400)
  Installation I/O error (Message 1 to 6 of 6)
Subject: Installation I/O error
Date: 29 Sep 1998 16:25:13
Message: <36109957.8DA64D54@peak.edu.ee>
When I try to install POVWin 3.1, the instlallation always gets to 73%
(extracting povray31.hlp) and then displays the following error message:
'An I/O error occurred while installing a file. This is normally caused
by bad installation media or a corrupt installation file'
The installation then exits.
This problem only occurs on my own computer (as far as I know), and was
also present in POVWin 3.1 beta 6b. My previos version (beta 4)
installed OK.
Setting Windows in safe mode doesn't help, nor does installing to
another drive/directory.
POVWin version 3.1 and 3.1beta6b
SYSTEM: 486DX120 16Mb, Windows 95 4.00.950
Subject: Re: Installation I/O error
Date: 29 Sep 1998 17:10:25
Message: <36113E88.A79BF7C1@pacbell.net>
> installed OK.
      I had the exact same problem with my installation
and it too occured exactly at the 73% mark..
It took me about 24 hrs before I got a clean install.
Here is the crazy way I finaly got around the problem.
    In desperation to get a working copy of Pov up and
running again I went to povray.org and downloaded
the 3.1b6b version again. I attempted to install it into
a clean directory. It installed to about 25% and hung.
I then, without removing the installed files from the failed
3.1b6b installation, installed the 3.1r1 version on top
of it. It installed clean that time.
    I can't remember how many copies of Pov 3.1r1 I
downloaded and how many failed attempts I made before
I hit upon that solution. It might have been a fluke who
knows. There were several other users that reported
installation problems with the beta versions. I wonder
if there is a borderline bug in the install kit.
My system is running Win 98, a 200 mmx pentium
processor with 64 megs of ram on board.
Ken Tyler
Date: 29 Sep 1998 17:34:42
Message: <3610A99B.93CF01FC@peak.edu.ee>
Wow, U must really have tried desperately, if U invented sth. as crazy as this
My solution was more straightforward: I installed it on another computer
(PII266, Win95) and brought it home on disks - and did a lot of registry
editing.
But here's a very weird thing: in whatever way I compress it (zip, rar), I
always end up with a CRC error when extracting povwin31.hlp on my home
computer.
Just a coincidence? Or can this be caused by sth. weird in the help file?? I
am no expert.
SYSTEM: 486DX120 16MB, Win95 4.00.950
Date: 1 Oct 1998 06:07:49
Message: <36134665.0@news.povray.org>
Ken wrote in message <36113E88.A79BF7C1@pacbell.net>...
I had the same problem with 6b myself.  I simply uninstalled my previous
version and then reinstalled the new version.  It only happened once and it
was an easy fix.  I can't remember if I posted the bug or not.
Sounds familiar!  :)  I also got mine to overclock to almost 290 MHz speed
(I have a REALLY EASY BIOS CPU setup, so overclocking is a breeze).
Duane
Check out my web page.  I just started, so don't laugh too hard.
http://www.geocities.com/siliconvalley/lab/8407
e-mail me: ddt### [at] junocom
Date: 1 Oct 1998 12:22:22
Message: <36139e2e.0@news.povray.org>
Duane Tackett <ddt### [at] junocom> wrote:
:  I also got mine to overclock to almost 290 MHz speed
  And then you wonder why some programs don't work...
                                                           - Warp. -
Date: 1 Oct 1998 18:02:45
Message: <35EB1BA8.608B0F5@club-internet.fr>
I had the same problem, but after a few nervous howls i read the POV page
from which I downloaded the install file. it says :
' try turning off  your proxy (or use FTP).'
I tried, it worked, was I lucky ?
H.Fabien
> installed OK.
