POV-Ray : Newsgroups : povray.binaries.utilities : TesselSphere-1.3.0-beta release Server Time
10 Jun 2026 15:03:34 EDT (-0400)
  TesselSphere-1.3.0-beta release (Message 1 to 10 of 10)
Subject: TesselSphere-1.3.0-beta release
Date: 25 Sep 2005 03:30:01
Message: <web.4336516d7f6076ba9315fbb20@news.povray.org>
TesselSphere-1.3.0-beta for MS-Windows and Linux has been released. This
version has an new GUI for cell morphing and fixes some bugs in the Linux
version. The Linux build process now uses CMake (Windows and Mac OSX will
follow). This is a pre-release prior to version 1.4.0; feedback would be
appreciated as it has only been tested on MS-Windows-98SE and Linux
Mandrake 10.2 (Mandriva Special Edition 2005). Sources and a binary for
MS-Windows may be downloaded at URL:
http://myweb.tiscali.co.uk/oaktree/nshea/tesselsphere/download.html
N.Shea
Subject: Re: TesselSphere-1.3.0-beta release
Date: 25 Sep 2005 12:19:40
Message: <4336ce1c@news.povray.org>
"Nicholas Shea" <nic### [at] tiscalicouk> wrote...
 Thank you Nicholas - an enjoyable afternoon was had. All seems to be
working well on XPHome SP2 here.
   ~Steve~
> N.Shea
Date: 25 Sep 2005 14:35:00
Message: <web.4336ed6a111fc8949315fbb20@news.povray.org>
>    ~Steve~
Thanks for taking the time to report this Steve. Information like this is
important to me.
N.Shea
Date: 26 Sep 2005 07:20:01
Message: <web.4337d840111fc894d2a235120@news.povray.org>
> important to me.
Steve, can you tell me where you installed the prefs folder called
"nicholassheaATtiscali.co.uk" on XP Home SP2 ?
Date: 26 Sep 2005 08:31:30
Message: <4337ea22@news.povray.org>
"Nicholas Shea" <nic### [at] tiscalicouk> wrote in message
news:web.4337d840111fc894d2a235120@news.povray.org...
>> important to me.
      Yes, it's the same as win98: C:\WINDOWS\Application Data
       BTW Nicholas, I'm having a little trouble trying to save a file. When
I open the save to PovRay 3.6 box, there is already a highlighted line:
"C:/Documents and Settings/sp/Desktop/TesselSphere-Win-1.3.0-beta/" in the
filename field. If you delete this line, and then try to add your own
filename, say, tess1, you can type the 't', but when you try to type the
next letter 'e', it will add the same line again for every key-stroke, so
you end up with something like this if you're not looking:
"C:/Documents and
Settings/sp/Desktop/TesselSphere-Win-1.3.0-beta/C:/Documents and
Settings/sp/Desktop/TesselSphere-Win-1.3.0-beta/te"
   If you just add your filename to the end of "C:/Documents and
Settings/sp/Desktop/TesselSphere-Win-1.3.0-beta/tess1", then, when it's
compiling all the vertices and lines co-ordinates etc., it will crash the
program when it gets to "Making Cell edges unique[pass2]"  - but then the
file is still saved, (incompletely? On checking, it does end in "#end").
     ~Steve~
Date: 26 Sep 2005 09:55:01
Message: <web.4337fc5d111fc894d2a235120@news.povray.org>
> >> important to me.
>       Yes, it's the same as win98: C:WINDOWSApplication Data
> "C:/Documents and
>      ~Steve~
Hi Steve.
The FLTK file chooser widget can be little strange when first coming
from windows. If the text below is not immediately obvious, I have
taken some screen shots which you can download from here:
http:://myweb.tiscali.co.uk/oaktree/nshea/tesselsphere/download/filesave-pics.zip
When saving a file, the current path (usually the TesselSphere app)
is already highlighted in the path field of the Save Dialogue.
Click after the path and start typing the name of your file.
As you type, the dialogue will try to auto-complete the file name if
it finds a match in the current directory.
Keep typing until the filename is unique.
You can click on the path-buttons to navigate the file system or...
Add the path to the favourites for next time.
WARNING: There is no check for a file with the same name yet! I know this is
pretty awful. Make sure your file has a unique name or an existing file
with the same name will get over-written.
The saved INC file should end with the auto initialization macros.
They look like this:
// #include auto initialization
// including this file will auto initialize the Polyhedron data:
TS_Init_Vertces()
TS_Init_Vertces_Array()
TS_Init_Centrum_Vertices()
TS_Init_Centrum_Vertices_Array()
TS_Init_Apex_Vertices()
TS_Init_Apex_Vertices_Array()
TS_Init_Cell_Arrays()
TS_Init_Edges_Array()
A successful save should be reported in the log window. Eg:
Wrote file: C:/my-docs/dev/tesselsphere-mingw-1.3.0/tesselsphere/test.inc
   Vertices: 3366
   cells: 908
   unique edges: 3372
Make sure you are using the 1.3.0-beta.
There was a bug when saving files that was introduced in a previous version
but I thought I'd fixed it. If you can repeat the bug with 1.3.0-beta,
please let me know the details so I can try to replicate it. Thanks for
your time in reporting this.
It is great to get genuine feedback :) I sometimes wonder if my site is
really public at all!
Best wishes
N.Shea
Date: 29 Sep 2005 07:13:15
Message: <433bcc4b@news.povray.org>
news:web.4337fc5d111fc894d2a235120@news.povray.org...
> "St." <dot### [at] dotcom> wrote:
> Hi Steve.
   Hi Nicholas - sorry for the delay, it's been one of *those* weeks at
work!  ;)
   Thanks, got that. Yes, I didn't realise it was doing the autocomplete
thing. Like you've said, I just add a unique filename now, and that works
fine.
> filesave1.jpg...
   <snip>
> TS_Init_Vertces()
   Well, I definately wasn't getting this...
>   Vertices: 3366
>   cells: 908
>   unique edges: 3372
   ...or this. (But I'm getting it now on simple files).
     Yes, definately.
> version
     Glad to at least try and help - I'm no programmer, so please bare with
me, and I'll help if I can. If you want me to do anything specific, then
just fire away with what you want.  :)
     Ok, first of all, here's my setup if it's of any use to you:
       XP Home Edition (5.1, Build 2600) Service Pack 2
       AMD Duron(tm) Processor ,  MMX,  3DNow, ~600MHz
       512MB RAM
       NVIDIA GeForce FX 5700LE
   I've had a good play with Tesslesphere this morning, and I've noticed a
couple of things. When I first started playing with it earlier this week, I
think I was a little too impatient and not giving TS a chance to do its
thing after clicking around on various buttons, which is why all of a
sudden, it would just disappear from the screen, (literally, it would just
disappear without any warning). So I learnt to watch the FPS field and let
it go up to around the 40 to 50 mark - that helped a lot.
    The other thing that I found was that TS will save a simple file, but
won't save a complicated file, (even after doing the above). I don't know
what a 'complicated' file is when using TS, but I've uploaded a screenshot
so you can at least see what will cause TS to crash when trying to save a
file: http://website.lineone.net/~25ct/test.htm
    Again, this crashed TS as soon as it got to the "Making Cell Edges
unique [pass2]" stage. It also took about thirty minutes to get to this
stage, so would this be normal? I'm thinking it might be my setup, and maybe
it's not powerful enough?
     ~Steve~
> Best wishes
> N.Shea
Date: 29 Sep 2005 10:30:00
Message: <web.433bf64b111fc89454c8fa520@news.povray.org>
<*snip*>
Thanks Steve :)
>        512MB RAM
It's always helpful to know how the program is being used and on what
system.
Hmmm... seems like a crash. I'll upload a degug version for windows so you
can trace out what's going on. I'll also code a progress box for big data
sets to give more user feedback.
> So I learnt to watch the FPS field and let  it go up to around the 40 to
Thanks for the screen shot. I managed to export this to an INC file on Linux
using TesselSphere 1.3.3. I can send it to you, but please read on...
Your set up is well powerful enough. But even so, that's a pretty big file:
you are trying to export 14400 cells; the _ts_V array alone contains 41400
vertices. One way round this is to just export a single geodesic particle.
You can then write POV macros that use the symmetry of the system to rotate
the particle to other locations on the sphere. I will update the POV-Macros
so that you can do this. Of course, 30 minutes to export a file is not
normal. The reason for the delay is outlined below...
The problem you are experiencing with big data sets is due to TesselSphere's
INC file export code and the internal data representation. TesselSphere does
not yet use indexed cells, so it has to generate all the indices to the
vertex array when saving the INC file. This ensures that only unique
elements are stored in the _ts_V array. This delay does not occur with VRML
export as no indexing takes place.
Right now, INC file export delays with large data sets is a limitation in
the program and one I will endevour to overcome. I would really like to
thank you for your time in reporting this. User feedback is important; I
know TesselSphere's quirks, so when using it, I don't attempt the things
that others might.
Best wishes
N.Shea
Date: 30 Nov 2005 10:00:00
Message: <web.438dbd08111fc8943d35d84a0@news.povray.org>
<snip>
Hello Steve,
I have been working to correct the issues you raised in your last post. (I
sent you two e-mails but they bounced back - so I'm hoping you get this). A
32V Class I geodesic sphere now exports to a POV INC file in 40 seconds
(all class triangles). Convex hull generation now has progress bar for
large data sets. Implemented truncation/spherical range adjustment
(geodesic module only).
You can see how this works here:
http://myweb.tiscali.co.uk/oaktree/nshea/tesselsphere/geodesic/trunc_tutorial_1.html
If you are still interested in testing the program, I can post you a pre-1.4
beta. (Any further communication is probably best kept off this group). Your
time and interest has been greatly appreciated.
Best wishes,
N.Shea
Date: 20 Aug 2008 15:50:00
Message: <web.48ac7436111fc894c300b2600@news.povray.org>
Steve
Im new to POV-Ray community and have noticed your correspondance with Nicholas
Shea over TesselSphere.  I have looked for this application for some time and
all links are dead ends.  Nicholas' own site at tiscali.. had diappeared as
well as all the links to source on OpenGL forum.
You were discussing running Window's XP version.  Did you succeed?  And have you
maintained correspondance with Nicholas?   I'm interested in getting a copy of
this program (also XP) for some research I am doing.
Any advice or suggestions would be greatly appreciated.
Ed Popko
> >> important to me.
> "C:/Documents and
>      ~Steve~
