![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: POV-Ray 3.5 makefile for Inprise (Borland) free command-line tools
Date: 3 Oct 2002 18:19:45
Message: <3D9CC349.8080502@starman.ee>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As subject says :-) File contains readme file with detailed instructions.
Download 'borland.zip' (5 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: POV-Ray 3.5 makefile for Inprise (Borland) free command-line tools
Date: 3 Oct 2002 19:34:16
Message: <3d9cd3f8$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wow! Talk about detailed. That's a lot of work to get POV to compile. I'm
about to try it out. Thanks in advance for all the hard work you put into
this, Vahur! I know I wouldn't have had the time or knowledge to do it all
alone.
Anthony Bennett
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 3 Oct 2002 23:31:14
Message: <3d9d0b82@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Success! Thank you!! :-D
Anthony
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 4 Oct 2002 15:29:35
Message: <3D9DECEA.6090907@starman.ee>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
De nada!
But if You think, that mere 'Thank you' is sufficient, then think again!
Now You have to provide some investment return (i.e. patches, defect
corrections etc.)!
j/k, of course:-)
But seriously talking I'd like to know, whether there were omissions or
shortcomings in documentation or makefile in order to improve them. I
finished this ca. 1.30 AM (4 hours past usual bed-time!!!, but I got hit
by this can't-stop-before-finished flow!) and I'm not very sure, that
readme is quite readable or understandable by others. So if you have (or
someone else has) suggestions or corrections, then I'd like to hear them!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 4 Oct 2002 18:16:13
Message: <3d9e132d$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> corrections etc.)!
Of course! That was the whole point of compiling POV. :) It will be a long
time before you see anything from me, though. The code looks perfect to my
inexperienced eyes, so rather than trying to optimize what they've got there
right now, I'll be doing research into (dare I say) better algorithms which
produce at least equally good results. Wish me luck! :)
Only thing that I had to do was find htmlhelp.lib and winmm.lib. I used
implib (as per a suggestion on some site I've lost the URL to) to extract
winmm.lib from system32\winmm.dll. Oh, and I renamed it .obj. I have no idea
whether this is good or bad, all I know is that POV compiled and hasn't
crashed yet... It's just very slow compared to the official binary. About
half speed. :(
Anthony
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 5 Oct 2002 05:44:53
Message: <3D9EB55E.700@starman.ee>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> crashed yet...
Which Windows version you have? In my system (W2K) there was no need for
winmm.lib.
> half speed. :(
You get what you pay for: Inprise compiler does not produce so good
code, as MS, Intel or gcc. Did you compiled optimized version of it? By
default makefile has debug compiler flags (without any optimization) in
order to make debugging easier. Although to me it seems, that these
optimizing flags do nothing, it will produce code, which has same speed :-(
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 04 Oct 2002 22:32:58 +0300, Vahur Krouverk <vkr### [at] starman ee>
I will check it. Thank for your effort.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 4 Oct 2002 18:16:01 -0400, "Tony[B]" <ben### [at] catholic org> wrote:
> crashed yet...
That's wrong IMO. I have thought about that problem and found the reason.
First of all You don't have to extract winmm.lib from dll. It is already
present in free borland but not in main LIB\ but in subfolder LIB\PSDK.
And you don't have to rename it to obj. It can be linked directly as
winmm.lib. Just make optional two pragmas from pvengine.c.
#ifndef __BORLANDC__
#pragma comment(lib, "htmlhelp")
#pragma comment(lib, "winmm")
#endif
> half speed. :(
Exactly. Standard benchmark started on Win95 with PII 233 128 MB
POVWin - 13h 51m 14s
PoPOVWin - 7h 00m 24s
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 27 Oct 2002 03:33:42
Message: <3DBBA4F0.1090602@starman.ee>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>crashed yet...
> #endif
I looked at my code and I stand corrected in my previous statement (_In
my system (W2K) there was no need for winmm.lib._): as it appears, i've
commented out both pragma directive lines in pvengine.c and therefore it
linked OK in my case. So best solution for given problem would be indeed
to make these pragmas conditional as above.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Sun, 27 Oct 2002 10:33:52 +0200, Vahur Krouverk <vkr### [at] starman ee>
Vahur, since you are only brave to play with free borland compilation process,
would you like to try prepare compilation of povcmax2.dll and cmedit.dll using
notes written in $(POV35winsrc)\windows\readme.txt ? Is it mission imposible
with free borland ?
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
