POV-Ray : Newsgroups : povray.binaries.utilities : Smooth transitions between CSGs ...Chris Colefax? Server Time
4 Dec 2025 22:45:38 EST (-0500)
  Smooth transitions between CSGs ...Chris Colefax? (Message 1 to 4 of 4)
Subject: Smooth transitions between CSGs ...Chris Colefax?
Date: 19 Apr 2000 09:26:52
Message: <38fdb41c@news.povray.org>
I have created several complex models (deeply nested CSGs) wherein the
smooth transitions between CSGs would greatly enhance the models.
Please refer to my posting of "Old Typewriter" in  the
povray.binaries.images and
Tor Olav Kristensen's posting in the same newsgroup entitled "playing with
CSGs".
I can't help thinking that Chris Colefax might get stirred up by these
possibilities as well as other such talented "POV-Ray" "plug-in" writers.
I am fairly advanced at playing around with the includes and placement of
such work in the POV-Ray scene language, unfortunately ...being more
artistically inclined, I have more of an aptitude for application of this
stuff ...not writing it.
What are the possibilities? ...or are there just too many possible variables
involved?
Having worked extensively in mesh based modelers, I can see the restrictions
in trying to create smooth transitions between primitives and CSG objects in
general. Meshes do not  have this problem, however, they never have those
remarkably smooth surfaces as rendered by primitives. Such a plug-in would
greatly enhance the possibilities of the POV-Ray rendering engine!
Geoffrey
Subject: Re: Smooth transitions between CSGs ...Chris Colefax?
Date: 19 Apr 2000 20:29:37
Message: <38fe4f71@news.povray.org>
> CSGs".
variables
> involved?
restrictions
in
The ability to smooth off CSG transitions has actually been suggested to me
a number of times in the past, and I agree that unwanted sharp edges can
detract from otherwise excellent CSG models.  As Howie and others have shown
blobs can be extremely powerful, but they aren't always suitable for
accurate work, involving planes and such.
There are a couple of solutions I can think of - I haven't checked out Tor's
work, but with the right maths many cases could conceivably be handled using
spheres, cylinders, and torii for the transitions.  I can imagine, though,
that this would get fairly complicated fairly fast(!), and might end up
adding a lot to the memory requirements of a scene (e.g. a simple box
smoothed using CSG requires 23 objects or more, depending on the method
used).
Using modified normals might offer a solution, but applying the right
perturbations to just the transition areas would also be very complicated,
and you'd still have the usual sharp shadow problems, etc.
It seems to me that the best solution, then, would be a procedural method
handled at trace-time.  This would work similar to blobs, with each object
having a threshold extending either side of its surface.  Surfaces outside
of these threshold intersections would be rendered as per normal CSG (giving
accurate placement), but where thresholds do intersect they would be
averaged like blobs to give a smooth transition.
Finally, I believe Chris Huff has done some work along these lines, using
isosurfaces.  His messages should still be accessible on the server, as
should he...
Date: 20 Apr 2000 06:16:41
Message: <0nltfscvastl9feui866gcr0ijs2njngus@4ax.com>
On Thu, 20 Apr 2000 10:44:36 +1000, "Chris Colefax"
This looks like an intersting way to attack the general case Chris. There would
be problems where you have a surface with several intersections, some of which
you would like to be smoothed and others where you would like a sharp edge or
internal corner, nevertheless, a capability like this would add a very useful
capability to CSG.
David
dav### [at] hamiltonitecom
http://www.hamiltonite.com/
Date: 20 Apr 2000 07:53:47
Message: <chrishuff_99-0AF1F5.06563720042000@news.povray.org>
In article <38fe4f71@news.povray.org>, "Chris Colefax"
> should he...
Hmm, I haven't done anything directly related to this...but my proximity
pattern could do the job easily. I wouldn't use it directly, it is too
slow, but it would be simple to use it with eval_pattern() to write data
into an array or a file(preferably a file, so you don't have to
recalculate it every time you parse the file) and use that as the input
for an isosurface.
Another possibility would be to use the blob pattern. It currently only
supports spheres and cylinders, but could easily be extended to do
toruses, cones, boxes, etc...even isosurface functions could be
included. It doesn't require the 3D density stage, it is fast enough
as-is(although there are some optimizations that could be done). I got a
nice "corroded metal" look by using turbulence on the blob pattern in an
isosurface.
And finally, you could use Lummox JR's isoblob patch, which is kind of a
cross between isosurfaces and blobs. I haven't done anything with it,
but it looks quite good.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
