POV-Ray : Newsgroups : povray.binaries.scene-files : Re: Imitated Bricks Server Time
25 Mar 2026 08:35:41 EDT (-0400)
  Re: Imitated Bricks (Message 1 to 10 of 20)
Subject: Re: Imitated Bricks
Date: 5 Jun 2015 17:51:43
Message: <557219ef@news.povray.org>
Am 05.06.2015 um 23:39 schrieb clipka:
> Am 04.06.2015 um 23:17 schrieb Reuben Pearse:
>> I would like try some more UberPov renders using the LDraw models that
>> I've
>> already converted to POV-Ray - could you share the full code for your
>> example picture.
Here are the files that make up the scene. I might have made some minor
changes by now.
NOTE: The include file "lego_colors_.inc" is NOT INTENDED FOR FURTHER
DISTRIBUTION without my explicit consent. There are reasons I don't want
it to be spread around outside this newsgroup.
Download 'windows-1252' (8 KB) Download 'us-ascii' (44 KB)
Date: 9 Jun 2015 01:41:33
Message: <55767c8d$1@news.povray.org>
Thanks for the files.
I've tried rendering them using UberPOV, but I'm getting a really "grainy"
image. I'm guessing it's to do with the radiosity settings (or the
subsurface settings?).
Do you have the details of the final render settings you used for your
image?
Thanks
Reuben
"clipka" <ano### [at] anonymousorg> wrote in message
news:557219ef@news.povray.org...
>>> I've
>>> example picture.
> changes by now.
Date: 9 Jun 2015 02:12:39
Message: <557683d7$1@news.povray.org>
Am 09.06.2015 um 07:41 schrieb Reuben Pearse:
> image?
No, I don't recall what settings I used; but the highest-quality
settings suggested in the comments (+am3 +r9 +a0.002 +ac0.99) should
kill the graininess in any image(*).
(*unless it's /designed/ to be grainy, of course ;))
Date: 12 Jun 2015 02:18:50
Message: <557a79ca$1@news.povray.org>
Thanks - that's done the trick (the image is still rendering!)
I'm gonna try rendering some of the models I've converted from LDraw using
your technique.
I've got my own version of the lego colours based on the POV-Ray code
generated by this site:
http://guide.lugnet.com/color/
news:557683d7$1@news.povray.org...
>> "grainy"
>> image?
> No, I don't recall what settings I used; but the highest-quality settings
> suggested in the comments (+am3 +r9 +a0.002 +ac0.99) should kill the
Date: 5 Sep 2015 23:42:50
Message: <55ebb63a$1@news.povray.org>
Have you made any progress, Reuben? Have you made the finishes work with
L3P or LDView's POV-Ray output?
Michael
Date: 5 Sep 2015 23:44:45
Message: <55ebb6ad$1@news.povray.org>
You have two different global_settings blocks in your code. Is that
intended? Do they interfere with each other?
Michael
Date: 6 Sep 2015 01:37:09
Message: <55ebd105@news.povray.org>
>> "grainy"
>> image?
Is this the only way to get rid of the speckles? The render is
unfortunately taking too long at the highest quality settings.
Michael
Date: 6 Sep 2015 08:24:26
Message: <55ec307a$1@news.povray.org>
Am 06.09.2015 um 05:44 schrieb Mike Horvath:
The first global_settings block is just for the assumed_gamma setting,
so that using the srgb keyword in colors_lego_.inc doesn't give warnings
or errors.
I have a habit of placing #include statements as early as possible in
any file, so the remainder of the global settings goes in a second
global_settings block.
POV-Ray is perfectly fine with multiple global_settings blocks,
especially if they contain entirely different settings as in this case;
if one setting would appear in both blocks, the second one would
generally win (but until then the first one might have an influence on
parsing).
Date: 6 Sep 2015 08:32:51
Message: <55ec3273$1@news.povray.org>
Am 06.09.2015 um 07:37 schrieb Mike Horvath:
>>> "grainy"
>>> image?
I presume you're talking about noise-like speckles.
Generally speaking, there is no way around those speckles except for
shooting more rays. The most simple solution to achieve this is indeed
to use "anti-aliasing" mode 3 and increase its quality settings, but
there are other places to tweak:
- If the grainy speckles appear to be related to radiosity, increasing
the radiosity "count" parameter might be a more efficient way to reduce
the speckles. Note that you can also use the radiosity importance
mechanism in this case.
- If the grainy speckles appear to be related to subsurface scattering,
increasing the subsurface sample count might be a more efficient way to
reduce the speckles.
Date: 7 Sep 2015 01:26:03
Message: <55ed1feb$1@news.povray.org>
> parsing).
That's good to know.
