POV-Ray : Newsgroups : povray.binaries.scene-files : Wind pattern code and reed stalk example Server Time
18 May 2024 01:00:28 EDT (-0400)
  Wind pattern code and reed stalk example (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Wind pattern code and reed stalk example
Date: 21 Sep 2014 09:45:01
Message: <web.541ed590825f35c27a3e03fe0@news.povray.org>
> OK. How about this?
Thanks, I will understand.
I doubt that I will be able to study it. :(
Date: 21 Sep 2014 10:25:25
Message: <541edfd5$1@news.povray.org>
On 21-9-2014 15:41, LanuHum wrote:
>> OK. How about this?
Don't hesitate to ask if in doubt, though.
Date: 21 Sep 2014 11:40:01
Message: <web.541ef117825f35c27a3e03fe0@news.povray.org>
> > Thomas de Groot <tho### [at] degrootorg> wrote:
> >> OK. How about this?
> Thomas
Thanks!
Problem in English which I don't know.
I translate your messages, using an online translator of an intenet.
Therefore it is difficult to understand even an overall picture:
Why HF how HF influences mesh is used is a secret.
I still will try to study example.
Probably, time is necessary to understand.
I will ask questions if I will be able to start understanding though something.
Date: 22 Sep 2014 03:19:34
Message: <541fcd86$1@news.povray.org>
I think those are basic concepts, also in Blender?
The /normal/ of a point on a surface is the vector /perpendicular/ to
the surface (see also the Docs: paragraph 2.3.5.2). Using trace() you
can get the normal at a certain point. Knowing the normal, you can
calculate the angle it makes with a horizontal plane, or the angle it
makes with another vector around an axis.
Date: 22 Sep 2014 13:10:01
Message: <web.5420573b825f35c27a3e03fe0@news.povray.org>
> Thomas
Thomas,thanks.
I started understanding your mechanism.
But, I had an idea to use means of Blender (force field : wind) to do without
excess mathematical calculations.
Wind is applied to particles, but there is no realistic bend
It is necessary to find only the solution of a realistic bend of a trunk of a
plant also means of Blender
Download 'force_field_wind.jpg' (99 KB)
Preview of image 'force_field_wind.jpg'
Date: 22 Sep 2014 13:35:20
Message: <54205dd8$1@news.povray.org>
On 22/09/2014 18:07, LanuHum wrote:
> Thomas,thanks.
Just a suggestion LanuHum,
Can Blender apply wind to cloth?
Can you create a stalk as a "cloth" with only 2 degrees of freedom and
very stiff?
If so then you can apply "wind" to the "clothified"* stalk.
*Using Poser terminology.
Regards
Date: 22 Sep 2014 15:15:00
Message: <web.5420749d825f35c27a3e03fe0@news.povray.org>
Yes.
> very stiff?
I don't think that such option will be real for a large number of triangles. The
scene will be very heavy.
I am inclined to use only data, to process and write down the file
Date: 22 Sep 2014 15:40:49
Message: <54207b41@news.povray.org>
> Yes.
>> very stiff?
Fair enough. It was just a thought.
Keep up the good work. :-)
Regards
Date: 23 Sep 2014 03:17:08
Message: <54211e74@news.povray.org>
On 22-9-2014 19:07, LanuHum wrote:
> Thomas,thanks.
Ah yes, that is an idea. Like Stephen suggested, something Poser also
does. Only thing indeed is the bending.
It seems to me, looking at your image, that the rate of bending should
be inverted. What I mean is this: Now, the angle goes from high at the
start to gradually low towards the top, producing a concave-up bending
shape. Could you /invert/ the calculation for this? Thus making a
convex-up bending shape?
Alternatively, can you make the wind power in Blender to increase upwards?
Date: 23 Sep 2014 12:45:01
Message: <web.5421a2c0825f35c27a3e03fe0@news.povray.org>
> Thomas
If to use sphere_sweep probably it is possible to reach desirable result of a
bend.
It is necessary to study influence of several wind modifiers for increase in
wind power from above.
If the result is effective then it is necessary to think of leaves. :)
Download 'force_field_wind_render.jpg' (95 KB)
Preview of image 'force_field_wind_render.jpg'
