POV-Ray : Newsgroups : povray.binaries.programming : An updated povr tarball for Unix/Linux. f6b1c13e Server Time
14 Dec 2025 14:24:02 EST (-0500)
  An updated povr tarball for Unix/Linux. f6b1c13e (Message 6 to 15 of 45)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: An updated povr tarball for Unix/Linux. f6b1c13e
Date: 21 Jul 2020 11:50:00
Message: <web.5f170d79f6dfcecf4d00143e0@news.povray.org>
hi,
"jr" <cre### [at] gmailcom> wrote:
> right, and now we're getting to the bit where it gets .. strange.  :-)
ignore.  the problem was the symlinks in /usr/include not pointing to the
correct headers.  :-(  re-built 'povray2' and all three test scenes ok.
regards, jr.
Date: 29 Jul 2020 14:20:00
Message: <web.5f21bcf7f6dfcecf4d00143e0@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> Sure. You can continue to use any names you want for function and macro
> parameters. The _<lower> is the suggestion because it won't collide with
> future SDL keywords where some other lower case string might eventually
> - though probably not a_ :-).
I find I'm not .. getting on with the forced uppercase stuff (sorry), and would
prefer to go back to the first version you posted.  regarding that, I did a
'diff' on the respective 'vfe/unix/unixconsole.cpp' files, is the 'XInitThreads'
call (including surrounding conditional) the only thing that would need to be
added to allow the _f9bc4ef7 version to function safely wrt X11?
regards, jr.
Date: 30 Jul 2020 19:31:19
Message: <5f235847$1@news.povray.org>
On 7/29/20 2:16 PM, jr wrote:
Just back from a few days at real life. Back at povr for real tomorrow -
or the day after. Ahead of me getting back...
Could you be more specific?
Povr breaks compatibility with as little as possible - but still quite a
lot. My aim is to keep behavior near v3.8, but there is certainly more
compatibility breakage to come. Is it more than wanting to continue to
use lower case and/or includes which already have lower case?
Are there actual conflicts/problems with the approach; or examples where
it's very inconvenient?
The functionality is still hacked in - because I'm trying it too. :-)
But, thus far, I'm liking the behavior. In fact, I recently fixed a miss
with command line declares letting lower case declare IDs still happen.
That said, I've not run much old stuff with it as yet. Plus, suppose I
wasn't in the habit of using lower case locals/declares to begin with.
Our SDL usage is different. I've not much jumped on the newer array,
dictionary stuff, for example, mostly because it came well after my tcl
wrapper - which already had that functionality.
As safely as the newer release, yes.
There are other fixes and improvements relative to the prior release
you'll be missing in using the first, but stuff should work except where
there was already incompatible change - ie fog, inbuilt functions,...
Bill P.
Date: 30 Jul 2020 20:45:00
Message: <web.5f236956f6dfcecf1f9dae300@news.povray.org>
Is it possible, and is there a security issue related to providing a means to
create a subdirectory in a write-permitted directory?
#write creates a file.  Can we create a directory by a similar means?
Just something to think about.
Date: 31 Jul 2020 04:25:00
Message: <web.5f23d42df6dfcecf4d00143e0@news.povray.org>
hi,
no, for me it's just[*] the lower/uppercase stuff.  basically, each of my old
scenes I tried, failed.  I thought about modifying scene code, but since they
work I'll find it easier not to use (the new version of) 'povr'.
[*] at present.
just inconvenient.  eg, to "fix" the scene I used when I ran into the X11
animation issue, would be a lot of work, made worse by the fact that I got that
scene from the web, ie it's not even my code.
cannot say the same.  guess I'm "allergic" to uppercase.  :-)
(could this behaviour be enabled/disabled via a 'povray.conf' setting instead?)
thanks, I'll try that then, sometime this weekend.
regards, jr.
Date: 31 Jul 2020 10:45:00
Message: <web.5f242c92f6dfcecf4d00143e0@news.povray.org>
hi,
have been thinking about (wishing for) for a 'system()' type function for a long
time.  but reading the above made me realise that a modified '#fopen' which
supports command pipelines, aided by a new OPEN_TYPE for r/w access could do
"everything" anyway.  then we could write, eg:
#fopen FP "| program" rdwr
to communicate with 'program', making creating a directory, all sorts of stuff,
easy and convenient.  for instance write some calculated parameters to 'program'
and read back new, derived values.
regards, jr.
Date: 31 Jul 2020 12:55:21
Message: <5f244cf9$1@news.povray.org>
Le 31/07/2020 à 16:40, jr a écrit :
> hi,
"Danger Will Robinson"
This could lead to some system corruption... A reason that there is
already io-restrictions: to protect the innocent.
You already have "shell-out" capability, with pre & post, scene & frame
level, so grouping actions should be doable to have all you need.
http://wiki.povray.org/content/Reference:Shell_Command_Options
Date: 31 Jul 2020 13:55:00
Message: <web.5f245a77f6dfcecf4d00143e0@news.povray.org>
hi,
> > ... but reading the above made me realise that a modified '#fopen' which
:-)  true.  otoh, the imagined '|program' form of '#fopen' could be made subject
to the same '[Shellout Security]' setting as the pre/post commands.
also true, I guess, that those commands can be used to do "everything".  still,
there are differences.  for instance, now, if I need to pass multiple/many
calculated values to 'program', I have to write a temporary file to be processed
by 'program', and then read the results on the next frame.  a modified '#fopen'
would allow a different programming style, and would in the example obviate the
need for temporary file(s) and animation control.
regards, jr.
Date: 31 Jul 2020 18:30:02
Message: <web.5f249b3ef6dfcecf4d00143e0@news.povray.org>
hi,
> Please find attached an updated tarball.
ran into a problem with some code I was sent.
==== [Parsing...] ==========================================================
#include "spheresweep.inc" //version 1.2
File '/home/jr/POVr/share/povray-3.8/include/shapes.inc' line 20:
Possible Parse Error:
Cannot find file 'Wrapper.inc', even after trying to append file type extension.
Parse Error:
Cannot open include file Wrapper.inc.
Fatal error in parser: Cannot parse input.
Render failed
regards, jr.
Date: 31 Jul 2020 19:20:01
Message: <web.5f24a5f6f6dfcecf1f9dae300@news.povray.org>
> Parse Error:
> Render failed
That's a _weird_ error, especially since line 20 of shapes.inc is
#include "shapes_old.inc"
And there's no reference to 'Wrapper.inc' in either file.
Maybe if you have a reference to that, just comment it out?
