![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi.
I have a question for you, well, I'm developing a ray-tracing program and
I need help with the aspect of the memory allocation. I define my objects in
special structures, each object is allocated in memory dynamically, you
know, with memalloc and free, but the question is: How can I optimize this?,
I want to use the less memory possible, because with objects like mesh or
series of thousand objects consumes a lot of RAM memory, I don't know how
POV-Ray uses the memory to its objects, but certainly it can trace scenes
with a lot of complex objects without problem...
Should I put everything in memory?, primitives, mesh, textures, etc. or
exist a technique to use more efficiently my resources.
Thanks for your time and patience.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You didn't mention the programming language you are using ('memalloc' is
not a C nor C++ function; at least not a standard one).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorry, malloc is the function, I'm writting my program in C, but what I want
to know is the Algorithm or procedure to distribute the memory, for example:
sphere needs 3 coordinates for the center and a radius, each variable takes
4 bytes of memory, well, I need 16 bytes for a sphere, but for a box I need
24 bytes...
sphere 16 bytes
box 24 bytes
cone 28 bytes
cylinder 28 bytes
plane 16 bytes
torus 8 bytes
this are without transformations, they need more memory, that's the problem,
my memori not is infinite
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
majucatur wrote:
> Hi.
If you want to render more geometry than fits into memory, then only
option is to cache it (if you don't want to leave it to op. sys. swapping).
One paper I know about it could be found:
http://graphics.stanford.edu/papers/displace/
Google should help in finding similar papers.
Other option is to optimize geometry. Latest Siggraph papers ('00 IIRC)
have number of various optimizations described.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> 24 bytes...
So in 10 Megs of memory you can store almost 437000 boxes. I don't see
the problem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> box 24 bytes
so you use only 4 bytes for the float number storage?
IMHO a box needs 6 float parameters to be defined...
regards
SY
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In fact, 2 is enough. See the box syntax for an example. (Of course with
2 floats it's axis-aligned, but that doesn't matter; the transformations of
a box are not made by moving its vertices anyways.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
floats or vectors?
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
of
how do you define a box with 2 floats? even length, height and depth would
already need 3!
regards
SY
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ron Parker <ron### [at] povray org> wrote:
> floats or vectors?
Floats. (Of course that will create a cube, but as I said, transformations
can make it a box of any shape, and place and orient it in any way.)
Thinking about it, it actually doesn't need any floats at all. Just
create a unit-cube by default and let the transformations do the rest.
So in fact it requires 0 floats.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
