POV-Ray : Newsgroups : povray.binaries.programming : POV Memory Server Time
6 Jul 2026 19:49:13 EDT (-0400)
  POV Memory (Message 1 to 10 of 21)
Subject: POV Memory
Date: 21 Feb 2002 16:51:22
Message: <3c756bda@news.povray.org>
Hi.
   I have a question for you, well, I'm developing a ray-tracing program and
I need help with the aspect of the memory allocation. I define my objects in
special structures, each object is allocated in memory dynamically, you
know, with memalloc and free, but the question is: How can I optimize this?,
I want to use the less memory possible, because with objects like mesh or
series of thousand objects consumes a lot of RAM memory, I don't know how
POV-Ray uses the memory to its objects, but certainly it can trace scenes
with a lot of complex objects without problem...
   Should I put everything in memory?, primitives, mesh, textures, etc. or
exist a technique to use more efficiently my resources.
Thanks for your time and patience.
Subject: Re: POV Memory
Date: 22 Feb 2002 03:04:40
Message: <3c75fb98@news.povray.org>
You didn't mention the programming language you are using ('memalloc' is
not a C nor C++ function; at least not a standard one).
Subject: RE: POV Memory
Date: 22 Feb 2002 13:09:57
Message: <3c768975@news.povray.org>
Sorry, malloc is the function, I'm writting my program in C, but what I want
to know is the Algorithm or procedure to distribute the memory, for example:
sphere needs 3 coordinates for the center and a radius, each variable takes
4 bytes of memory, well, I need 16 bytes for a sphere, but for a box I need
24 bytes...
sphere    16 bytes
box          24 bytes
cone        28 bytes
cylinder   28 bytes
plane       16 bytes
torus          8 bytes
this are without transformations, they need more memory, that's the problem,
my memori not is infinite
Date: 22 Feb 2002 19:58:55
Message: <3C76EA1E.2060303@comtrade.ee>
majucatur wrote:
> Hi.
If you want to render more geometry than fits into memory, then only
option is to cache it (if you don't want to leave it to op. sys. swapping).
One paper I know about it could be found:
http://graphics.stanford.edu/papers/displace/
Google should help in finding similar papers.
Other option is to optimize geometry. Latest Siggraph papers ('00 IIRC)
have number of various optimizations described.
Date: 23 Feb 2002 13:25:19
Message: <3c77de8f@news.povray.org>
> 24 bytes...
  So in 10 Megs of memory you can store almost 437000 boxes. I don't see
the problem.
Date: 4 Mar 2002 10:57:54
Message: <3c839982$1@news.povray.org>
> box          24 bytes
so you use only 4 bytes for the float number storage?
IMHO a box needs 6 float parameters to be defined...
regards
SY
Date: 4 Mar 2002 11:52:27
Message: <3c83a64b@news.povray.org>
  In fact, 2 is enough. See the box syntax for an example. (Of course with
2 floats it's axis-aligned, but that doesn't matter; the transformations of
a box are not made by moving its vertices anyways.)
Date: 4 Mar 2002 21:10:54
Message: <slrna88a9i.la6.ron.parker@fwi.com>
floats or vectors?
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 5 Mar 2002 03:29:31
Message: <3c8481eb@news.povray.org>
of
how do you define a box with 2 floats? even length, height and depth would
already need 3!
regards
SY
Date: 5 Mar 2002 06:53:17
Message: <3c84b1ad@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
> floats or vectors?
  Floats. (Of course that will create a cube, but as I said, transformations
can make it a box of any shape, and place and orient it in any way.)
  Thinking about it, it actually doesn't need any floats at all. Just
create a unit-cube by default and let the transformations do the rest.
  So in fact it requires 0 floats.
