POV-Ray : Newsgroups : povray.binaries.images : Basic SDL raymarcher Server Time
13 Feb 2026 06:57:22 EST (-0500)
  Basic SDL raymarcher (Message 1 to 7 of 7)
Subject: Basic SDL raymarcher
Date: 9 Aug 2023 20:00:00
Message: <web.64d427081961efb7f8c47d526e741498@news.povray.org>
Here's a generic raymarcher in POV-Ray. It consists of a camera looking at a
plane, and a pattern applied to said plane. Only diffuse shading has been
implemented (no shadows, reflections, etc.) The pattern loops through x and y
gradients, and uses various inputs which define the scene.
I would have liked to do this using pure functions (and not pigment_map loops)
but... solutions based on nothing but functions are hard to figure out :P
Sam
BasicRaymarching.pov
2023 Sam Benge
Warning! It takes a long time to parse. For faster parsing, lower the values for
Res and NSteps.
#version 3.7;
global_settings{assumed_gamma 2.2}
#default{ finish{emission 1} }
camera{
 orthographic
 right x up y
 location -z
 look_at 0
// a displacement pattern for the plane
#declare FPattern = function{pattern{crackle}}
// Distance Estimate for sphere and plane (This is the scene's geometry.
DE=signed distance function)
#declare DE =
 function{
  min(
   // sphere
   sqrt(x*x+y*y+z*z)-2,
   // plane
   y+1.9
   // displacement for plane
   - .4*FPattern(x, y, z)
//~~~ Raymarching Variables ~~~//
//  x & y resolution (later versions of POV-Ray [or maybe just UberPOV] allow
for more than 256 pigment_map entries)
#declare Res = <256, 256>;
// number of raymarching steps
#declare NSteps = 64;
// camera position
#declare RayBeg = <0, 0, -10>;
// light position
#declare LPos = vnormalize(<1, .5, -.3>);
// raymarching bailout threshold
#declare Threshold = 0.001;
// normal accuracy
#declare NAcc = .001;
//~~~ Rendering ~~~//
// we are just looking at a plane
plane{
 z, 0
 // image is mapped using two gradients: x & y
 pigment{
  // image uv y gradient
  function{min(1, max(0, y))}
  pigment_map{
   #for(Y, 0, Res.y-1)
    [1/Res.y*Y
     // image uv x gradient
     function{min(1, max(0, x))}
     pigment_map{
      #for(X, 0, Res.x-1)
       [1/Res.x*X
        // initialize Ray
        #local Ray = RayBeg;
        // ray direction
        #local RayDir = vnormalize(<X/Res.x-.5, Y/Res.y-.5, 1>);
        // did the ray hit something?
        // -1  = no, it did not
        // >=0 = yeah, it hit something
        #local FDist = -1;
        // march the ray through DE
        #for(I, 0, NSteps-1)
         // functions require all axes to be reduced to single values
         #local RX = Ray.x;
         #local RY = Ray.y;
         #local RZ = Ray.z;
         // value for DE at Ray position
         #local Dist = DE(RX, RY, RZ);
         // if DE at Ray position is below threshold
         #if(Dist<Threshold)
          // the ray hit something, so we give FDist a value
          #local FDist = Dist;
          // and then we get surface normal
          #local Norm =
           vnormalize(
             DE(RX-NAcc, RY, RZ)-DE(RX+NAcc, RY, RZ),
             DE(RX, RY-NAcc, RZ)-DE(RX, RY+NAcc, RZ),
             DE(RX, RY, RZ-NAcc)-DE(RX, RY, RZ+NAcc)
          #break
         // advance the ray
         #local Ray = Ray + Dist * RayDir;
        // return color/value based on whether or not the ray hit something
        #if(FDist>=0)
         // diffuse shading
         rgb .875 * max(0, pow(vdot(Norm, -LPos), .75))
        #else
         // background
         rgb .5
  // center pattern on screen
  translate -.5*(x+y-1/Res)
Download 'basicraymarching.jpg' (68 KB)
Preview of image 'basicraymarching.jpg'
Subject: Re: Basic SDL raymarcher
Date: 10 Aug 2023 02:05:00
Message: <web.64d47d41884abba817bac71e8ffb8ce3@news.povray.org>
Sam,
Can't you use the trace function for intersection testing an getting the normal?
Only had a swift look at the code. I.i.r.c. there was some patch that also
returned the colour at the intersection point. Brain's getting more fuzzy than
I'd like to.
Just posted a recent inc that traces objects or patterns to an inc file with
array's <web.64d47ced807074f217bac71e8ffb8ce3@news.povray.org>
ingo
"Samuel B." <stb### [at] hotmailcom> wrote:
> Hi,
Date: 10 Aug 2023 16:55:00
Message: <web.64d54d86884abba8f8c47d526e741498@news.povray.org>
"ingo" <nomail@nomail> wrote:
> Sam,
Hi ingo,
I could cheat, sure, but this is a raymarcher. It's an entirely different type
of rendering engine. To put it succinctly: it traces isosurfaces. It can't trace
any standard POV object directly because it only evaluates a function (signed
distance field/function, to be precise). That is why the ray has to step through
the scene; it can't know when it has hit something until it actually gets there.
(Believe it or not, but this method is actually faster when rendering certain
complex objects when using a GPU [if you have a GPU, check out shadertoy.com].
Things like 3D fractals can be rendered in real time, whereas in POV-Ray they
can take hours)
This scene is a test case: can it be done in POV-Ray? The answer is yes it
can... But this particular method is very inefficient.
> I.i.r.c. there was some patch that also returned the colour at the intersection
> point.
That could be done here too, since it's possible to obtain the value of a
pattern function after the ray has hit something. But any lighting here is
"virtual." I use no actual light_sources; they must be defined another way.
> Brain's getting more fuzzy than I'd like to.
I know what you mean, somewhat. I go through periods of extreme mental
tiredness, and I tend to forget a lot of things. Even the names of people I went
to school with. Or events that happened and /should/ remember, but I don't. (I
don't think it's dementia or anything... I think it's just the extreme changes
my brain goes through periodically.)
> ingo
Hm, I'll have to check that out. Based on the description, it makes rounded
shapes from sharp-edged objects (such as text)? I won't really know until I run
it, I guess :D
Sam
Date: 10 Aug 2023 19:25:00
Message: <web.64d57159884abba8f8c47d526e741498@news.povray.org>
Here's another version. I added a surface color, fog color, and shadows. It's
very slow. No antialiasing. A lot of artifacts typical of naive ray marching.
This image parsed very slowly but rendered quickly, finishing at a total of 3
minutes and 33 seconds, with a resolution of only 354x354.
(Why did I do this?)
This is far as I'll take it, because the whole exercise if kind of pointless,
other than to show how flexible POV-Ray's SDL can be.
Sam
BasicRaymarchingB.pov
2023 Sam Benge
Warning! It takes a long time to parse... minutes, even. For faster parsing,
lower the values for Res (start with <32, 32> Also, lower or RaySteps and
LightSteps if needed.
#version 3.7;
// linear interpolation function
#macro Mix(A, B, C) A*(1-C) + B*C #end
camera{
 orthographic
 right x up y
 location -z
 look_at 0
// distance estimate for sphere and plane (This is the scene's geometry.
DE=signed distance field/function)
#declare DE =
 function{
  min(
   // sphere
   // plane
   y+2
  // displacement
  + .07*(cos(7*x)+cos(7*y)+cos(7*z))
#declare Res = <354, 354>;
// number of camera raymarching steps
#declare RaySteps = 256;
// adjust camera ray step amount (1 is ideal, but some distance estimates
require lower values)
#declare Adj = 0.5;
// number of light steps
#declare LightSteps = 32;
// camera position
// light position
#declare LPos = <1, .5, -.3>;
// normal accuracy
// object color
#declare ObjCol = <1, .8, .5>;
// fog color
#declare FogCol = <.2, .4, 1>;
// fog distance
#declare FogDist = 20;
// we are only looking at a plane
plane{
 z, 0
 // image is mapped using x & y gradients
 pigment{
  pigment_map{
   #for(Y, 0, Res.y-1)
    [1/Res.y*Y
     pigment_map{
      #for(X, 0, Res.x-1)
       [1/Res.x*X
        // initialize Ray
        // ray direction
        // false = (default) no, it didn't hit anything
        // true  = yeah, it hit something
        #local DidHit = false;
        #for(I, 0, RaySteps-1)
         #local RX = Ray.x;
         #local RY = Ray.y;
         #local RZ = Ray.z;
         #local Dist = Adj*DE(RX, RY, RZ);
         #if(Dist<Threshold)
          // the ray hit something, so we set DidHit to true
          #local DidHit = true;
          // escape the loop because we don't need to trace anything anymore
          #break
         // advance the ray
        #if(DidHit) // the ray hit something, so we start shading the objects
         // position where the ray hit
         #local Hit = Ray;
         #local HX = Hit.x;
         #local HY = Hit.y;
         #local HZ = Hit.z;
         // initial color
         #local Col = ObjCol;
         // get the surface normal from DE() at hit position
         #local Norm =
          vnormalize(
            DE(HX+NAcc, HY, HZ)-DE(HX-NAcc, HY, HZ),
            DE(HX, HY+NAcc, HZ)-DE(HX, HY-NAcc, HZ),
            DE(HX, HY, HZ+NAcc)-DE(HX, HY, HZ-NAcc)
         // diffuse value
         #local Diffuse = max(0, pow(vdot(Norm, LPos), .75));
         // set initial color
         // apply diffuse
         #local Col = Col * Diffuse;
         // calculate shadows
         #if(true)
          // light direction
          #local LDir = vnormalize(LPos);
          // initialize light ray (slightly offset from surface)
          #local LRay = Hit + 2 * Threshold * Norm;
          // Is the light shining here? default = true
          #local IsLit = true;
          // march the light ray through DE
          // (not designed to stop after passing through light source)
          #for(I, 0, LightSteps)
           // light ray position is reduced to single values
           #local LX = LRay.x;
           #local LY = LRay.y;
           #local LZ = LRay.z;
           // value for DE at light ray position
           #local LDist = DE(LX, LY, LZ);
           // if light ray hits an object, then no light is shining on this
pixel
           #if(LDist<Threshold)
            // not lit
            #local IsLit = false;
            #break
           // advance the ray
           #local LRay = LRay + LDist * LDir;
          // apply shadow
          #local Col = Col * IsLit;
         #end // ~if shadows
         // apply fog (calculation provided from POV docs)
         #local Col = Mix(FogCol, Col, exp(-vlength(RayBeg-Hit)/FogDist));
         // final object color
         rgb Col
        #else // the ray didn't hit anything, so we use the background color
         // background
         rgb FogCol
Download 'basicraymarchingb3m_33s.jpg' (59 KB)
Preview of image 'basicraymarchingb3m_33s.jpg'
Date: 11 Aug 2023 19:15:00
Message: <web.64d6bfec884abba878f7f9ccdabc9342@news.povray.org>
> Sam
> 2023 Sam Benge
Thanks for sharing... very nice!
Again, will need spend some time looking at the funtions to understand. ;)
Mike.
Date: 13 Aug 2023 20:20:00
Message: <web.64d9728d884abba8f8c47d526e741498@news.povray.org>
> > > a generic raymarcher in POV-Ray. [...]
> > Here's another version. [...]
> Mike.
Thank you, Mike. It's ok. Not very useful in POV-Ray, although a more
function-based approach could be good in certain situations.
(If one /really/ wanted to learn about ray marching, they would check out
shadertoy.com, and also Inigo Quilez's tutorials here:
https://iquilezles.org/articles/)
Sam
Date: 14 Aug 2023 08:45:00
Message: <web.64da2129884abba878f7f9ccdabc9342@news.povray.org>
> > Mike.
> Sam
Thanks Sam,
I appreciate the reference.
Cheers,
Mike.
